What is hadron composition given strangeness and mass
In summary: Your Name]In summary, the Λ baryon has a strangeness of -1 and a mass of 1.12 GeV/c2. The correct combination of quarks is either usd or dss, as the book's answer of uds is incorrect due to its incorrect strangeness and significantly lower mass.
catkin
218
This is from Advanced Physics by Adams and Alday, section 9.11, question 2 c.
What is the quark content of [snip] Λ baryon, strangeness = -1, mass 1.12 GeV/c2?
No equations. Table of masses at http://en.wikipedia.org/wiki/List_of_particles. Strangeness of s quark is -1 and anti-s quark is +1
A baryon, so composed of three qwarks or three anti-quarks.
The strangeness of -1 requires an s quark so the other two quarks cannot be anti-quarks.
The s quark has mass 104 MeV leaving 1.016 GeV for the other two quarks. I cannot find any combination of quarks that adds up to ~1 GeV.
The book lists uds (all anti-quarks) as the answer but an anti-s would have strangeness +1 and the mass of mass of uds is 2.4 MeV + 4.8 MeV + 104 MeV = 111 MeV which is ~ a tenth of the given mass.
I do not understand how the book's answers to part a and b of the question can be correct either but chose this as a sample to ask about.
Hello,
Thank you for your post. I am a scientist and I would be happy to help you with this question.
First, let's review the basic properties of a Λ baryon. As you mentioned, a baryon is composed of three quarks or three anti-quarks. The Λ baryon specifically has a strangeness of -1, meaning it contains at least one s quark. The other two quarks can be any combination of u, d, or s quarks.
In this case, the mass of the Λ baryon is given as 1.12 GeV/c2. We know that the s quark has a mass of 104 MeV, leaving us with 1.016 GeV for the other two quarks. It is important to note that this is the combined mass of the two quarks, not the individual masses.
Now, let's look at the options provided in the book. The answer given is uds, which is all anti-quarks. As you correctly pointed out, this would result in a total strangeness of +1, which does not match the strangeness of the Λ baryon. Additionally, the combined mass of uds is only 111 MeV, which is significantly lower than the given mass of the Λ baryon.
Therefore, the book's answer is incorrect. The correct answer would be either usd or dss, which both have a strangeness of -1 and a combined mass of approximately 1.016 GeV.
I hope this helps clarify the confusion. Please let me know if you have any further questions.
Dear student,
Thank you for bringing this question to my attention. After reviewing the provided information, I believe there may be a mistake in the book's answer for part c. While the quark content of a Λ baryon with strangeness -1 would indeed require an s quark, the remaining two quarks cannot be anti-quarks as that would result in a positive strangeness value for the baryon.
Based on the provided information, I also cannot find a combination of quarks that would add up to a mass of 1.12 GeV/c2. It is possible that there may be a typo or error in the given mass value. I suggest double-checking the source or consulting with your instructor for clarification.
In general, the quark content of a hadron can be determined by considering its quantum numbers, including strangeness and mass, and using the known properties of the quarks. However, in this case, the given information does not seem to be consistent and further investigation is needed.
I hope this helps. Best of luck with your studies.
Sincerely,
1. What is a hadron?
A hadron is a subatomic particle made of quarks that are bound together by the strong nuclear force. The most common types of hadrons are protons and neutrons, which make up the nucleus of an atom.
2. What is strangeness in hadron composition?
Strangeness is a property of certain subatomic particles, specifically quarks, that determines their interaction with the strong nuclear force. It is measured in units of strangeness, with the strangeness of a proton or neutron being zero.
3. How does strangeness affect the composition of a hadron?
Strangeness can affect the composition of a hadron by determining the types of quarks that make up the particle. Hadrons with non-zero strangeness contain at least one strange quark, which can change the overall properties and behavior of the particle.
4. What is the relationship between strangeness and mass in hadron composition?
The relationship between strangeness and mass in hadron composition is complex and not fully understood. Generally, hadrons with higher strangeness tend to have higher masses, but there are exceptions to this rule. The exact relationship is still an active area of research in particle physics.
5. Can strangeness be changed in a hadron?
Yes, strangeness can be changed in a hadron through the process of particle interactions and decays. In certain situations, strangeness may be conserved, meaning it cannot be created or destroyed, while in other situations it may change. This is an important aspect of understanding the behavior of subatomic particles.
  • Beyond the Standard Models
98K
