Determinant of symmetric matrix with non negative integer element
In summary, the conversation discusses the proof of the determinant of a matrix A with dimensions n x n being equal to [(-1)^n][n][2^(n-1)]. The proof is suggested to be done using induction, while for n = 4, it is recommended to evaluate the determinant by expanding it. It is also suggested to manipulate the matrix by adding or subtracting rows or columns to simplify the calculation.
golekjwb
Let \begin{equation*}
A=%
\begin{bmatrix}
0 & 1 & \cdots & n-1 & n \\
1 & 0 & \cdots & n-2 & n-1 \\
\vdots & \vdots & \ddots & \vdots & \vdots \\
n-1 & n-2 & \cdots & 0 & 1 \\
n& n-2 & \cdots & 1 & 0%
\end{bmatrix}%
\end{equation*}.
How can you prove that det(A)=[(-1)^n][n][2^(n-1)]? Thanks.
Try n=4
golekjwb said:
Try n=4
Hey golekjwb and welcome to the forums.
For the general proof I would use an induction argument. The differences between say n = k and n = k + 1 has to do with evaluating one extra minor determinant for that extra row and you would show that under a simplification that the formula is correct.
For a specific n=4, just evaluate the determinant for that particular dimension for your particular matrix, expand out and see what you get.
welcome to pf!
hi golekjwb! welcome to pf! :smile:
have you tried adding or subtracting rows or columns, to get a simpler matrix?
I would approach this problem by first understanding the properties of symmetric matrices and their determinants. A symmetric matrix is a square matrix that is equal to its transpose, meaning that the elements above and below the main diagonal are symmetrical.
To prove the determinant of a symmetric matrix with non-negative integer elements, we can use the cofactor expansion method. The determinant of a matrix is equal to the sum of the products of the elements in any row or column multiplied by their corresponding cofactors.
In this case, we can choose the first column to expand the determinant. The first element in the first row is 0, so the corresponding cofactor is (-1)^{1+1} = 1. The determinant of the remaining (n-1)x(n-1) matrix is denoted as det(A').
Therefore, the determinant of the first column is 0 x det(A') = 0. We can continue this process for the remaining columns, where the determinant of the second column is 1 x det(A''), the third column is 2 x det(A'''), and so on.
Since the elements in each column are multiplied by a different number, we can factor out the common term n! from the determinant. This gives us det(A) = n! x det(A').
Next, we can use the fact that det(A') is equal to the determinant of a (n-1)x(n-1) symmetric matrix with non-negative integer elements. We can repeat the process above, choosing the first column to expand the determinant. This time, the first element in the first row is 1, so the corresponding cofactor is (-1)^{1+1} = 1. The determinant of the remaining (n-2)x(n-2) matrix is denoted as det(A'').
Continuing this process, we can see that det(A') = (n-1) x (n-2) x det(A''). We can factor out another common term (n-1)! from the determinant, giving us det(A) = n! x (n-1)! x det(A'').
We can continue this process until we reach a 2x2 matrix, where the determinant is simply the product of the elements on the main diagonal (0 x 0 - 1 x (n-1) = - (n-1)). Therefore, det(A) = n
What is a determinant?
A determinant is a mathematical value that can be calculated from a square matrix. It is used to determine certain properties of the matrix, such as whether it is invertible or singular.
How is the determinant of a symmetric matrix calculated?
The determinant of a symmetric matrix can be calculated using the cofactor expansion method, where the determinant is recursively calculated using the determinants of smaller matrices. Alternatively, the determinant can also be calculated using the Gaussian elimination method.
What is the significance of a symmetric matrix with non-negative integer elements?
A symmetric matrix with non-negative integer elements has special properties that make it useful in various applications. For example, it can represent a network or system where the elements represent connections or interactions between nodes.
What is the relationship between the determinant and the eigenvalues of a symmetric matrix with non-negative integer elements?
The determinant of a symmetric matrix with non-negative integer elements is equal to the product of its eigenvalues. This means that the determinant can provide information about the eigenvalues and vice versa.
How can the determinant of a symmetric matrix with non-negative integer elements be used in real-world problems?
The determinant of a symmetric matrix with non-negative integer elements can be used to solve systems of linear equations, calculate the area of a parallelogram or volume of a parallelepiped, and determine the stability of a dynamical system. It also has applications in computer science, physics, and engineering.
  • Linear and Abstract Algebra
