Integrate (1+x+x^2) / x(1+x^2) for x. Partial dractions?
In summary, the conversation is discussing the partial fraction expansion of (1+x+x^2)/x(1+x^2) and its integration, with the final result being ln x + arctan x + C. The correctness of the expansion is confirmed and the conversation concludes with a question about the possibility of integration being taught in precalculus.
teng125
416
integre (1+x+x^2) / x(1+x^2)
pls help...
i used partial fraction and obtain the answer of ln x - 1/2 ln (1-x^2) + arctan x
is it correct??
That's not what I get. HOW did you get that? What was the partial fractions expansion?
i got 1 +x +x^2 = A(1+x^2) + B(x^2) + Cx
then let x =1 and -1 and again x=0
is it correct??
Looks good. So what are your A, B, and C?
Remember that:
[tex]\frac{1 + x + x ^ 2}{x(1 + x ^ 2)} = \frac{A}{x} + \frac{Bx + C}{1 + x ^ 2}[/tex]
What does your final result look like?
A=1 B=0 and C=1
is it right
Yup, it looks good. So:
[tex]\int \frac{1 + x + x ^ 2}{x(1 + x ^ 2)} dx = \int \left( \frac{1}{x} + \frac{1}{1 + x ^ 2} \right) dx = ?[/tex]
Can you integrate this? And what's your answer, then?
oh...i intgre wrongly on the above...is should be ln x + arctan x rite??
Looks about right, but don't forget the constant of integration. :wink:
Are they teaching integration in precalculus now?:confused:
1. What are partial fractions?
Partial fractions are a method of breaking down a complicated rational function into simpler fractions that can be easily integrated.
2. Why would I need to use partial fractions?
Partial fractions can make it easier to integrate complex rational functions, as well as solve differential equations and evaluate improper integrals.
3. How do I know when to use partial fractions?
Partial fractions are typically used when the degree of the numerator is less than or equal to the degree of the denominator, and when the denominator cannot be factored into linear terms.
4. How do I integrate using partial fractions?
To integrate using partial fractions, first decompose the given rational function into simpler fractions using the method of partial fractions. Then, integrate each individual fraction and combine the results to get the final solution.
5. What is the general form of a partial fraction decomposition?
The general form of a partial fraction decomposition is:
(Ax + B)/(x(x^2 + 1)) = A/x + (Bx + C)/(x^2 + 1)
where A, B, and C are constants to be determined.
