Tosh5457
- 134
- 28
I live in an apartment, and today I heard what seemed small rocks falling in one of the walls (it's a wall that goes through the center of the building), several times. Is this normal?
lisab said:I bet it's mice, or some sort of rodent, in the walls.
Tosh5457 said:I live in the 4th floor, how would they come up here inside the walls?
collinsmark said:
phylotree said:Who is this guy ?
collinsmark said:
There are a few possible explanations for this sound. It could be caused by loose debris or construction materials inside the wall, which can shift and fall as the building settles. It is also possible that small animals, such as rodents or insects, have made their way into the wall and are causing the noise. Lastly, the sound could be coming from pipes or ductwork that run through the wall and are experiencing some kind of blockage or damage.
In most cases, the sound of small rocks falling inside a wall is not dangerous. However, it is important to determine the cause of the sound and address any potential issues. If the sound is coming from loose debris or construction materials, it is best to have a professional inspect and repair the wall to prevent any potential hazards. If the sound is caused by animals or blocked pipes, it is important to address these issues to prevent any damage to the building.
To determine the source of the sound, you can try tapping on different areas of the wall to see if the sound becomes louder or changes. You can also try to listen for the sound in different rooms or areas of the building to narrow down the location. If you are unable to determine the source yourself, it is best to consult a professional for further assistance.
The answer to this question depends on the cause of the sound. If it is caused by loose debris or construction materials, a professional can repair the wall to prevent further movement and noise. If the sound is caused by animals or blocked pipes, addressing these underlying issues should stop the noise. However, if the sound is due to a structural issue with the building, it may require more extensive repairs to fix.
No, it is not normal for a wall to make this kind of sound. Walls should be solid and not have any loose materials or debris inside. If you hear this sound, it is important to investigate and address the issue to prevent any potential damage or hazards. It is always best to consult a professional for proper diagnosis and repair of the issue.
