What is the Dot Product of Two 2x2 Matrices?
In summary, the conversation is about the concept of a basis set of images (matrices) being orthonormal, as explained by the teacher in an image processing class. The dot product between two basis images is discussed, with an example given using two 2x2 matrices. The discussion also touches on the difference between the dot product and the matrix product, and how to compute the dot product for matrices.
Owen-
40
This seems like a very basic question that I should know the answer to, but in my image processing class, my teacher explained that a basis set of images(matrices) are orthonormal.
He said that the DOT product between two basis images (in this case two 2x2 matrices) is 0. so, for example
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
=0
\end{equation}
I don't understand how this can be. I always thought it gave another matrix, and not a direct value:
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
\begin{bmatrix}
ae+bg & af+bh\\
ce+dg & cf+dh
\end{bmatrix}
\end{equation}
Can someone help me out? It would be unbelieveably helpful,
Thanks!
Owen.
Mathematics news on Phys.org
The only possibility I can think of is to take a 2x2 matrix and write it out in the form ##a e_{11} + b e_{12} + c e_{21} + d e_{22}##, ie as a four dimensional vector space. Then the e's form an orthonormal basis.
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
\begin{bmatrix}
ae+bg & af+bh\\
ce+dg & cf+dh
\end{bmatrix}
\end{equation}
Thanks!
Owen.
That's the matrix product, not the dot product. A dot product (inner product) is a scalar. Always. For matrices, the typical definition of the dot product is the Frobenius inner product. Simply compute as if the matrix was a vector. For real matrices,
\begin{equation}
A\cdot B \equiv \sum_i \sum_j A_{ij} B_{ij}
\end{equation}
For your pair of 2x2 matrices,
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
= ae + bf + cg + dh\end{equation}
Perfect thanks a lot!
The dot product of two 2x2 matrices is a mathematical operation that results in a scalar value, not a matrix. It is also known as the inner product or scalar product. The formula for the dot product of two matrices is the sum of the products of their corresponding elements. In other words, the dot product of two matrices A and B is given by:
\begin{equation}
A \cdot B = \sum_{i=1}^{n} \sum_{j=1}^{m} a_{ij}b_{ij}
\end{equation}
In your example, the dot product of the two 2x2 matrices would be:
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
= a \cdot e + b \cdot f + c \cdot g + d \cdot h
\end{equation}
It is important to note that the dot product of two matrices is only defined when the number of columns in the first matrix is equal to the number of rows in the second matrix. This is why your teacher mentioned that the basis images (matrices) are orthonormal, meaning they are perpendicular to each other and have a length of 1. In this case, the dot product of any two basis images (matrices) would always be 0, as the sum of their corresponding elements would always be 0. This is a useful property in image processing as it allows for efficient and accurate calculations. I hope this helps clarify the concept of the dot product of two 2x2 matrices.
1. What is a dot product for a 2x2 matrix?
The dot product for a 2x2 matrix is a mathematical operation that takes two matrices of the same size and multiplies corresponding elements in each matrix. It then adds up the products, resulting in a single number.
2. How do you calculate a dot product for a 2x2 matrix?
To calculate a dot product for a 2x2 matrix, you first need to multiply the corresponding elements in each matrix. Then, add up the products to get a single number. For example, if we have matrices A = [a b] and B = [c d], the dot product would be calculated as (a*c) + (b*d).
3. What is the purpose of calculating a dot product for a 2x2 matrix?
The dot product for a 2x2 matrix is used to find the angle between two vectors in a two-dimensional space. It is also used in linear algebra to solve systems of equations and find projections of one vector onto another.
4. Can a dot product for a 2x2 matrix be negative?
Yes, a dot product for a 2x2 matrix can be negative. The result of a dot product depends on the values of the matrices being multiplied, so it is possible for the product to be negative if the elements have opposite signs.
5. Is the dot product for a 2x2 matrix commutative?
No, the dot product for a 2x2 matrix is not commutative. This means that the order in which the matrices are multiplied matters. In other words, A*B is not necessarily equal to B*A.
  • Linear and Abstract Algebra
  • Differential Equations
  • General Math
  • General Math
