Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
  • #7,981
Atomfritz said:
I think the green stuff scattered on photo is no metal. You would see the metal exposed at the breaks, but it is colored uniformly. Looks like plastic to me.
To me it looks like steel or metal with reinfoced webs, but you're probably right about it being plastic. There would indeed be exposed metal at the breaks.
As for the red stuff in the photo, I think they used a "dye bomb" or dropped some paint on the hot spot as a marker.
If I could ask a favor, in the future could you please try and limit the horizontal width of posted pics to 800 or so? Very wide pics make the rest of the page really hard to read!
  • #7,982
I read somewhere in this thread that functional groups in nuclear plants are "color coded", like the "FHM green".
But I doubt that a plastic box would be used in hot areas, for various reasons. It could just be a trash can been hit in the yard by the explosion. (just my unqualified 2 cents)
I am also curious. What could be radiating so much there?
Certainly this is not caused by a screwdriver.
So here my layman's analysis of the image and my thoughts and questions:
What could be this reddish stuff that appears to spread like pigment?
Any idea?
Edit: This stuff also could be bricks. But I doubt that bricks of apparently very low quality are used in NPPs... So I suppose this could be something other... but what?
Highly doubtful it's brick; that's a wrong red for bricks, too bluish-red, too "red" for brick.
Appears too as though whatever the red is, it got there after the pile got pushed together.
  • #7,983
This sounds very plausible, thanks!
Oooops... apologizes to all..
I really didn't think of that. *slapping myself*
  • #7,984
MiceAndMen said:
Regarding the Gamma Camera images at http://www.tepco.co.jp/en/news/110311/index-e.html
Does the fact that the Gamma Camera registers significantly on the (broken?) ventilating ducts imply that the electrically powered HVAC fans were actively circulating radioactive material before they lost electric power on 11 March?
Tepco press releases often seem a bit like their plant releases, they do nothing to clear the air.
In this case, are they simply surveying the place, or perhaps looking for a failure point or are they looking to see what equipment can be made serviceable?
If they are looking for a failure point then SGTS ducting outside of primary containment but inside the building would be a good candidate (it's my "favourite" for how hydrogen made it throughout the RB's). The SGTS's projected failure during reactor overpressure "incidents" is what prompted the Direct Torus Vent System retrofit.
However, there are the SGTS ducts, HVAC ducts and others, who knows what the ducting system is in the pictures, who knows why tepco surveyed it and who knows why they showed it to us.
There are lots of docs on the net going into GE Mark 1 BWR "issues" in depth but this one does two of the more likely failures in brief -
Page 4 of http://resosol.org/InfoNuc/seismes/Japon2011/Nucleonics Week-20110324.pdf" document has a brief section on the Brunswick plant stress test that revealed the BWR Mk1 containment dome lifting off it's seals at 70psi and also the SGTS issue as mentioned above.
  • #7,985
That green stuff may be Borotron, or similar boron-loaded plastic for neutron absorption. I see it at the accelerator labs I visit, you can get it in sheets and blocks to fabricate shielding from.
Jon
  • #7,986
Yes, this really disturbs me.
And a closer looking also makes me doubt that this is just dye.
See this zoomed-in image.
http://img153.imageshack.us/img153/5853/bricks1.jpg
This discoloration of bricks is often caused by abnormal high temperatures, like with metals.
Over-heated red pottery often discolors into crimson-bluish if it gets burnt too hot.
Another known cause of brick discoloration are chemical contaminations.
And why are these bricks (or whatever this is) in such a bad shape?
If these are hard bricks (as commonly used in modern times), such a pulverization makes me think that they originally probably have been very near the epicentre of an explosion.
Or, maybe like damaged oven/furnace bricks. Like being burst by steam expansion when heating up a wet oven.
If you look at the bricks closely, you also can find blackish-looking discolorations.
Like the soot you find when you demolish an old not-perfectly-tight chimney. You see where smoke has passed/leaked through.
In fact, these bricks look to me very similar to rotten chimney bricks, decomposed by the effects of heavily changing temperatures, humidity, condensing as boilt out, and salts and acids.
Really not the sort of things I would expect in a NPP.
To me these discolorations seem a bit too dark just to be mortar.
Could it be earth, on this sandy site?
