4 home work problems over projectile motion
In summary: For the rock, it is thrown at an angle of 56.6° with the horizontal. it will be 30.1m above the ground at the time it reaches the horizontal.
man on fire
1. a projectile is fired into the air at a projection angle of 30° above the ground. its initial speed is 327 m/s. what is its speed 3 seconds later
2.the speed of a projectile at its maximum height was 40% of its speed at ground level. find the angle of elevation.
3.a man stands on a cliff 15m abouve a level plain. he tosses a rock at 36m/s into the air over the plain. at what angle to the horizontal did he throw the rock if it is in the air for 6.6s(i got 63.93° but my teacher got 56.6° i am not sure why i am wrong or if i am wrong)
4.a stone is projected from ground level aith a speed of 61m/s at an angle of 24° with the horizontal. how high above the ground, assumed level, will the stone be when its horizontal displacement is 122m(i got 69.65m my teahcer got 30.1m i am not sure why i am wrong or if i am wrong)
please explain how you got your answer
1. i have no clue what to do
2. still no clue
3. i used {2(sin(theta)*V)/g = t ---> (2*sin(theta)*36)/9.8 = 6.6 ---> (6.6*9.8)/(2*36)=sin(theta) ---> sin^-1(64.68/72) = theta} is this correct
4. i used {t = Dh/Vcos(theta) ---> t = 112/(61*cos(24) ---> t = 2.0098 ---> now with time i put it into Dy = (v*sin(theta)*t) + .5*g*(t^2) ----> Dy = (61*sin(24)*2.0098) + .5*9.8*2.0098^2} is this correct
4.a stone is projected from ground level aith a speed of 61m/s at an angle of 24° with the horizontal. how high above the ground, assumed level, will the stone be when its horizontal displacement is 122m(i got 69.65m my teahcer got 30.1 i am not sure why i am wrong or if i am wrong)
You need to show your working for us to comment on what you might be doing wrong.
You have given no indication at all for parts 1 and 2 ??
Has your teacher taught you the X and Y table method?
no she has not taought us the X and Y table method please explain
For part 3, your teacher is correct.
For part 4, I got 30.8m, assuming g = 9.8 m/s/s (30.4m, if using g = 10 m/s/s)
speed is velocity, there should be 4 linear equations of motion that should describe this. . .
For projectile motion, the initial velocity can be divided into a vertical component and a horizontal component, using trig. Some people refer to those as an x-component and a y-component as the x-axis is traditionally horizontal, while the y-axis is traditionally vertical [when drawn on the page]
During the flight, the horizontal component remains constant [until the projectile hits something] and the vertical component follows the normal laws of vertical motion under g.
approximation example: - using g=10 for simplicity.
Your 327 m/s at 30 degrees amounts to vertical approx 160, horizontal approx 280.
In 3 seconds, the vertical component will reduce by 30 [remember I am taking g = 10 for simplicity here]
so now Vv = 130 and Vh = 280 [unchanged].
You can use Pythagoras to reconstitute the speed that means.
That's how #1 is done - but with far more accurate figures!
#2 can be analysed as above, and at maximum height, the Vertical component = 0, so only Vh has a value, and it is 40% of the initial velocity. Trig should give you the answer.
What is projectile motion?
Projectile motion is the motion of an object that is launched into the air and then moves under the influence of gravity. It is a form of two-dimensional motion, meaning it occurs in a plane instead of a straight line.
What are the four home work problems related to projectile motion?
The four homework problems related to projectile motion typically involve finding the maximum height, range, time of flight, and velocity of a projectile launched at an angle.
How do you solve these projectile motion problems?
To solve projectile motion problems, you will need to use the equations of motion, which include the kinematic equations and the equations for horizontal and vertical motion. You will also need to break down the initial velocity into its horizontal and vertical components.
What are some common mistakes when solving projectile motion problems?
Some common mistakes when solving projectile motion problems include forgetting to break down the initial velocity, using the wrong equations, and not considering air resistance. It is also important to pay attention to the direction of the velocity and acceleration vectors.
How can I check my answers for projectile motion problems?
You can check your answers for projectile motion problems by using the equations of motion and plugging in your values to see if they match. You can also use online calculators or graphing software to visualize the trajectory of the projectile and compare it to your calculated values.
