Can ghosts be proven to exist or not?
In summary: Sorry to double post.Yes. I was thinking about something like the commonly thought 'characteristics' of ghosts and if it could be shown that such a thing cannot exist. Characteristics such as:a. they can go through walls,b. they possesses intelligence,c. they can move things,d. they appear as 'foggy-looking' see-through-type beings,e. etc. (Not sure if I'm forgetting something...)Could it be shown that a 'being' with these characteristics cannot exist?I think it fair to say that there is no accepted scientific evidence that ghosts, as suggested, exist. Given that, we have no explanation for what "
  • #176
Why all "of" are in red. Hope it isn't the mischief of a ghost ;)
  • #177
You alone are seeing that. It is caused by the fact that you have arrived at this page by a search in which one of your keywords was "of".
  • #178
CEL said:
In reality, the phrase is "You cannot prove a universal negative."
You can prove that there are no elephants in your living room, but you cannot prove that elephants don't exist.
I agree. But what about this universal negative? All ravens are not white?
http://en.wikipedia.org/wiki/Raven_paradox
  • #179
Can you clarify how this applies? You cannot prove that there are no white ravens.
  • #180
Seems to me the Ghost Hunters TV show is all the proof you need that they don't exist.
  • #181
I don't consider it all that unlikely that consciousness can exist outside of a body. I know this point has been discussed before, but nobody has the faintest clue what consciousness is. Nobody can say that if a system fulfills criteria A, B, and C, then it is conscious; otherwise, it is not. Put another way, what specifically causes consciousness? Is it a chemical in the brain? If so, I should be able to synthesize the chemical, pour it onto a table, and make the table conscious. Is it the system of connections between neurons? If so, could I make several billion wooden blocks, connect them with string to simulate these connections, and have the blocks gain self-awareness. Is it the electrical signals that the neurons send each other? If that's the case, why isn't my computer, which also uses signals, conscious?
Whether the underlying reason for consciousness is chemical, physical, or something else entirely, it's possible that existing non-living objects fulfill the necessary and sufficient criteria for consciousness, whatever they may be, and are therefore self-aware.
  • #182
ideasrule said:
... Put another way, what specifically causes consciousness? Is it a chemical in the brain? If so, I should be able to synthesize the chemical, pour it onto a table, and make the table conscious. Is it the system of connections between neurons? If so, could I make several billion wooden blocks, connect them with string to simulate these connections, and have the blocks gain self-awareness. Is it the electrical signals that the neurons send each other? If that's the case, why isn't my computer, which also uses signals, conscious? ...
This post seems to me to be flawed on several levels. By analogy: I have a car that is traveling at 120mph. What makes it do that? Is it gasoline? If so I should be able to pour it on a table and make the table go 120mph. Is it the motor? I should be able to make pistons out of wood put them in a box on the table, pour gasoline on it and make the table go 120mph. Is it the gasoline burning? Now we are getting somewhere, all I have to do is light a match to the gasoline on the wooden box of pistons on the table and it will go 120mph. Hmmm, it still isn't moving.
  • #183
In the case of your car, the necessary & sufficient criteria for movement is a sophisticated system consisting of the engine, the gasoline, the spark plug, the transmission, the wheels, etc. However, it's clear that you can take the radio, the hood, the sunroof, and even much of the frame off without disabling the car.
The difference between a car and a brain is that it's possible, at least in principle, to spell out exactly what arrangements of components are sufficient to get a car moving. (In reality, there are in infinite number of possibilities, but we can easily figure out whether a certain one will work or not.) For a brain, nobody can come close to explaining what arrangements of chemicals can and will cause consciousness. How can we be sure that it isn't something simple, like a single chemical?
  • #184
I think what ideasrule getting at is that what causes self awareness is not understood. He's just 'throwing ideas out there'. Testing ideas to see if they work- if they don't, try something else- if they do, learn from it. Toddlers do it, as do scientists.
  • #185
I don't see the answer to this as any mystery.
Consciousness arises from the sum of all these connections.
The blocks do not gain self-awareness, but if your billion block-and-string contraption is able to gather and store input from around it, and in particular modify its own connections in constructive ways, then yes it would be conscious.
