Gear ratio question. ugh i'm confused.
In summary: say 100 foot pounds would solve the issue of over-speeding, and allow the engine to produce the desired work.tuning down the torque to...say 100 foot pounds would solve the issue of over-speeding, and allow the engine to produce the desired work.
jakksincorpse
74
okay. i recently had a forum asking about gear ratio that has me so confused on the concept of ratio that it hurts.
if you have a 40 spline gear and a 20spine gear. and ur power input is on the 40 spline gear. doesn't that mean the 20 spline gear will rotate twice every time the 40 spline gear rotates once?
It doesn't matter which shaft is the driven shaft. Whenever a 40 tooth gear meshes with a 20 tooth gear the shaft that the 40 tooth gear is mounted to will make one revolution for every 2 revolutions the 20 tooth gear makes.
okay. so with this statement. we could typically say that the 20 spline tooth gear will provide twice the work of the 40 spline tooth gear correct?
No. It will have twice the number of revolutions, and half the torque. So the amount of work would be equal.
What if torque isn't a desired effect but rotation. its for a propeller. would it still be equal work? because this could be the difference of 1000lbf and 2000lbf, which would be 100% more efficient and very beneficial.
The faster a propeller spins, the more torque it needs.
So, you can't just slap any small motor onto a gearbox, and ask it to spin the propeller as fast as you want. It simply won't be able to do it. An airplane propeller might only spin at 2000-3000 rpm for example, but it might need thousands of foot-pounds of torque to do so. The result is that, in a lot of cases, the power of the engine is actually put through a REDUCTION gearbox, to decrease the rpm and increase the torque going to the propeller.
Otherwise, the engine simply would not have the strength to spin the thing fast enough.
It's okay if the amount of rotation is your desired effect, but that would be different than work. Work has a strict definition in physics and engineering: Force-times-Distance, or equivalently Torque-times-Angle for a rotating shaft.
I don't know if you have some application in mind, or this was a hypothetical question. In practice, you can't just "gear up" to an arbitrarily high rotation rate because you need enough torque to drive whatever load is attached.
yea I am not an idiot thanks, that was too ur small motor remark.
secondly there's no 1000's of foot pounds of torque. more like 120 foot pounds of torque that i need out of a 310 foot lb torque motor.
and third, you might want to look up how a helicopter works...the goal is to reduce torque...not do a burn out on the highway, oh wait...theres no tires...just a propeller.
thanks for your reply tho, the reason why i ask is because i have an excess amount of torque compared to the rotational weight of the propeller. which seems like a waste because there's no friction application. just aviation.
tuning down the torque to match the weight of the propeller will initially raise the rpms if using this 2:1 gear ratio or something of the sort correct?
i mean obviously if i have too much torque and a moderate amount of rotation for vertical thrust, that seems like a waste.
so i thought this gear ratio for less torque and more rpm would make a more efficient propeller application. which ultimately would use less gas while producing more thrust.
am i right so far on this?
There is only the amount of torque proportional to the power divided by rotational speed. For example, if the propeller uses power that only requires 120 ft.lbs. of torque and the motor is directly coupled to it, the motor is only producing 120 ft.lbs of torque. No torque is wasted. If the motor is producing an excess of torque, the propeller will speed up until an equilibrium is reached. For efficiency, you try to minimize the power required to produce the required thrust. Unless I am misunderstanding your application, the best way to maximize efficiency would be to choose a gear ratio such that the motor and propeller both are operating at their respective design speeds or speeds where they are most efficient.
...okay...thats kind of what I am asking but thanks for restating my question...
so I am guessing that you agree with what i said then, finding the correct gear ratio to reduce this 310ft lb of torque to 120lb of torque while increasing propeller speed for more thrust, is the best application for my flying machine.
When you want to match a power source to a load, you do not look at the torque but at the power.
Your propeller will need some amount of power to do the job (read http://www.auf.asn.au/groundschool/propeller.html#propellers" ). So it's the product of torque AND rpm that matters, not the torque alone. A propeller is designed to be efficient at a particular rpm, so the rpm is fixed, you can't modified it at your will.
