Register to reply
How does x-ray diffraction from different Bragg planes add up?
by SadScholar
Tags: bragg, diffraction, planes, xray
Share this thread:
SadScholar
#1
Aug21-14, 01:35 PM
P: 36
I'm writing a little bit of Mathematica code that should be able to make a reasonable powder diffraction spectrum. The algorithm is like this:
Take Bravais lattice and basis. Compute reciprocal vectors.
Compute structure factor (and its square magnitude)
Have triple nested loop that creates ordered triplets of Miller indices. {(h1,k1,l1),(h2,k2,l2)....}
For each of these triplets, compute the momentum transfer vector G (in Kittel. It's K in A&M. Sometimes it's called Q or Δk in other texts). Compute the angle of the peak from Bragg's law and the intensity from the structure factor's square.
OK, this algorithm runs. I look through the list of angles. They all compare perfectly with reference literature. Here's where the real question comes in. I have this list of Miller indices, and each one comes with an angle and an intensity. Sometimes, many many miller indices come at the same Bragg angle, because the MAGNITUDE of G is the same. Should I just add the intensity (structure factor squared) of these so that they make a superpeak at that angle? Was I wrong to square the structure factor in the first place? Should I instead leave it unsquared and then square it only after I've added together all of the structure factors at a given angle? I tried both of these things, and they both yield nonsense in terms of peak intensity. I'm getting anomalously high peaks at high angle. The atomic form factor should be preventing that from happening. Any insight on this would be greatly appreciated.
PS: Debye-Waller factor is not the answer. I'm not at high enough momentum transfer for that to account for the massive discrepancies I see.
Phys.Org News Partner Physics news on Phys.org
X-ray stroboscope offers new insights into biomolecular dynamics
Ordinary materials, fantastic opportunities
A metallic alloy that is tough and ductile at cryogenic temperatures
M Quack
#2
Aug23-14, 01:08 PM
P: 672
In a powder, different G vectors correspond to different orientations, i.e. the diffracted intensity comes from different grains within the powder. There add incoherently, therefore you have to add the intensities.
There are more "correction" factors that take into account the polarization, geometry, etc.
http://reference.iucr.org/dictionary...ion_correction
SadScholar
#3
Aug23-14, 01:17 PM
P: 36
Thanks for this. Does Rietveld fitting take this kind of thing into account?
SadScholar
#4
Aug23-14, 03:31 PM
P: 36
It looks like I lied. I took the Debye-Waller factor into account, and the pattern showed up perfectly.
M Quack
#5
Aug23-14, 03:52 PM
P: 672
Common Rietveld fitting codes take all this into account. The Debye-Waller factor can even be asymmetric, giving a "thermal ellipsoid".
The codes calculate a "theoretical" x-ray diffraction pattern from the sample and experimental input parameters, and then optimize the parameters to best match the calculated pattern to the experimental data. How exactly the pattern is calculated, and how you can constrain and limit parameters varies from code to code, but the fundamentals you point out above should be taken into account in any good Rietveld code.
Register to reply
Related Discussions
Bragg planes seem imaginary Quantum Physics 3
X-ray Diffraction and Bragg's Law Advanced Physics Homework 0
Bragg Diffraction Physics Learning Materials 0
Bragg diffraction Advanced Physics Homework 5
Bragg's Diffraction Introductory Physics Homework 0
