Help with understanding dual nature of electron.
In summary, the dual nature of electrons refers to their ability to behave as both particles and waves. This concept is explained through the use of quantum numbers, sub-shells, and orbitals. While there are diagrams and explanations available to help visualize these concepts, it is important to understand that particles do not have trajectories and their behavior is governed by probability amplitudes rather than classical probabilities. This is demonstrated through the use of the path integral and the time-dependent Schrodinger equation. However, it should be noted that the wave-like behavior of particles is not a property of the particle itself, but rather a property of its probability amplitude.
PrincePhoenix
Hello,
I had read about the dual nature of electrons and the quantum numbers for some time ago and was always confused.
1-What does dual nature of electron mean? Does it mean that the electron moves in a sort of wave like motion around the nucleus? Where do the sub-shells and orbitals fit in?
2-Is there any diagram or simple explanation that shows where in the shells the sub-shells (s,p,d,f) exist and then the orbitals?
Thanks in advance.
Hello PrincePhoenix! :smile:
Almost … it means that the electron is a sort of wave around the nucleus. :wink:
They're like the individual frequencies or resonances in, say, the wave for the noise from a church bell. :smile:
A quick google image-search shows http://www.chemistry.nmsu.edu/studntres/chem111/resources/notes/atomic_orbitals.html" …
if you search for longer you may find some better ones. :wink:
You mean something like this. (I'm not good at graphics but this is roughly what I mean)
[PLAIN]http://princephoenix.webs.com/untitled.bmp
I've seen those in my textbooks. I mean a diagram that shows them in perspective with the nucleus and the general structure of the atom.
No, that's one-dimensional, I was thinking of a 3D wave.
Okay a three-dimensional, but is it just its path of motion? I can't visualize it as a particle and a wave any other way.
What about the second request?
Particles have paths. Waves just are.
No idea. :redface:
Thank you :smile:
Is this accurate?
Looks about right …
are those the 95% probability limits?​
It might help to think of the Quantum Nature of particles according to the following points:
  • The particles are NOT waves. They are truly point particles. During ionization of atoms, no one has ever obsereved, for example, half an electron to emerge. It is always an integer multiple of electrons;
  • You cannot know both the position and the velocity of the particle at a given instant in time. As such, the concept of trajectory is meaningless in Quantum Mechanics. There is only a probability law that tells us the probabilities of finding the particle at a particular point at later times provided that it was known to be at some position at a previous fixed instant in time;
  • This probability is given by the square of the absolute value of a complex quantity called transition amplitude. It is this quantity that plays the fundamental role in the dynamics of quantum objects, like electrons, for example. Namely, according to the laws of conditional probability, if we know the conditional probability that the particle will go from A to some intermediate point C and then from C to B, then the conditional probability for the particle to go from A to B is given by the sum:
    [tex]
    P(A \rightarrow B) = \sum_{C}{P(A \rightarrow C) P(C \rightarrow B)}
    [/tex]
    where the sum goes over all possible intermediate positions. However, this rule does NOT hold for probabilities, but for probability amplitudes in Quantum Mechanics:
    [tex]
    T(A \rightarrow B) = \sum_{C}{T(A \rightarrow C) T(C \rightarrow B)}
    [/tex]
    and the probability is given by:
    [tex]
    P(A \rightarrow B) = |T(A \rightarrow B)|^{2}
    [/tex]
  • It is easy to see that there is nothing special about one intermediate state in the above sum and the same law holds if we insert an arbitrary number of intermediate states. Specifically, if this number tends to an uncountable infinity, we go from an infinite number of infinite sums to a so called path integral. The transition amplitude from point with position vector [itex]\mathbf{x}'[/itex] at time [itex]t'[/itex] to a point with position vector [itex]\mathbf{x}[/itex] at time [itex]t[/itex] is denoted by [itex]K(\mathbf{x}, t; \mathbf{x}', t')[/itex] and it may be shown that is given by:
    [tex]
    K(\mathbf{x}, t; \mathbf{x}', t') = \int{D\mathbf{x}(t) \, \exp\left[\frac{i}{\hbar} \, S(t, t')[\mathbf{x}(t)] \right]}
