C programming Q: initializing an array of structures
In summary: Info[curse].name = "Curse";...line is doing is attempting to assign a string literal to an array of char. You can't do that. You need to use a function like strcpy() or strncpy() to accomplish that.Or initialize it at declaration time:struct cardDef cardInfo[treasure_map +1] = { {"Curse", CURSE, 0, -1, 0, 0, 0}, {"Duchy", VICTORY, 5, 3, 0, 0, 0},...}Yes! That is the standard way to do it.
jjc
I am writing a program in C (vanilla, non-C++/C#) and I am having trouble figuring out why my initialization of my array of structures isn't working. I have tried a number of things without any luck. I still get a compiler error: "conflicting types for 'cardInfo' "
I am writing a simple implementation of a card game (Dominion) and each card has different costs, effects, etc. So I was going to make a struct, plop a bunch into an array (we only need to implement 27 cards, already specified) so that I could access various bits of info about them more easily (I need the cost in the Buying phase, the Coins and Actions in another phase, etc).
There is an ENUM earlier in the program that defines the names 'curse', 'estate', 'treasure_map' and others. So I am using those enums as indexes (as well as defining the array size). So when defining the array elements (the cardDef structures) I am trying to set the 0-index element as the Curse card ('curse' enum is 0), the 1-index as "Estate" ('estate' enum is 1).
Code:
struct cardDef {
	char name[MAX_NAME];
	enum CARDTYPES card_type;
	int card_cost;
	int victory_points;
	int addBuyCcoins;
	int addActions;
	int addCards;
struct cardDef cardInfo[treasure_map + 1];  /*my attempted array declaration  */
/*Trying to initialize the elements of the array here.  This first line is where I get the
compiler error; the other lines are examples of other styles that still got the same error.   */
struct cardDef cardInfo[curse] = {"Curse", CURSE, 0, -1, 0, 0, 0};
cardDef cardInfo[duchy]  = {"Duchy", VICTORY, 5, 3, 0, 0, 0};
cardInfo[estate]  = {"Estate", VICTORY, 2, 1, 0, 0, 0};
Any pointers (haha - no C pointers please) and help would be appreciated. I imagine that it is something simple, but the various references and tutorials that I have found on this seem to point to the method that I use in the first line. No love from GCC, though. And it's late, and I am cross-eyed from staring at this. :)
Thanks!
Justin
Code:
struct cardDef {
	int card_cost;
	int victory_points;
	int addBuyCcoins;
	int addActions;
	int addCards;
Thanks!
Justin
You are attempting to declare and/or define cardInfo multiple times. This declaration
Code:
indicates that cardInfo is an array of (treasure_map + 1) cardDef elements.
Here you are redefining cardInfo
Code:
as an array of (curse) cardDef elements. This is why you are getting the error you're seeing.
A similar thing is happening with these definitions.
Code:
You can initialize an array of structs at the place where you define the array, but you can't define the array as you did in the first line, and then come back later and assign a struct value to one of the elements of the array.
If your book doesn't have any examples of initializing an array of structs, see http://www.mycplus.com/tutorials/c-programming-tutorials/unions-structures/1/ and http://www.mycplus.com/tutorials/c-programming-tutorials/unions-structures/2/.
After a nice long nap, I see what you are getting at now. Thanks!
So it seems that the way to initialize it is to do either member by member:
Code:
cardInfo[curse].name = "Curse";
cardInfo[curse].card_type = CURSE;
cardInfo[curse].card_cost = 0;
etc.
Code:
I got stuck on thinking that it was just like setting array values, where the equals sign was enough for the compiler to recognize that it is an assignment to that index instead of a declaration of the array w/ that many elements. Ah, the intricacies of C! :)
Thanks again,
Justin
Code:
Sort of. You can assign values like so to the card_type and card_cost members, but not to the name member. What your first assignment statement here does is to store a memory location into name, which is in essence a pointer.
For this member you should use one of the standard library functions such as strcpy. So the first line above would look like this:
Code:
strcopy(cardInfo[curse].name, "Curse");
This will actually copy the characters in "Curse" to the name member of the struct. Be sure to #include <string.h> for the declaration of strcpy().
jjc said:
etc.
Code:
Remember that you can't set a character array by assignment for the reason given above. You can set the individual character elements of such an array or you can use strcpy or another function to do this.
You can initialize a character array, but this is different from assigning a string value to a string (really, character array or pointer to a character).
IOW, this will work:
Code:
char name[10] = "Fred";
but this won't.
Code:
char name[10];
name = "Fred";
In the first example, the array name is being initialized with the string constant. In the second, the compiler will generate an error, because name is not an lvalue (i.e., name cannot appear on the left side of an assignment statement.
Hope that helps.
OK, thanks for the clarifications. I think I have a better handle on it now.
Is the only way to assign data to the structures, if I don't do it at declaration, to do it member by member, though? I keep thinking about only filling the array of structures with cards that are actually being used (27 are defined, only 17 or so are used).
Thanks,
Justin
Yes.
Thanks,
Justin
Bummer, but good to know. :)
Thanks again for all the pointers.
-- Justin
1. How do you initialize an array of structures in C programming?
To initialize an array of structures in C programming, you can use the curly braces syntax to assign values to each member of the structure within the array. For example:
struct student {
int id;
char name[20];
struct student class[3] = {
{1, "John"},
{2, "Jane"},
{3, "Bob"}
This creates an array of 3 student structures with the specified values for each member.
2. Can you initialize an array of structures with a loop in C programming?
Yes, you can use a loop to initialize an array of structures in C programming. This can be useful if you have a large number of structures or if the values need to be generated dynamically. You can use a for loop or a while loop to iterate through the array and assign values to each member of the structure within the loop.
3. How do you initialize an array of structures with default values in C programming?
If you want to initialize an array of structures with default values, you can use the curly braces syntax and leave some members empty. For example:
struct student {
int id;
char name[20];
char major[20];
{1, "John"},
{2, "Jane", "Computer Science"},
{3, "Bob"}
This will initialize the first and third structures with default values for the major member, while the second structure will have a specific value assigned to the major member.
4. How do you initialize an array of structures with pointers in C programming?
You can initialize an array of structures with pointers in C programming by using the arrow operator (->) to access the members of the structure. For example:
struct student {
int id;
char *name;
{1, "John"},
{2, "Jane"},
{3, "Bob"}
To access the name member of the second structure, you can use:
class[1].name = "Jane";
Or using the arrow operator:
class[1]->name = "Jane";
5. How do you initialize an array of nested structures in C programming?
To initialize an array of nested structures in C programming, you can use the curly braces syntax and nest the structures within each other. For example:
struct address {
int house_number;
char street[50];
struct student {
int id;
char name[20];
struct address home_address;
{1, "John", {123, "Main Street"}},
{2, "Jane", {456, "Oak Avenue"}},
{3, "Bob", {789, "Maple Drive"}}
This creates an array of 3 student structures, with each structure containing a nested address structure for the home address of the student.