Or, could it be precipitated black smoke?
So, what I don't understand - where came these "bricks" from?
And why do they look so odd?
Could it be possible that an opening in the reactor building has been closed by putting masonry into it?
Maybe due an open hole for some heavy equipment that had to be put with a crane into a building floor after raw construction has been finished?
Or by some modification involving closing no-longer needed openings?
If so, then this could have a series of imaginable consequences.
First, it would have been a weak point in the side walls - possibly ripping them outward instead of relieving the pressure in direction to the ceiling, resulting in the peculiar shape of RB #3?
Second, as most initial pressure then would be relieved when this "structural breaking point" opens, maybe a contaminated equipment part could have separated and blown out of the building?
And so, finally, resulting in a radiation obstacle for the pumping teams, so it just got bulldozed into the next corner?
(Sorry for my long unqualified and scientifically unfounded post. I just have a bit of construction experience, nothing nuclear.)
  • #7,987
Maybe the brick color is due to Iodine? Iodine-129 @ .84% fission yield and 15.7 million year halflife could surely still be around in quantity.
  • #7,988
  • #7,989
The PDF on this page, "May 22, 2011 Dose-measurement points by gamma camera..."
http://www.tepco.co.jp/en/nu/fukushima-np/handouts/index-e.html
is this file http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110522_01-e.pdf
The first page shows where the pictures were taken from. It looks like they drove the gamma cam bot in through the vehicle portal ("carry-in gate for large stuff") and took pictures straight ahead, and then turned right 90 deg and took some more. The electrical panel on the column with the door hanging off of it is in both pictures. The second picture, then, is from an area near the SW corner of the building with the camera pointing South, while it seems to be pointing East in the first picture.
@Atomfritz : Thank you for resizing that picture.
  • #7,990
I've no nuclear experience but have built & fired a lot of kilns, and that red substance is nothing like any brick (kiln or otherwise) I've seen. The weird blue red in overburnt bricks goes along with melting, slagging not crumbliness. Boiler bricks would be whitish to white, high duty (high temp/corrosive atmosphere) refractories don't include iron.
It is a puzzle, that largest lump does have a brickish outline, but I can't believe Tepco would have used bricks that way: Japanese knowledge/practice of ceramics is vast and ancient. "Dye bomb" or indicator powder gets my vote.
  • #7,991
Heh, remember occams razor. What would normal red bricks be doing as construction material at a nuclear powerplant? Laying bricks is not exactly easy on labor.. And that would be the only small pile of bricks we've seen on the entire site.
It's paint/dye/powder to mark the spot of high radiation.
  • #7,992
My second reply to this... I adjusted the levels a little on the second picture (the one to the south) just to enhance the contrast a bit. It's a little more complex up there than I initially thought. There seems to be a jib crane mounted on a vertical pivot that is probably used to load and unload equipment and fuel from vehicles. Other than that, it looks like a rat's nest of pipes and other things.
  • #7,993
Atomfritz said:
http://img852.imageshack.us/img852/5558/reactorstain2.jpg
(Edit 2: re-uploaded smaller sized pic, see full resolution pic here: http://imageshack.us/photo/my-images/853/reactorstain.jpg )
I like your analysis. I think the red is red marker powder.
Let me throw my $0.02 in the rubble debate, from a very different angle.
I had been looking for a way to avoid having to think of burning concrete and burning metals, because I didn't understand why such high temperatures would not also produce other observable effects. Seems I found it.
The yellow stuff is indeed insulating foam. To be more precise, it is polyurethane foam, widely used for insulation and as a fire retardant. If you are looking for an explanation for what generated massive amounts of black smoke on several occasions, this may be it. A small electrical fire in a cable duct (a la Browns Ferry) can be enough to get it going.
Diablo Canyon incidents:
http://www.nrc.gov/reading-rm/doc-collections/gen-comm/info-notices/1988/in88004s1.html
LATER EDIT: the small orange-brown pieces you ask about are also insulating foam. It gets like this from being exposed to UV light.
  • #7,994
razzz said:
Thanks for unearthing this Kyodo news.
Far greater amounts of radioactive iodine and cesium were found in rain, dust and particles in the air in some areas over a 24-hour period from Sunday morning due to rainfall, the science ministry said Monday.
http://english.kyodonews.jp/news/2011/03/80010.html
This blame-the-rain stance sort of rules out the possibility that any serious radiation was released into the air at the plant on March 20th or 21st.
