Exploring the Energy and Absorption Spectrum of Free Particles in Plasmas
In summary, the conversation discusses the concept of quantization of energy in free particles and how it applies to molecules, particularly water molecules. The conversation also explores the idea of translational absorption and its role in spectroscopy. The participants also touch on the Born-Oppenheimer approximation and the process of scattering.
altered-gravity
62
Hi, this is a silly question
Energy of a free particle is not quantized. Does it mean that it should have a continuous absorption spectrum?. When a cloud of free electrons in some type of plasmas is irradiated with light, theese "hot electrons" are accelerated as they absorb light.
So, imagine water. We want to measure the IR spectrum of water, but instead of doing it in solution or in gas phase, we do it in a molecular beam (without collisions and interaccions), supposing that water molecules in the beam are completely free and cold would they absorb radiation in all the wavelengths, increasing the energy in traslation degrees?
It´s obvious I´m wrong, but where?
Thanks in advance.
Unlike a monoatomic particle, water particles have the extra degrees of freedom of rotation and vibration. The associated energy levels are quantized, and I believe that it them that allow IR absorption in molecules with 2 or more atoms
Single atoms absorb IR by having their electrons jump up levels, still quantized.
So IMO, besides for particles with a net charge, such as electrons, protons, alphas, and ions, absorption is necessarily quantized. Neutrons should strictly not be aware of any IR.
Would IR make an ion translate continuously or have its electrons jump levels? I suppose it would depend on whether the IR wavlength matches a level jump or not.
Hi Gonzolo, thanks for your time and excuse me if my question is nonsense.
That´s true, but it has also translation degrees. If a molecule of water is "completely free" (not influenced by any potential) the energies of theese degrees are continuous. So translation degrees would absorb themselves all the radiation leaving no possibility for measuring other degrees.
If you prepare a beam of any type of particle propagating coherently and free, wolud it be "black" and opaque to light? NO but why not?
Perhaps the reason is that it´s impossible to get a molecule "completely free", but that wolud quantize the translation energy thus creating "translation spectrums"... of course not, but I can´t explain why not.
Help please!
You are trying to make a comparison between electrons and molecules. Electrons are free particles, yes, but molecules are not free particles in a Spectroscopic sense. They consist of electrons bound to a nucleus and two atoms bound together.
Molecules will still exhibit electronic, vibrational and rotational spectra. Translational motion simply doppler shifts the spectrum one way or the other, is does not contribute to the spectral features and is usually disregarded in spectroscopy for this reason.
Look up 'Born-Oppenheimer approximation' for more info.
Claude.
Ok, Born-Oppenheimer approx. says that electronic movements are much quicker than nucleus movements, so in VIS radiation-matter interaccions we can consider total wavefunction as electronic wavefuncion.
Even rotational and vibrational movements are much quicker than translational movements. So if we irradiate the beam with MW or IR (resonant with any transition) it would absorb as if the molecule hadn´t translational energy.
But if we irradiate with non-resonant ligth? What is the reason for not to think that it wolud use that energy to increase translational energy (as if it was a photon-molecule collision)?
First, there are many more photons than water molecules in the beam, so many get through.
And in a case where you have exactly the same number of photons than molecules, there is some distance between the molecules, so that light can scatter through, such that it does through any gas. There is a limited cross-section to a molecule that might be smaller for translation absorbtion than for vibrationnal or rotationnal absorption.
In fact, the closest thing to the beam you envision might be very dense steam. It is not black indeed, but rather white-ish, due to scattering. This white is indeed continous. You might want to think of this white as what happens "after a translationnal absorption" in the VIS. But remember that a water molecule is a dipole, so that if it is accelerated by EM (such as a photon), it can also emit. Such "emission and absorption", which I believe is better termed "scattering" is quite symetrical - what the dipole (or whatever charge) receives doesn't necessarily have a reason to stay, such translations would cause molec.-molec. collisions emitting further photons and some of the molecules might return to their original state. And beam temperature would rise.
Ok, that made me think. Perhaps te answer is simply in the Rayleigh and Raman scattering... Thanks very much to both of you, I will need time to think about it.
