- #1
~christina~
- 0
[SOLVED] 2 Thermodynamic questions
1.
a) Determine the work done on a fluid that expands from i to f as indicated in picture below.
b) How much work is performed on the fluid if it is compressed from f to i along the same path?
http://img340.imageshack.us/img340/6344/82457490fq4.jpg [Broken]
2. An ideal gas initially at Pi, Vi and Ti is taken through a cycle as shown.
a) find the net work done on the gas per cycle
b) What is the net energy added by heat to the system per cyle
c) Obtain a numerical value for the net work done per cycle for 1.00 mol of gas initially at 0C
[tex]\Delta E_{int}= Q+ W [/tex]
1.
a)Determine the work done on a fluid
I thought that work was the area under the curve...but acording to my book for constant pressure.. I think it is
[tex]P_i(V_f-V_i) [/tex]
Now I'm thinking that If I find the are under the curve then it would be=>
(4-1m^3)(2x10^6Pa)+ (2-1m^3)(6x10^6-2x10^6)+ 1/2(3-2m^3)(6x10^6-2x10^6)=
(6x10^6)+(4x10^6)+ (2x10^6)= 1.2x10^7 J
here I'm not sure what they want, when they say that the fluid is compressed along the same path. I assume that would mean that the pressure changes? But how would that look on the graph? Am I supposed to draw a new graph?
_________________________________________________________________________
2.
a) net work done on the gas per cycle
I would say work done is = area of the cyclic cycle thus:
(3Pi-Pi)(3Vi-Vi)= 4J
if it is cyclic I think that the net energy added by heat would be =
Q= -W because the [tex]E_{int}= 0[/tex] thus would it would be -4J ?
Not sure how I would do this if they say that there is 1.00mol of gas at 0C.
I know that [tex]Q=nc\Delta T[/tex] but if you don't have the final temp then how do you do the question, and also if you don't have c?
I need help on kowing whether I'm correct or not and need help on parts c for #2 and also on part b) of #1.
Please help me out.
Thank you.
2.
Please help me out.
Thank you.