I was thinking that at the very least by knowing where the hot spots are located they would know where they need to add shields to block the rays.
  • #7,995
zapperzero said:
Hey ho... when you say prism effects you mean the oddly coloured diffuse splotches in the water? What abot the two closely spaced shiny/white spots, violet on the edges, on the roof of #1 turbine hall? There's another similar one on the road in front of #4. Specular?
Concerning this particular picture that you mention:
http://www.netimago.com/image_202874.html
I remarked when i saw it first when it was released by digitalglobe that there were those very bright spots encircled with coloured lines, especially on some roofs but also around the reactors on the ground. AT first i thought that these could be some glowing parts of fuel or corium emitting a very intense light, as in digital photography, this kind of fringing appears around very bright spots in an image, in fact this comes from an overflow of photos in the adjacent pixels when the pixels receiving too much light are saturating (which is called BLOOMING).
I tried to see on all the other pictures i saw after from the plant if i could do a correspondance between these spots seen on this picture taken just after explosion of N°3 and some specific areas with remaining debris. In fact i didn't succeed in doing this: those spots didn't appear to me to be of special interest based on the later pictures.
So i don't know what to think. For sure these bright spots circled with color are surprising at first sight. On the other hand, we see in the sea area (on the same picture) that there are a lot of speculars coming from what looks to be like aluminum sheets reflecting in the sun. I don't know if there is something special on the water that makes it shining like that, or if it is just from the waves and the sun playing together (i think this second option is the good one). For sure, the picture is a little bit overexposed and the sun reflecting here and there doesn't help.
Now, even if the spots on the roofs for example are not "glowing corium" (which was not evidently) but reflections from shiny parts, we shoud find evidence of some of those parts on other pictures. I had a hard time to confirm this either... So i guess this needs maybe further look and analysis. But again maybe it's just speculars on some small shiny parts, we all know how bright this can be if just at the right angle!
Concerning the white dots in some pictures in areas with radioactivity: this is a different subject than above but to me this is clearly the effect of the radiations (gamma) on the sensor. This is very well shown in the experiment in the video posted. Some of these dots may be in fact dead pixels from a previous exposure (like in the experiment shown) or pixels reacting to some gamma rays i think.
CCDs are considered more proned to this than CMOS but CMOS are also vulnerable to this. There is a complete thesis available on this subject:
http://www.cse.yorku.ca/visor/pdf/MSc_thesis_Henok.pdf
  • #7,996
Iodine is too volatile to stay in open place for that long. Besides this is not an iodine color.
  • #7,997
Now, even if the spots on the roofs for example are not "glowing corium" but reflections from shiny parts, we should find evidence of some of those parts on other pictures. I had a hard time to confirm this either... So i guess this needs maybe further look and analysis.
Blooming on the edges, for sure. But I can't see what the mirror could have been either. I doubt anyone went on that roof to sweep away little blobs of corium though, after all, this is not as bad as Chernobyl, as they keep telling us :D
  • #7,998
Serious amount of radiation in Tokyo is serious, no matter if it's from concentration due to rain or a new massive release.
  • #7,999
Please, not a "what this pixel is" again.
Color that you see depends on the light at the place picture was taken, white balance of the camera and color temperature of your monitor (and other things). In some cases original colors are irreproducible on the screen no matter how you try, in some cases they are changed beyond recognition. So while there is some reddish tint in this place, it accurate shade is questionable.
Shapes do look "brickish" but if you desaturate the image (making it black and white) they no longer look like bricks, just like a random rubble. It is combination of shape and color that tricks you into thinking about bricks.
I like the idea of a paint bomb.
  • #8,000
Humm, i extract the part that is interesting in this last pdf (TCups may like it !):
According to Lochbaum, workers at Brunswick-2,
which also has the Mark I containment — a design by
General Electric used at units 1, 2 and 3 at Fukushima
I — performed “a structural integrity test on the reactor”
in the 1970s, in order “to satisfy a requirement in the
American Society of Mechanical Engineers (ASME) code
for prototype containment designs.”
Progress says the test is required of all containments
before reactors enter service.