    [/tex]
    where:
    [tex]
    S(t, t')[\mathbf{x}(t)] = \int_{t'}^{t}{L(\tilde{t}, x(\tilde{t}), \dot{\mathbf{x}}(\tilde{t})) \, d\tilde{t}}
    [/tex]
    is the action of the particle with a Lagrangian [itex]L(t, \mathbf{x}, \dot{\mathbf{x}}[/itex];
  • If the Lagrangian is given by:
    [tex]
    L = \frac{m \dot{\mathbf{x}}^{2}}{2} - V(\mathbf{x}, t)
    [/tex]
    then one can proove that the transition amplitude satisfies the following PDE:
    [tex]
    i \hbar \frac{\partial K(\mathbf{x}, t; \mathbf{x}', t')}{\partial t} = -\frac{\hbar^{2}}{2 m} \nabla^{2}_{\mathbf{x}} K(\mathbf{x}, t; \mathbf{x}', t') + V(\mathbf{x}, t) K(\mathbf{x}, t; \mathbf{x}', t'), \; t > t'
    [/tex]
    with the initial condition:
    [tex]
    K(\mathbf{x}, t; \mathbf{x}', t) = \delta(\mathbf{x} - \mathbf{x}')
    [/tex]
    The last partial differential equation is known as the time-dependent Schrodinger equation, but now it holds for the propagator of the particle. Since in classical mechanics only phenomena associated with the propagation of waves obey such types of partial differential equations, one might be tempted to interpret the propagation of the wave associated with the probability amplitude of the particle as the property of the particle itself. This, however, is not strictly true.
Feynman on Wave Particle Duality
One often talks about the wave-particle duality of the electron meaning: in some experiments the electron behaves like a wave and in others like a particle.
1) http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/davger2.html#c1"
You shoot electrons at a crystal and observe an interference pattern. The pattern can be explained if you assume that the electron has a wavelength.
2) http://www.hitachi.com/rd/research/em/doubleslit.html" )
You observe dots on the screen (particles) but the pattern looks as if produced by wave interference.
http://www.perimeterinstitute.ca/Perimeter_Explorations/Quantum_Reality/Chapter_2_-_Wave-Particle_Duality_with_Electrons/" (Perimeter Institute for Theoretical Physics)
The video can be viewed http://www.perimeterinstitute.ca/en/Perimeter_Explorations/Quantum_Reality/Suggested_Ways_to_Use_this_Package/" I recommend the Quicktime video. The first half of the video deals with the electron double slit, the second half with photon double slit, molecule interference, different interpretations (pilot wave theory, Many Worlds, Copenhagen) and applications of quantum mechanics (for example quantum cryptography).
Thanks to everyone for their help. :smile:
1. What is the dual nature of an electron?
The dual nature of an electron refers to the fact that it exhibits both particle-like and wave-like behavior. This means that it can behave like a tiny particle with a definite position and momentum, but it can also exhibit wave-like properties such as diffraction and interference.
2. How was the dual nature of an electron discovered?
The dual nature of an electron was first proposed by French physicist Louis de Broglie in the early 1920s, based on his theory of wave-particle duality. This was later confirmed by experiments such as the famous double-slit experiment conducted by Thomas Young and the diffraction experiments performed by Clinton Davisson and Lester Germer.
3. What are the implications of the dual nature of an electron?
The dual nature of an electron has major implications in the field of quantum mechanics, as it challenges our classical understanding of particles and waves. It also helps explain phenomena such as quantum tunneling and the uncertainty principle, and has led to the development of technologies such as electron microscopy and electron diffraction.
4. Can the dual nature of an electron be observed?
Yes, the dual nature of an electron can be observed through various experiments, such as the aforementioned double-slit and diffraction experiments. It can also be observed in everyday technologies, such as the cathode ray tube in old televisions and computer monitors.
5. How does the dual nature of an electron impact our understanding of matter?
The dual nature of an electron is just one aspect of the broader concept of wave-particle duality, which applies to all subatomic particles. It has significantly impacted our understanding of matter by showing that particles can also exhibit wave-like behavior, and that the behavior of particles is inherently probabilistic rather than deterministic. This has revolutionized our understanding of the fundamental building blocks of the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