For a particular propeller with a particular aircraft, you will get a "power required curve", like this one:
[PLAIN]http://www.auf.asn.au/groundschool/powercurve.gif
Then you will overlap the power curve of the engine of that curve, like this:
[PLAIN]http://www.auf.asn.au/groundschool/poweravailable.gif
Every time both curves are at the same point, it is a stable condition. If the engine power is greater than the power required, than the propeller will accelerate until it reach a stable condition. The power required will never be greater than the engine power.
The gearbox is used to match the maximum rpm of the engine to the maximum rpm of the propeller. No matter the gear ratio, the power stays constant (minus some efficiency losses) between the gearbox input and output.
You can also check this more technical http://continuouswave.com/whaler/reference/propellerPowerCurve.html" . It is about propeller for boat propulsion, but the same principle apply.
All I have to go off of is what you write, and "we could typically say that the 20 spline tooth gear will provide twice the work of the 40 spline tooth gear correct?" was indicative that you didn't know the basics. So I explained it as basically as I could. Second, not knowing something doesn't make one an idiot...especially if you know that you don't know something, and try to remedy it...which is the point of this site. I apologize if my explanation insulted you though...
When a helicopter has a turbine engine spinning at 10000rpm and making thousands of horsepower, and the propeller is spinning at a few hundred rpm...well I don't want to say anything that might insult you again. I'm sure you know the formula to derive how much torque that propeller is seeing.
Jakkincorpe, you've been told just how gears work several times now, both by me and others. You continue to ignore what we are saying and respond with flippant remarks.
We know how gears work, you obviously don't. I suggest you listen to what people are saying.
ur all right i reall don't know how they work. it just seems common sense that 1 rotation that can be multiplied by 2 would produce more power. its fine though, thanks for the replies everyone. imma take a break on all of this and research a little more.
I'm not saying don't ask questions or be put off as it's taking a while, or my bluntness. I had to be blunt to get through that you are sticking with a misconception and not listening to what people ar esaying. You are trying to tackle too many things that you don't have a full understanding of.
There is no shame in not understanding something, we are here to share our knowledge and collectively we do have a very large knowledge base.
Common sense in a very dangerous thing regarding engineering as even a minor error in understanding it can lead to massively wrong conclusions. What you think of as 'more power' is acutally 'more torque'. The power is always constant.
If you can come up with a clear idea of what you want to do in schematic form. This means the specifics such as motor size, gear ratio and proellor size are all not needed.
EG: Motor -> Gearbox -> Propellor
With the aim of lifting you vertically (if I recall correctly).
We can take it from the motor one step at a time of how the powr is transferred and why no new power is available.
Just always remember one thing: The power in, must equal the power out minus any losses, and you can't go wrong.
CS
wait, is all this confusion happening because I'm saying "power" instead of "torque"?
like as in i know the motor power will never change, but the smaller gear would produce more torque to the turbine than the motors power would alone. is that right?
The confusion is that you are still confusing power and torque with each other. You aren't clear on how they are different and how they can be related to each other mathematically. You must start treating them as the completely separate entities that they are and paying attention to the mathematical relationships. Ie:
"more torque...than the motor's power would alone" is a jumble of words that doesn't have any meaning because power isn't torque. Knowing the power of a motor tells you very little about what the torque at the motor might be.
The motor has produces a certain torque at a certain rpm. Multiply them together and you get power. Apply a gear ratio and the rpm at the drive shaft goes down while the torque goes up (or vice versa) and the powe stays constant...and the rpm and torque at the motor stay constant.
Note, however, that depending on the type of motor and the application, the motor may simply fail to do what you want it to do. In the case of a synchronous AC motor driving a fan, for example, the rpm of the motor is fixed, but the power is not. If you gear-up the fan to spin faster, the rpm of the motor stays constant, the rpm of the fan goes up, the torque at the fan goes up, and the torque at the motor goes up a lot. The net result for a fan is that doubling the speed of the fan increases the motor power by a factor of 8. And a synchronous AC motor will successfully run at pretty much whatever power you demand from it...until it burns itself up.