  • #186
Interesting thread. I just want to add a few things. It seems that most people here agree that consciousness is a product of natural selection. That isn't proven. Very plausible but not proven. We don't even know if language was naturally selected. The leading linguist in the world, Chomsky, actually thinks language is a spandrel. If such a high cognitive process as language can be a spandrel than just about anything can.
"Spandrel is a term used in evolutionary biology to describe a phenotypic characteristic that is a byproduct of the evolution of some other character, rather than a direct product of adaptive selection. The term was coined by the Harvard paleontologist Stephen Jay Gould and population geneticist Richard Lewontin in their influential paper "The Spandrels of San Marco and the Panglossian Paradigm: A Critique of the Adaptationist Programme" (1979). In this paper Gould and Lewontin employed the analogy of spandrels in Renaissance architecture: curved areas of masonry between arches supporting a dome that arise as a consequence of decisions about the shape of the arches and the base of the dome, rather than being designed for the artistic purposes for which they were often employed."
Could it be a saltation?"In biology, saltation (from Latin, saltus, "leap") is a sudden change from one generation to the next, that is large, or very large, in comparison with the usual variation of an organism. The term is used for occasionally hypothesized, nongradual changes (especially single-step speciation) that are atypical of, or violate, standard concepts - gradualism - involved in neo-Darwinian evolution."
I read something interesting by a neuroscientist who first proved lucid dreaming. He written extensively on near death experiences and out of body experiences. Both of which he says are totally explained by biology and are hallucinations and not supernatural. So he knows a thing or two about the tricks the mind and body can play. He was asked if his work had given him any insight into the afterlife:
"DJB: What do you think happens after biological death and has your experience with lucid dreaming influenced your thoughts in this area and about the nature of God?
Stephen: Let’s suppose I’m having a lucid dream. The first thing I think is, "Oh this is a dream, here I am." Now the "I" here is who I think Stephen is. Now what’s happening in fact is that Stephen is asleep in bed somewhere, not in this world at all, and he’s having a dream that he’s in this room talking to you. With a little bit of lucidity I’d say, "this is a dream, and you’re all in my dream." A little more lucidity and I’d know you’re a dream figure and this is a dream-table, and this must be a dream-shirt and a dream-watch and what’s this? It’s got to be a dream-hand and well, so what’s this? It’s a dream-Stephen! So a moment ago I thought this is who I am and now I know that it’s just a mental model of who I am. So reasoning along those lines, I thought, I’d like to have a sense of what my deepest identity is, what’s my highest potential, which level is the realest in a sense? With that in mind at the beginning of a lucid dream, I was driving in my sports car down through the green, Spring countryside. I see an attractive hitchhiker at the side of the road, thought of picking her up but said, "No, I’ve already had that dream, I want this to be a representation of my highest potential. So the moment I had that thought and decided to forgo the immediate pleasure, the car started to fly into the air and the car disappeared and my body, also. There were symbols of traditional religions in the clouds, the Star of David and the cross and the steeple and near-eastern symbols. As I passed through that realm, higher beyond the clouds, I entered into a vast emptiness of space that was infinite and it was filled with potential and love. And the feeling I had was-- this is home! This is where I’m from and I’d forgotten that it was here. I was overwhelmed with joy about the fact that this source of being was immediately present, that it was always here, and I had not been seeing it because of what was in my way. So I started singing for joy with a voice that spanned three or four octaves and resonated with the cosmos with words like, "I Praise Thee, O Lord!" There wasn’t any I, there was no thee, no Lord, no duality somehow but sort of, ‘Praise Be’ was the feeling of it. My belief is that the experience I had of this void, that’s what you get if you take away the brain. When I thought about the meaning of that, I recognized that the deepest identity I had there was the source of being, the all and nothing that was here right now, that was what I was too, in addition to being Stephen. So the analogy that I use for understanding this is that we have these separate snowflake identities. Every snowflake is different in the same sense that each one of us is, in fact, distinct. So here is death, and here’s the snowflake and we’re falling into the infinite ocean. So what do we fear? We fear that we’re going to lose our identity, we’ll be melted, dissolved in that ocean and we’ll be gone; but what may happen is that the snowflake hits the ocean and feels an infinite expansion of identity and realizes, what I was in essence, was water! So we’re each one of these little frozen droplets and we feel only our individuality, but not our substance, but our essential substance is common to everything in that sense, so now God is the ocean. So we’re each a little droplet of that ocean, identifying only with the form of the droplet and not with the majesty and the unity."
