Einstein-de Haas Experiment: Magnetic Dipole Moment Alignment
In summary, the conversation discusses the alignment of magnetic dipole moments in a ferromagnet with a solenoid's magnetic field, and the opposition between the MDM and angular momentum vector of an atom/electron. Lenz's law is mentioned, but it applies to induced currents rather than already existing magnetic dipoles. The alignment of the magnetic dipole is in the lowest energy state.
oliverlovellt
Hi.
So, you surround a ferromagnet with a solenoid.
Run current through solenoid to create B field withing.
2 Questions:
1:Why do the magnetic dipole moments in the ferromagnet "align" with the magnetic field of the solenoid? Doesn't lenz's law say that the magnetic field within the ferromagnet will "oppose" the introduced B field in the solenoid.
2:Consider a birds eye view of an electron orbiting a nucleus in the clockwise direction. Is the opposition of the Magnetic Dipole Moment (MDM) and the Angular Momentum vector of an atom/electron caused by the fact that L will point down due to the right hand rule and because convention says that MDM will point up because we use the CURRENT (flow of positive charge, not -ve) and the right hand rule, causing the MDM to point up?
Cheers.
Ollie.
1. Lenz's law is about induced currents (which has to do with dB/dt). There are magnetic dipoles in ferromagnetic material that would already be in the material before the B field is applied. The torque on a magnetic dipole m is mxB, which would, for an off B-field axis magnetic dipole, cause angular acceleration toward alignment. The B field aligned magnetic dipole is in the lowest energy alignment state.
2. Yes
Cheers : )
x
What is the Einstein-de Haas experiment?
The Einstein-de Haas experiment is a scientific experiment conducted by Albert Einstein and Wander Johannes de Haas in 1915. It demonstrated the relationship between magnetism and angular momentum, and proved the existence of the magnetic dipole moment of a spinning object.
How does the Einstein-de Haas experiment work?
In the experiment, a non-magnetic object, such as a glass rod, is suspended between the poles of a strong electromagnet. The object is then rotated, causing it to spin and align its magnetic dipole moment with the external magnetic field. This alignment can be measured by the change in the object's angular momentum.
What is the significance of the Einstein-de Haas experiment?
The Einstein-de Haas experiment provided evidence for the relationship between magnetism and angular momentum, which was a key concept in the development of quantum mechanics. It also confirmed the existence of the magnetic dipole moment of a spinning object, which is now a fundamental principle in many areas of physics.
What are some applications of the Einstein-de Haas experiment?
The experiment has been used to study the magnetic properties of various materials and to measure the magnetic dipole moments of particles, such as electrons and protons. It has also been used to study the behavior of magnetic materials at different temperatures and under different conditions.
Are there any limitations to the Einstein-de Haas experiment?
One limitation of the experiment is that it can only measure the magnetic dipole moment of objects with a certain level of angular momentum. It also requires precise and sensitive equipment to accurately measure the small changes in angular momentum. Additionally, the experiment does not work for objects with a purely intrinsic magnetic moment, such as certain subatomic particles.
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