Anyway, all your comments will be surely wellcome at any time :smile:
Not quite, the Born-Oppenheimer approximation says that we are able to separate the electronic part of the wavefunction from the rovibrational (rotation/vibration) part. The total wavefunction is the electronic wavefunction times the rovibrational wavefunction.
Claude.
OOps! :blushing: :blushing: Of course, you´re right. Thanks for correcting me.
Ok, the process that I was looking for is the scattering. But the scattering is a concerted process in which the absorbed and the emitted photons are connected by a virtual state with zero lifetime, so I may think that all the non-resonant energy (photons that match the cross section) is directly scattered without increasing linear momentum of the molecules. But the hot electrons emitted in laser ablation for example, or in photoelectric effect do so, they are accelerated without scattering. What´s the difference?
The more I think the more confused I get... :confused: Je Je
Light is not necessarily scattered when it hits a solid. In ablation or in the photoelectric effect, much of its energy is used to eject the electron from the solid, this is indeed absorption. And much of the extra energy goes into the electron's velocity.
I am not so sure the linear momentum of a gas is not increased at all. I can see the cross section to be very small, but not sure it is zero. If photon direction changes, so should a particle's.
Ok. Thanks for your time. I really appreciate your interest.
I was tracking down your thread "free particle spectrum" and others on google, but found nothing specific . Has no one calculated/measured it yet?
I can imagine the experiment: a discharge tube, say a meter long with transparent electrodes maintaining a 1 amp current flow at a variable potential difference up to speeds of 90%c. There would be a monochrometer passing variable narrow band emf from nicrowave to gamma down the tube to a detector that tells you Absorbance at a wavelength verses voltage.
My imaginary results would have a blip at spin flipping wavelength, superposed on a continua. The area under the absorbance vs wavelength curve properly calculated would be near to one electron.
Why can't the experiment and or oscillator strength calculation be made? Is there a fundamental problem like an electron can not have a transition (or any other) dipole?
Or, incoherent photon absorption would force a major fraction of electrons to leave the beam ( sic, angular dependence), and mess up "concentration"?...Or what.
Surely, you collective physicist could have come up with some appropriate, pointed answers in the four years since this thread was started.
The first post already answered that question: A free particle has a continuous spectrum. It has only kinetic energy.
Thank you,alxm.
But I was hoping for an answer a bit more detailed than was found in the existing threads.
Can you refer to a calculation- say one showing the transition dipole is not zero, or some experimental observation,like the electron population between the Earth and sun diminishes the suns spectra somewhat?
george simpso
When a cloud of free electrons in some type of plasmas is irradiated with light, these "hot electrons" are accelerated as they absorb light.
Free electrons cannot absorb photons because energy and momentum conservation cannot both be satisfied simultaneously. The incident photons are instead scattered by Thomson (low energy Compton) scattering off of the electrons. This is an important hot-plasma electron temperature diagnostic. See
http://en.wikipedia.org/wiki/Plasma_diagnostics#Thomson_scattering
http://en.wikipedia.org/wiki/Thomson_scattering
Bob S
Thank you, Bob S.
I appreciated the references to Thomson Scattering. I'll try to track down all the scattering processes.
I feel certain that scatter is the result of an energy absorption process for the electron and an exchange of energy &/or momentum by the photon.
george simpso
imagine a photon with energy [itex]E_{\gamma}[/itex] incident on a "composite particle" with a rest mass [itex]M[/itex]. For simplicity, we will observe the phenomenon in the CM - frame. In this frame, the momentum of the particle is opposite of the momentum of the photon [itex]p_{\gamma} = E_{\gamma}/c^{2}[/itex].
After the collision, the particle absorbs the photon and its mass increases to [itex]M' = M + \Delta M[/itex]. Momentum is conserved and the particle is at rest. Total energy is conserved, so we may write:
[tex]
\frac{\Delta M}{M} = \frac{E_{\gamma}}{M c^{2}} - 1 + \sqrt{1 + (\frac{E_{\gamma}}{M c^{2}})^{2}}
[/tex]
One can view this increase in rest mass as excitation of the intrinsic degrees of freedom of the particle by an energy [itex]\Delta \epsilon = \Delta M \, c^{2}[/itex]. We see that this dependence is a continuous function, so the absorbtion spectrum of the photon depends only on the excitation spectrum of the particle. Notice that the translational degrees of freedom where not limited and, therefore, they are not quantized.
