Understanding Redshift: Exploring the Color Shifts in Science
  • Thread starter eggman
In summary, Doppler shift is the process by which the frequency of light waves changes as an object approaches or recedes from an observer.
eggman
64
What is 'redshift' ?
one poster says depending on the color you see it will tell you which way the picture is moving..
ex:either away from the observer or towards the observer..
please explain in SIMPLE terms what these 'shifts' are...
is there a green shift or a blue shift in science?
..(i hope i put this idea in the proper area of the forum) :rolleyes:
There is indeed a 'blue' shift, which is the opposite of the 'red' shift. Both occur because the speed of light is constant. An object approching you is traveling at speed a, for instance. Since the speed of light is c, the logical first thought is that the light would then be approacing you at a + c. That can't happen, though, because the light is restricted to c. Instead, the light waves become 'compressed' (sort of like a spring). The waves get closer together (shorter wavelength), which raises the frequency (in the case of visible EM, toward the blue end of the spectrum).
A redshift is the opposite, wherein a receding object has the light waves behind it 'stretched' to a longer wavelength (red end of the spectrum).
Thanks you for your reply...
Look at this logic and see if it makes sense?
I look out my kitchen window...there is a green shrub/tree in the distance..
Is it moving away from me...or towards me?
..or is this apparent movement a 'trick of the light'?
This is very complex I feel because of the 'observers' question can be
false...that is to say not a True Scientific Question..
Needless to say I am not good at science...
I think that you're misinterpreting the use of colour words in Doppler terms. Whatever the initial frequency of the EM is, it will be either increased or decreased according to a specific formula related to its motion. 'Red' and 'blue' are simply used to indicate that because they're the extreme ends of the EM spectrum that humans can see. Something that's blue to start with, approaching you fast enough, will be shifted up to ultraviolet or even gamma, which aren't visible. Something that starts out in ultraviolet will climb to x-ray or gamma status.
The bush is green due to the pigmentation of its cells, and has nothing to do with whether or not it's moving. (It isn't, by the way, unless you have an alien in your yard.) If someone were to uproot that bush and throw it at you at a good percentage of light speed, it would then grow bluer.
I think I see the idea...
The next time I see one of those trees vanish I will know its moving fast and could possibly wack me! :rofl:
Thanks for your help Danger :tongue2:
...the moral of the story...'Watch out for things that suddenly dissappear..it will indicate a 'shift' in the continuum and sh*t is
in the process of hurling itself about SpaceTime!
I wouldn't go putting that on an exam paper, but it sounds good to me. :biggrin:
And watch out for SpaceTigers!
Oh, yes! They're the worst! Bengals are timid little pussycats compared to the Space variety.
The names redshift and blueshift are used because red and blue are on opposite ends of the spectrum. If the wave is shifted longer, it is "redshift", if it is shifted shorter, it is "blueshift".
Doppler shift also works on sounds. When a train passes you and the pitch of its whistle changes - first rising, then falling, that's the same as blue then red shift - just with sound instead of light.
Thought Experiment
1)..If a man had a baseball attached to a wire and began to
spin it in a circle above his head what would you see as the ball
approached the speed of light...
You would see a spinning ball. I assume you mean what color, if so, because it is spinning, one side would be red, and the other blue as it approached the speed of light. One side is relatively moving toward you, and the other, relatively moving away.
If the ball achieved 'c' (speed of light) would it dissappear?
or what would you observe?
The ball wouldn't achieve the speed of light.
I put some stuff about speed and vibration over in the metaphysics section...I was attempting to understand what would occur
if an 'object' were capable of remaining intact and going lightspeed.
I am attempting to wrap my brain around Time Travel...and its different perceptions
Its very hard to grasp
You would notice nothing out of the ordinary, regardless of the speed of the ball.
And nothing with mass, be it a ball, a bat, or an umpire, can achieve light speed. There's no point in trying to visualize what would happen if it did, because it's flatly impossible.
Are you dismissing my conjecture?
Why would the baseball be 'spinning'?
~H
I think that he means revolving around the anchor of the string, not rotating on its own axis.
Help Please...
If nothing can move faster than the Speed of Light...
then please explain the phrase 'The speed of Light Squared' (E=MC2)
that would be 186,000 mps X 186,000mps
...what am I missing :cry:
even in the mutiplication its still called 'the speed of light' :frown:
It's merely the number squared, not the speed. I can square my age on paper; it doesn't make me suddenly 2,500 years old.
1. What is redshift?
Redshift is a phenomenon in which the light from an object appears to have a longer wavelength than it actually does. This is caused by the expansion of the universe, which stretches out the wavelengths of light as it travels through space.
2. How is redshift measured?
Redshift is measured using a unit called "z" which represents the amount of stretching that has occurred. It is calculated by comparing the observed wavelength of light from an object to its known rest wavelength. A higher value of z indicates a greater amount of stretching and therefore a higher redshift.
3. What causes redshift?
As mentioned, redshift is caused by the expansion of the universe. This expansion causes the space between objects to increase, which in turn stretches out the wavelengths of light as it travels through this expanding space.
4. How does redshift affect our understanding of the universe?
Redshift is an important tool in understanding the structure and history of the universe. By studying the redshift of objects, scientists can determine the distance and velocity of those objects, providing insight into the expansion of the universe and the evolution of galaxies.
5. Can redshift be used to determine the age of the universe?
Yes, redshift can be used to estimate the age of the universe. By measuring the redshift of distant objects, scientists can calculate the rate of expansion and use this to determine when the expansion began. This, in turn, can provide an estimate for the age of the universe.
  • Astronomy and Astrophysics
  • Other Physics Topics
  • Thermodynamics