He said workers pumped air into the containment
vessel to raise the pressure inside beyond the designed
maximum of 62 pounds per square inch to 71 psi, but
that the pressure stayed constant at 70 psi. “A hissing
sound attracted workers to the top of the containment
structure,” said Lochbaum. Workers discovered that the
air pushed up the metal containment head, which is
bolted to the containment wall “with a rubber O-ring
between the surfaces,” and seeped out into the refueling
cavity above the primary containment, he said.
“It is possible that the containment pressures [at
Fukushima I units] rose high enough to replicate the
Brunswick experience,” he said.
But while containment leakage in the Brunswick test prevented
the pressure inside from rising above 70 psi, Japan’s
NISA reported that pressure in the containment of unit 1
at Fukushima I had exceeded 120 psi a day after the reactor
had lost cooling. Tepco reported that the containment vessel
pressure at unit 2 had reached above 102 psi.
The interesting stuff if not only the pressure value at which it leaked (which is significantly lower than what some containments at Daichi apparently experienced) but the confirmation (as this has already been discussed) with a real world testing operation that this part of the containment (the seal of the containment cover) is clearly a weak point, making it very probable that some H2 escaped to the refueling well by this path...
There are other elements on the unresolved question of venting at Daichi (and I'm not sure it will make it clearer?):
Ventilation system
As steam accumulated and pressure rose in the containment
vessels, Tepco released some steam outside the reactor
buildings at all three units. Helwig said it is possible that
some steam mixed with hydrogen had escaped into the reactor
building during the venting.
The original Mark I design came with a so-called standby
gas treatment system, or SGTS, to vent steam under emergency
situations. Such a system first scrubs most radioactive
particles out of the steam through filters and then releases it
through the ventilation stack to the atmosphere. Fukushima
I units 1, 2 and 3 are still equipped with the SGTS system,
said a Tepco official, who requested anonymity because he is
not authorized to speak to the press.
The SGTS uses ductwork, which is susceptible to leaking
because it is not air tight and is not designed to withstand
significant pressures, to channel steam, said Helwig.
NRC in the 1980s requested that all US plants with Mark
I containments install hardened vents, replacing ductwork
with hard pipes, according to a March 19 report on the Mark
I by GE Hitachi, the company that combined the nuclear
operations of GE and Hitachi.
Borchardt told NRC commissioners that all US Mark I
reactors now have hardened vents, which he said would not
allow hydrogen to leak during venting.
Alexander Marion, vice president of nuclear operations
for NEI, said in an interview March 22 that US industry
experts assume that Fukushima I reactors do not have hardened
vents, “because somehow they were releasing hydrogen
into the secondary containment, but we just don’t know.”
The Tepco official, who answered questions through
emails, however, said the ductwork SGTS was not used at
Fukushima I for venting, “because the pressure of the containment
vessel was high.” Instead, he said, the company
used an alternative vent called the direct release line, which
can withstand high pressure, to blow off steam and cut
pressure inside the containments. “The direct vent line we
used this time is hardened pipe designed for severe accident
case,” he said.
  • #8,001
As a photographer I can attest to this. Also, both digital cameras and the systems we use to view them have a hard time with the color red.
You cannot analyze the color in a photograph unless you've taken it with very specialized equipment. We can see that it is red, but what shade is impossible to say.
  • #8,002
There are many different kinds of things which cause fringing. There are optical defects that are present in the lens, different sensor types might cause fringing (e.g Blooming, which is only present in CCD sensors).
The "fringin" on the highlights in the photo is with 99% certancy an optical effect caused by the Earth's atmosphere coupled with the extreme optics needed to get images like this from Earth orbit. There's no WAY that radiation could cause this. Also if the highlights weren't reflections of sunlight then the light source that produced them has to be as bright or brighter than the sun. And that would be kind-of noticeable on the ground.
  • #8,003
This. From the live feed. No zooming and no cropping on my part.
EDIT: also, this
  • #8,004
I agree. I was talking about the withe dots for example in this picture already posted, which are a totally different subject than the fringing in the satellite image, as i mentionned it...
http://www.netimago.com/image_202891.html
  • #8,005
interesting figures. The 500 mSv however could be misleading. The title of the map is "organ dose of I-131". Assuming they mean the organ thyroid gland, which has a weighting-factor of 0,05, the resulting effective dose would be 25 mSv.