Wow. This is what was confusing me. I knew what I was talking about the whole time I just wasn't wording it correctly. Jesus what a waste of time. Now that I'm over that freaking hump. I'm relieved. so I'm not to big on a flying machine right now.. My family and I saw this weird *** plane with a huge light source just floating from miles away. It looked like a planet but it moved slightly in every direction. Plus through a telescope it looked as if it was spinning. Then we saw a jet fly by towards the thing so we were all like... Aliens? Haha idk it was weird. So flying is a no because I don't want to be confronted by a B2 ever in my life. However. This gear ratio realization has led me to thinking about a car with amazing gas mileage by just using the gears and keeping a lightweight design. I'm on my iPhone right now so I'll go in further detail tomo. Night.
In your earlier posts, your math was wrong, so this clearly was not a matter of wording it was a matter of conceptual understanding. The problems continue:
There's no magic with gear ratios on cars. As others mentioned, they are already designed for optimum fuel efficiency, matching the most efficient operating point with the required output at a certain cruise speed. You cannot increase fuel economy by further changes in gear ratio unless you are adjusting for different operating conditions.
Also, fuel efficiency is not much of a function of weight for a car at cruise speed. Fuel efficiency is a function of drag.
I didn't say anything before, but I know exactly what you idea is (I think) as I've seen it before. I'll try to be clairvoyant. You were going to suggest that you could use a gear that kept an engine at idle but allowed the wheels to turn at many many rpm giving high road speed.
There are 2 ways of describing what is wrong with this one method using torque the other using power (in reality they describe the same thing).
1) You will use a gearing that increases the rpm and so reduces torque at the wheel, meaning it won't have the necessary thrust to attain the speed you want. The drag will just overpower the car and not allow it to accelerate. Ie you don't have enough wheel torque. OR 2) You don't have enough power at idle to push a cartain car with drag 'x' at a certain speed. You don't have enough engine power.
In the case above at idle rpm, you don't have the torque necessary (and therefore the power necessary) to propel the car at high speeds. No matter what the gearing.
the idle thing was for the vertical thrust. my calcs of the thust issue showed me at idle the propellers would be producing enough thrust to lift the vehicle. which the equivelent was like 2400lb of thrust while the vehicle only weighed 2000lbs.
but in this about the gearing of an actual car u are correct lol there is no way I'm going to be able to produce enough torque to go 60mph at idle haha.
yes, there is no magic in gear ratios. but if you have a low enough idle gear at a lower rpm than factory standard with a more efficient engine you can double your mpg. I'm thinking about a diesel motor so here's what i came up with using a 96-98 jetta turbodiesel
with a 24" wheel diameter, it will take 220 rotations to travel one mile. at 60mph the engine would be at 1900rpm, meaning the tranny gear would be 2.33:1 and the differential would be 3.7:1. i used 1900rpm because that's the engines maximum torque (149ft/t). so at this speed with the ratios the torque to the wheels is 1,284ft/t at 220rpm.
this is a very excessive amount of torque for highway cruising. my 2000 mustang only used 730ft/t at 220rpm and it weighed 200lbs more than the jetta.
thats what I'm saying. if you cut the rotation of the engine in half, while still producing enough torque to travel at 60mph. you'll gain mpg.
about the weight thing as well with the fuel efficiency russ, its a proven fact that if you can cut 50lbs off your cars weight you'll see a 6-10% gain in mpg. the GM ultralite factored that into producing a car that only weighed 420lbs, met USA speed standards, size, and got 80mpg. the thing was that the car was way to expensive to produce. but that's the problem with a lot of things these days. just not enough ppl manufacturing the products to create the parts.
Cutting drag is far more effective than cutting weight at any speed above about 45mph. Unless you are traveling up hill all the time or constantly accelerating and braking sharply. linky to a graph of losses: http://www.maxdunn.com/files/attachments/maxdunn/Max%20Dunn/tesla_losses.jpg
Obv losing weight is good, but if you had the choice of increaing weight to decreasing aero drag, you'd see a bigger gain at cruising speeds.And to be honest the US is in the dark ages in terms of engine technology on production cars. It all stems from the curious way your emissions standards are defined. It's easier to get a bigger displacement engine to pass regulations which encourages overpowered engines for every day needs. When a small turbodiesel will get vastly superioir emissions and mpg.
I do like muscle cars though, I appreciate the idea brute force over fancy technology.EDIT: Also I just can't understand the reason why Jettas outsell Golfs. Before the MK5 the jettas just looked so crap.