  • #187
instead of chopping up someones elses post why don't you try making an intellegent one to to argus his
  • #188
I would like to read your post but it is one giant block of text. No paragraphs to break up your thoughts.
  • #189
Sorry, but that's exactly how it was transcribed in the interview. He's kind of saying that God is all of us united. Not just humans. But everything. We return to what we really are at death.
He is the guy who first proved lucid dreaming. That block of text is his answer to to the question about whether his lucid dreams gave him any insight into biological death and the afterlife. Basically it is his opinion on what happens at biological death.
He explains how he can make his dreams more lucid, more real, at will. So what is his identity in the realest sense? What is the truest model?
  • #190
If that neuroscientist Stephen felt this independently without the influence of any book or philosophy, then i'll be damned. This is precisely what Advaita Vedanta says though using different terminology. Advaita itself means A-Dvaita, Not two. Just one. The snow flakes of stephen is named "Atman" here and the Infinite Ocean as "Brahman". The explanation is exactly the same.
http://en.wikipedia.org/wiki/Ātman_(Hinduism)
But i am not fully convinced by this Advaita-snowflake philosophy though i hope it's true.. Still too immature to accept mortality. :smile:
  • #191
"Proved"?
  • #192
DaveC426913 said:
"Proved"?
His technique of signalling to a collaborator monitoring his EEG with agreed-upon eye movements during REM became the first published, scientifically-verified signal from a dreamer's mind to the outside world.
Verified, I guess.
  • #193
spacetype said:
How could one go about proving that ghosts do not exist?
Apply standard scientific method:
1. Null hypothesis: Ghosts do exist
2. Seek confirming evidence of the null hypothesis using controlled methods
3. If or when no null confirming evidence is found within an environment controlled to some epsilon, determine the statistical degree to which the null is rejected.
  • #194
For me his experience is explained by Jill Taylor's My Stroke of Insight. A burst AVM incapacitated most of her language capabilities and some other important left hemisphere functions which left her living in a nearly total right hemisphere world: a world of bliss and euphoria for the most part. Ego and identity are sustained by talking to ourselves about ourselves and when a person can't do that they default to an unworried existence where they can't well distinguish between themselves and the environment, nor things in the environment from each other: all is one.
At the time of writing she assessed herself as 100% recovered, but not the same person, having little incentive to revert to certain kinds of gratuitous and counterproductive worrying, and, despite being a neuroscientist, she now has a distinctly mystical proclivity in her thinking.
Anyway, the thing he experienced in his lucid dream was not what physical death represents, in my opinion, but death of the "ego".
Reading her book caused me to speculate whether autism might not represent the opposite deficit: some degree of right hemisphere malfunction that prevents the person from experiencing an automatic feeling of connectedness to other people and their environment. (Or it could be a left hemisphere deficit that renders the left hemisphere unable to process signals from the right.) In any event, her story has volumes of intriguing first hand reports about right hemisphere function.
  • #195
But this man consciously brought this state onto himself. He did it through a linear thought process. It was controlled. He said it represented his deepest indentity. And his deepest indentity is not physical. He has done extensive work on NDE and OBEs. All of which he thinks arent supernatural and totally explained by biology. So he knows a thing or two about the mind and the tricks it plays.
Ego is an interesting suggestion. I don't see ego as a very descriptive or useful term in general though. But it could apply here. Are you talking about it in the Freudian fashion? What is the ego? Almost seems like a suitcase term. So the ego is one model of us. Like the model that we usually see as represntative of ourself. It was the ego driving the car in the dream, about to pick up a pretty hitchhiker. But then he says, let's go beyond the ego. Let's go beyond the model that I think I am. Let's explore more. This is similar to religious/psychological experiences, you are right. You learn you are more than what you think you are. Like the old Jung quote, "Who looks outside, dreams. Who looks inside, awakens." Getting beyond the ego is the awakening. Or at least realizing it is not the only part of you. Maybe death could even be the shedding of the ego.
