The space between a unit 'sphere' in n dimensions within an n-dimensional cube
In summary, the pattern of the distance between the corners and the origin in an n-dimensional cube continues for n greater than 3, with the distance being n^(1/2). This can be proven using the Pythagorean theorem and induction. However, in an infinite-dimensional space, the concept of volume is not well-defined and the unit sphere behaves like a point. There are various ways to make this space complete, but they all have their own limitations. Therefore, the concept of volume and area has no existence beyond their basic definitions.
prane
23
If we have a unit circle within a square s.t. the square touches the circle in 4 places then the biggest gap we can find is just √2 - 1.
Doing a similar thing with a sphere in a cube we get √3 - 1
I've heard the n-dimensional analogue is √n - 1. Which is crazy as it means the gap is bigger than the radius of the sphere! (When n is greater than 4).
Anyway, how is such a thing proven?
pythagoras?
Yeh the result can be proven by Pythagorus in 2 and 3 dimensions but what about n?
induction?
Higher-dimensional spheres have some surprising properties. The (hyper-) volume and (hyper-) surface area of a unit sphere increase for a while as the dimension goes up, but they reach their maximum values pretty soon, then decrease forever after that.
Consider an n-dimensional "cube" that just contains the n-dimensional sphere of radius 1: the midpoints of the sides of the cube are at distance 1 from the origin, but as you noted, the corners are farther away. For n=2 we have a square, whose corners are at distance [itex]\sqrt2[/itex] from the origin, and when n=3, we have an ordinary cube whose corners are at distance [itex]\sqrt3[/itex]. This pattern continues; when n=4, the distance is 2, when n=9 the distance is 3, when n=100 the distance is 10, and so on. Obviously there's no limit to how far away those corners get as the dimension becomes very large. But since every point on the sphere, of any dimension, is at distance 1 exactly, you can see why the sphere takes up less and less of the cube as the dimension increases.
My question though is, how do we know that this pattern continues for n greater than 3? If it's just defined to be that then I can kind of see why but is there any 'proof'? This result surely cannot be proven by induction?
the face of an n cube is an n-1 cube. The diagonal of an n cube thus is the hypotenuse of a right triangle whose other two legs are: 1) an edge of the n cube, 2) a diagonal of a face, i.e. a diagonal of an n-1 cube.
thus usual pythagoras supplies the inductive step to prove the diagonal of an n cube of edge length one, has length sqrt(n) = sqrt{1^2 + sqrt(n-1)^2}.
what about the ∞-dimensional case...?
In such a case the volume of the gap between the ∞-dimensional unit sphere and the ∞-dimensional unit cube is +∞.
Moreover the ratio of the volumes of the unit sphere and unit cube is given by [tex]\lim_{n\to +\infty} \frac{\pi^{n/2}}{2^n \Gamma(1+n/2)}[/tex]
and in this case the above quantity tends to 0.
Shall we conclude that in a ∞-dimensional space the unit-sphere behaves likes a point ?
No, you should conclude that volume in an infinite-dimensional space is not a well-defined concept. Furthermore, there are multiple kinds of infinite-dimensional spaces.
micromass;4027511} said:
[...] Furthermore, there are multiple kinds of infinite-dimensional spaces.
Could you just make an example on how to make an ∞-dimensional space out of ℝn that would not be the trivial method of "increasing the number of dimensions" up to infinity?
I'm not sure what you mean with with "make an infinite-dimensional space out of [itex]\mathbb{R}^n[/itex]".
But anyway, the easiest infinite-dimensional space to work with is probably the set of all sequence [itex](x_n)_n[/itex] which are eventually 0. So an example of an element in that set is (2,5,2,3,0,0,0,0,0,...).
But this is not a very interesting infinite-dimensional space because it has quite some deficiencies. One such deficiency is that it is not "complete". This means that it has gaps (just like [itex]\mathbb{Q}[/itex] has gaps compared to [itex]\mathbb{R}[/itex]).
There are various ways to make this space complete, and all these ways are useful in some way.
Proof of what? You seem to think that these concepts of "volume" and "area" have some kind of existence beyond the basic definitions. That's not true (not even for two and three dimensions).
1. What is the space between a unit 'sphere' in n dimensions within an n-dimensional cube?
The space between a unit 'sphere' in n dimensions within an n-dimensional cube refers to the distance or gap between the surface of the unit sphere and the edges or corners of the n-dimensional cube. This concept is often used in mathematics and physics to calculate volumes and probabilities.
2. How is the space between a unit 'sphere' in n dimensions within an n-dimensional cube calculated?
The space between a unit 'sphere' in n dimensions within an n-dimensional cube can be calculated using the formula: (2n - 1) / (n + 1), where n is the number of dimensions. This formula takes into account the number of dimensions and the radius of the unit sphere.
3. Does the space between a unit 'sphere' in n dimensions within an n-dimensional cube change with different values of n?
Yes, the space between a unit 'sphere' in n dimensions within an n-dimensional cube changes with different values of n. As the number of dimensions increases, the space between the unit sphere and the edges or corners of the cube also increases.
4. What is the significance of the space between a unit 'sphere' in n dimensions within an n-dimensional cube?
The space between a unit 'sphere' in n dimensions within an n-dimensional cube has various applications in mathematics and physics. It is used to calculate volumes, surface areas, and probabilities in higher dimensions. It also helps in visualizing and understanding higher dimensional spaces.
5. Are there any real-world examples of the space between a unit 'sphere' in n dimensions within an n-dimensional cube?
Yes, there are many real-world examples of the space between a unit 'sphere' in n dimensions within an n-dimensional cube. One example is in probability, where the space between the unit sphere and the cube can be used to calculate the likelihood of events occurring in higher dimensions. Another example is in computer graphics, where this concept is used to create 3D models and animations.
  • General Math
  • Science Fiction and Fantasy Media
  • Quantum Physics
  • New Member Introductions
  • Quantum Physics