Do you understand that when traveling at (say) 60mph you're not using anywhere near maximum torque, and that your theory is flawed? If not, go ahead.
one mile.
Are you sure?
Also, about the 2400lbs lift at idle, how did you figure that out? I hope you're not underestimating how much brute force it takes to push air around. Some airplanes use up tens of thousands of horsepower doing nothing more than just pushing air around...
Well, yes, you can certainly swap-out a more efficient or smaller engine to gain fuel economy. Double would be tough, but it depends on what is in a car now.
You seem to be assuming that if the engine is running at 1900 rpm, it is producing 149 ft-lb of torque. It has been explained to you before that this is not correct. 149 ft-lb may be the maximum torque, but it is not the actual torque.
The power at the wheels is the same regardless of the size of the engine, so the only real fuel economy difference is in the efficiency of the engine and drivetrain. The efficiency isn't likely to change much unless you go with a radically different engine. For example, I drive a Mazda 6 and Mazda currently offers a 170hp 2.5L 4cyl which gets 30 mpg and a 3.7L 6cyl that generates 272hp and gets 25mpg. So cutting the engine size (by peak power) by 63% only improves the fuel economy by 20%.
Note that 30 mpg is 2.0 gal/hr at 60mph. Calculating out using the energy density of gas and assuming about 30% engine efficiency yields about 30hp required at the engine to maintain 60mph. Figure at least a third of that is drivetrain loss and the power to the wheels to maintain 60mph on flat ground is about 20hp.
Nonsense. But by all means, if you have a reference, please share it.
The GM ultralite weighed 1400 lb and was a concept car, not a production ready/street legal car: http://en.wikipedia.org/wiki/General_Motors_Ultralite
According to this link: http://peakoil.com/forums/viewtopic.php?t=24763
...the GM Ultralite had a drag coefficient of .19 vs a typical car's .32. That's a difference of 40%, which translates directly into 40% more fuel efficiency. Other features, such as tires unsuitable for a mass produced car probably also factor in heavily, as does the small engine. Since it is light, it can get away with a small engine and still have decent acceleration. That would be a big factor in city fuel economy, but GM didn't publish city fuel economy. No doubt, this concept car was also not tested with air conditioning running and I wonder if it even had power steering and brakes...
Lsos said:
Are you sure?
He may be sure, but maths says no. With a rolling diameter of 24in it takes 840 rotations to travel a mile.
I acutally feel quite tight pointing out it's wrong, as I don't want to destroy the enthusiasm. But we really need to start from the basics.
It's not out of the question for a turbodiesel, 1900rpm does seem a little low for peak torque though, although if its on a restrictor then you get an artifically flat torque curve over the entire rev range.
  • #31
I think you missed my point: if 149 is peak torque, then at cruise, the engine is producing vastly less (perhaps 1/5 as much), even at that rpm.
  • #32
A gasoline engine, or diesel for that matter, will only produce its maximum torque with the throttle wide open. When you are cruising down the road your throttle is barely open you are only producing enough torque to maintain your speed - It is actually HP when you are moving because torque is a static force - horsepower is torque times the time or distance. HP = 33000 ftlbs per second.
  • #33
You mean as the engines at low load. I get you now ;)
I can see this opening a can of worms, as we've already got fairly complicated and the OP is getting lost in the basics.
  • #34
I never said i was going to cruise at peak torque, i don't have a dyno so i used the peak torque as an example for the diesel. i knew how much torque my stang was pullin at 60mph. it was roughly 700ft/t to the wheels at 1700rpm.
  • #35
i agree completely about the dark ages thing. we need to stop living in 1969, Old muscle is dead. New muscle (like that sick EV thing Chevy is producing) looks very intense.
i didnt know drag played that big of role in mpg. i was just always told in auto tech, less weight is better in every aspect. i wouldn't mind modifying my car to have a jet looking front for more mpg i think the concept would look pretty cool.
and for the Jetta vs. Golf, not a lot of ppl like hatchbacks that look like suv's. now, if they made a Golf that looked like the new Eo's er whatever it's called at an affordable price and maybe even not convertable. that would be sweet. i'd buy that over a jetta any day.
  • Mechanical Engineering
10K
24K