He also brings up some other interesting points about mind and dreaming.
RMN: There seems to be a correlation between psychedelic consciousness and lucid consciousness in the dream state.
Stephen: There’s a lot in common between the two states. In fact people can in the dream state, take a dream "psychedelic" and have it produce an effect.
DJB: Terence McKenna says that he smokes DMT in his dreams and then has the full experience.
Stephen: And what that shows is that what prevents us from having these experiences is not the chemical, it’s the mental framework. So in a way psychedelics can be a kind of guide in revealing some of the potential in the mind. I think they have limitations in terms of taking us to the visions they show us. One can take the mistaken path of saying, well since I had the taste of it with the substance, if I keep taking it I’ll eventually get the whole thing because more of the same should help. It doesn’t seem to work that way.
I have seen that video of Taylor on TED and I liked it.
  • #196
One thing I was thinking of including in my post was to point out that procedures for silencing the interior monolog are at the heart of every mystical religion. Jill Taylor had this forced on her by a freak stroke. It can certainly be achieved by voluntary practice to varying degrees. Voluntarily quieting the interior monolog is just about instantaneously reversable and it's quite frequent for periods of inner silence to be interrupted by verbal comments to ourselves. He got into this state by linear procedure, but not by thinking himself into it.
This is a left brain verbalization of a non-verbal right hemisphere experience intended to try and communicate something about that awesome experience to other people's left hemisphere's. It's one choice of words among a multitude of possible characterizations of that state: cosmic consciousness, Big Mind, Buddha Mind, Nirvana, and so on. A zen Buddhist would say all verbal descriptions are wrong, no matter how accurate, because the description is not the experience.
He said "My belief is that the experience I had of this void, that’s what you get if you take away the brain." I'm saying that Jill Taylor's experience demonstrates this experience is what you get when you take away, not the whole brain, just the left hemisphere.
I just meant it in the everyday sense of the word.
I haven't seen a video of her, but I'd recommend her book as almost certainly more comprehensive due to the inherent time constraints of a video.
  • #197
I was thinking the same thing. Especially about eastern religion. Finding oneself. This is again what Jung talked about. Religion/faith is often the best defense against a religious experience. A religious experience like both of these neuroscientists had. Traditional religion puts up a wall to that experience. Religion is a fear of inner experience. A guardian of it. The guard gives you a generic one in its place. So it really isn't your inner experience, but one imposed on you. With religion, you can never really know who you are. You have to take te journey by yourself.
The hope for Jung lies in true religion. The freedom and autonomy of the individual depends on deep inner experience of a metaphysical nature. This is not "faith"; it is direct knowing.
But the dreamer was thinking his way into it. That was the exercise.
I'm not sure both neuroscientists had the same experience but they certainly sound very similar. And I think he did think his way into it. He made choices that he thought would make him end up in this kind of state. He can "tune" his lucidity. It is a progression from less real to more real. Like he says about entering that nirvana state:
He can think out steps to make things realer. And he thinks he got to the realest. Who knows though? I am not saying what he is saying is real or correct. There could be nothing after or death, or there could be something. There is no good reason to believe in an afterlife or ghosts from a scientific perspective at this time obviously.
  • #198
He's certainly intending to convey the fact he was consciously controlling it, but I wouldn't take his saying "So then I thought..." too literally. He's narrating to a second party after the fact. I take him to be translating what were experienced as non-verbal impulses and expressions of will into verbal form.
  • #199
i for one want to prove they do exist that means there's something after all this i figure if i ever see a ghost i won't be scared because if it does kill me then there's something I am going to :) rationalize it that way and you will never be scared of ghosts again trust me also the elevator in my apartments will sometimes open RIGHT BEFORE you go to push the button with no one inside has happened enough times that i don't think its a coincidence like RIGHT before you push it its strange my brothers reported the same thing
  • General Discussion
18K
