Rate of heat transfer passing from the boiling water to the ice bath
In summary, the rate of heat transfer passing from boiling water to an ice bath is proportional to the area normal to the flow path and to the temperature gradient along the flow path.
lalahelp
75
A copper rod of length 0.20 m and cross-sectional area 6.00 10-2 cm2 is connected to an iron rod with the same cross section and length 0.28 m (the figure below). One end of the copper is immersed in boiling water and the other end is at the junction with the iron. If the far end of the iron rod is in an ice bath at 0° C, find the rate of heat transfer passing from the boiling water to the ice bath. Assume there is no heat loss to the surrounding air.
What equation do I need to solve this could someone help?
Check this explanation
http://hop.concord.org/h1/phys/h1pm.html
which ends with a formula
OR [pasted from another site.
Basic Theory
The rate at which heat is conducted
through a material is proportional
to the area normal to the heat flow
along the heat flow path. For a one
dimensional, steady state heat flow
the rate is expressed by Fourier’s
equation:
Q = kA ΔT/d
Where:
k = thermal conductivity, W/m-K
Q = rate of heat flow, W
A = contact area
d = distance of heat flow
ΔT = temperature difference
The trick with the two rods is that the rate of heat flow in each must be the same, so the temperature at the Cu/Fe junction will NOT be 50 degrees.
Given that Copper conducts heat much better than Iron it will be closer to 100.
If, for example, copper conducts 9 times as well as Iron, the temp would be 90 degrees.
heat flow through copper with a 10 degree difference [100 - 90] would equal heat flow through Iron with a 90 degree difference [90 - 0].
Q/ Time = (Thermal conductivity) x (Area) x (Thot - Tcold)/Thickness
thermal conductivity of copper = 401 W/m K
thermal conductivity of iron = 80 W/m K
For copper heat conduction:
Q/t = 401 * .0006 m^2 * (100C - 0C) / .20 m thickness
Q/t = 120.3 watts conduction heat loss up to iron junction
For iron conduction:
Q/t = 80 * .0006 m^2 * ( 100C - 0C) / .28 cm = 17.1 watts heat conduction from junction to ice bath.
Is my work correct? I don't know what to do after?
The temperature difference of 100C is across both rods. You do not know the temperature at the junction of the copper and the iron... call it ∅.
The temp difference for the copper is then (100 - ∅)... put this in your copper equation.
The temp difference across the iron is (∅-0) =∅...put this in the iron equation
You will then have 2 equations for heat flow through copper and iron. These are equal so find ∅ then substitute back to find heat flow.
I got ∅ = 87.5C and rate of heat flow 1500W
How did you solve for ∅?
For the copper
dQ/dt = 401 x 0.0006^2 x (100-∅)/0.2
For the iron
dQ/dt = 80 x 0.0006^2 x (∅ -0)/0.28
These 2 equations are equal
Can you do the algebra to find ∅?
If not ask and I will do the next step
Can you do the next step please
1. How does the temperature difference between the boiling water and ice bath affect the rate of heat transfer?
The greater the temperature difference, the faster the rate of heat transfer. This is known as the temperature gradient, and it is a driving force for heat to move from the hotter object (boiling water) to the cooler object (ice bath).
2. Does the surface area of the objects affect the rate of heat transfer?
Yes, the larger the surface area of the objects, the faster the rate of heat transfer. This is because a larger surface area allows for more contact between the two objects, increasing the efficiency of heat transfer.
3. How does the type of material of the objects affect the rate of heat transfer?
The type of material can greatly affect the rate of heat transfer. Materials with high thermal conductivity, such as metals, will transfer heat more quickly than materials with low thermal conductivity, such as plastics. This is due to the ability of the material to conduct heat energy.
4. Does agitation of the water affect the rate of heat transfer?
Yes, agitation of the water can increase the rate of heat transfer. When water is agitated, the molecules move more vigorously and come into contact with each other more frequently, leading to faster heat transfer.
5. How can the rate of heat transfer be calculated?
The rate of heat transfer can be calculated using the equation Q/t = kA(T1-T2)/d, where Q is the amount of heat transferred, t is the time, k is the thermal conductivity of the material, A is the surface area, T1 is the initial temperature, T2 is the final temperature, and d is the distance between the objects.