They explicitly stated "thyroid equivalent dose", from the pdf. They have already corrected for thyroid uptake.
  • #8,006
~kujala~ said:
Hello jpquantin,
As you have calculated the loss rates of SFP 4 is it possible that the SFP 4 at some point has overflowed?
When they spray water over the SFP is there any mechanism that prevents it from overflowing except "let's stop the pumps"?
AFAIK water flows into the FPC skimmer surge tank. The highest recorded level for SFP4 skimmer level is 6600; without knowing how high can this measure go, one cannot know if water has overflowed.
SPF4 losses are quiet constants, if we trust skimmer level as indicating the pool is full when its level rises. My own calculation are (first date pool is full, second tons of water lost per day until full signal):
13/04 6:57 => 46 - 47
15/04 18:29 => 56 - 57
17/04 21:22 => 66 - 67
27/04 14:44 => 124 - 125
07/05 17:30 => 56 - 57
11/05 19:38 => 53 - 54
21/05 19:56 => 54 - 55
I've rechecked figures between 17/04 and 27/04, and still find a rate exceeding by far the constantly boiling rate (which is about 85 tons per day). It can be many things, including errors in reported sprayed volumes, water not reaching SPF ... or alien heat.
  • #8,007
EDIT: also, this
The images look just as distorted as they did 2 weeks ago. Is there something new and noteworthy there?
  • #8,009
  • #8,010
Is it possible to locate the seawater pumps of Fukushima Daiichi precisely on satellite views or on the map at http://www.tepco.co.jp/en/nu/fukushima-np/f1/images/f1-sv-20110323-e.pdf ? According to http://www.yomiuri.co.jp/dy/national/T110410003477.htm they are "near water intake outlets". According to http://www.asahi.com/english/TKY201104060126.html they were "not located within a sealed structure" and had been designed at a time prior Hitachi and Toshiba gained the experience that would lead them to locate seawater pumps "within buildings".
  • #8,011
Ok, on google maps i checked but it is very difficult to see it due to the poor resolution. On the picture below, you see on the right the four water intakes (one for each reactor, N°1 is smaller because the reactor is smaller in fact). Then if you move a little bit on the left, then you will see some spherical grey objects, aligned parallel to the intake, these are the pumps: 2 for N°1, 3 for N°2 to 4 but at N°4, because they were doing maintenance on the core, it seems they were also doing maintenance on the pumps because they seem to be removed on this picture. You can see that they are very vulnerable from tsunami standpoint (they must be close to the sea to some extent of course!) and they are also critical in order to keep the cold source working!
http://www.netimago.com/image_202942.html
I add this other satellite view, you see very well the difference between the N°1 and the others (size of intake and N° of pumps)
http://www.netimago.com/image_202943.html
I add a picture showing how they look like -these are from N°5 reactor and got hit by this big blue structure, but they look similar to the others:
http://www.netimago.com/image_202944.html
Do you see them?
Note 1 : I add this other picture showing the all 6 reactors from the sea, so you see very well the size of the various intakes and the grey pumps in the alignment:
http://www.netimago.com/image_202948.html
Note 2: At DAINI plant, which is newer, they added some buildings close to the sea but to me, these pumps are still outside, close to these buildings (the 3 aligned white/grey circles each time)
http://www.netimago.com/image_202950.html
  • #8,013
Hm? What distorsion?
EDIT: the camera was focused on unit #4 and panning left to right, then back again.
  • #8,014
jlduh said:
Do you see them?
Thank you. Thanks to your pictures, I think I could see all of them, except those for unit 4. Have they been wiped out by the tsunami, or have they already been removed for cleanup or repair ?
Their absence is conspicuous on :
Are you sure ? Looking at that picture, it is difficult to say if the blue structure is close or far enough behind.
  • #8,015
SteveElbows said:
More detailed analysis of accumulated turbine building water from march sampling finally published:
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_110522_04-e.pdf
Any comments?
Yep. Ruthenium, Strontium, Uranium and Plutonium present. That's used fuel, basically. It needs to have melted down for this stuff to be mobilized, I think.
  • Nuclear Engineering
46K
51
418K
17K
259K
14K
11K