Err...no.
For simplicity, let's consider the total absorption of a photon by an electron in the lab frame, where the electron is initially at rest. For a photon of energy Eγ = pc and momentum p = Eγ/c , the final total energy of the recoiling electron would be
Ee= m0c2 + Eγ.
But the momentum of the recoiling electron would be p = Eγ/c,
leading to a total energy of
[Ee]2= [m0c2]2 + [pc]2= [m0c2]2 + [Eγ]2
These two equations are irreconcilably different, because energy and momentum cannot both be conserved..
Bob S
Is the electron a composite particle?
So, that's the essential difference between your and my derivation. The electron's rest mass cannot change, since it is truly an elementary particle.
However, composite particles (such as atoms, molecules, nuclei and even hadrons) have a complicated internal structure described by so called "internal degrees of freedom". The rest mass of a bound system is always smaller than the sum of the rest masses of its constituents, the difference being called mass defect [itex]\Delta m[/itex] and being connected to a quantity called binding energy of the system [itex]B = \Delta m c^{2}[/itex].
This is why the whole energy of the photon can be absorbed by the composite particle. In order that we compensate for the momentum of the particle (at any given energy, massless particle have the highest possible momentum, so this is the "worst case scenario"), we better give the composite particle an equal by magnitude and opposite in direction momentum and, thus even more energy is available.
Now comes the paradox. The whole amount of the photon energy + kinetic energy of the particle are supposed to increase the rest energy of the particle. This is only possible if the rest mass of the particle decreases. If you remember, the rest mass was smaller than the sum of the rest masses of the constituents and the difference (by definition positive) was called mass defect. Increasing the rest mass of the particle is equivalent to decreasing the mass defect, which, in turn is directly proportional to the binding energy of the system. We can only do this until the binding energy becomes zero. Then, the composite system becomes unbounded and it disintegrates into its constituent parts.
(Bob S and Dickfore):Wow.
But light does interact with an electron. It does get polarized-angular momentum gets exchanged.Why can't the electron gain mass along with the energy, or lose angular momentum, at least temporarily.
Please provide evidence for a process where a free electron absorbs a photon.
Dickfore:
Your request puts me back to where I was when I logged into "free particle spectrum"
For starters check out http://farside.ph.utexas.edu/teaching/jk1/lectures//node85.html.
Next google "free electron laser" and "Absorption spectra of electrons in plasmas". There are a lot of experiments and calculation supporting absorption of a photon by an electron.
For what it's worth, google "free electro absorb a photon" you'll get >200,000 responces. But, query "free electron cannot absorb a photon", and ther are ~100,000.( more data/opinions pro than con ).
I think the evidence supports free electron absorption of a photon, but perhaps the collective physics wisdom does not.
So, what do you come up with?
Not sure what your point is exactly, but these excitations of intrinsic degrees of freedom can not include excitations of translational degrees of the composite particle, since that would violate the requirement that the final particle momentum be zero in this frame.
So you are only allowed to excite the other degrees of freedom: rotational, vibrational, and interaction terms (which are all quantized).
george simpso said:
... "Absorption spectra of electrons in plasmas". There are a lot of experiments and calculation supporting absorption of a photon by an electron.
Electrons in plasmas are free? Google "collective modes in plasmas"
Exactly what I was saying and those contribute to the rest mass of a composite object.
Free electrons can absorb EM radiation via inverse Bremsstrahlung absorption, the catch being that it can only occur in the vicinity of atoms.
Claude.
Claude.
So, how are they free if they are in the vicinity of atoms?
Free as in not bound to a nucleus. Conduction band electrons in a condensed dielectric for example.
Claude.
Claude.
What is the meaning of this 'band' you are using?
  • #31
(Posted by Dickfore:)
The difference between the photoelectric effect, in which the photon's total energy is absorbed by the electron, and Thomson scattering on free electrons, is that a little recoil momentum is absorbed by the recoiling atom or atomic lattice. Conduction electrons are not free electrons; the work function to remove a conduction electron is >= 3 eV.
Bob S
  • Atomic and Condensed Matter
  • Astronomy and Astrophysics
  • Quantum Physics
  • High Energy, Nuclear, Particle Physics
  • Other Physics Topics
16K
