Two particles and gravity; non-constant acceleration
In summary, In order to calculate a(t), you integrate the equation of motion of the two particles, which is separable, and solvable, but has no analytical solution.
Acronim
Hi,
I wanted to find some formulas for describing the motion of two particles.
It seems, though, that it's harder than I originally thought.
The situation:
there are two particles (m1 and m2), and they are in rest somehow. Due to their mass, each particle attracts the other with a gravitational force [tex]F_g = \frac{G m_1 m_2}{d^2}[/tex], where G is the gravitational constant, d is the distance between the particles, and m1 and m2 are the masses of the particles.
Combining this with: [tex]F=m \cdot a[/tex]
Gives me: [tex]a_1 = \frac{G m_2}{d^2}[/tex]
This is already useful, of course, but I'd rather have a formula that depends on time instead of the distance between the particles.
So what I'd like to know: is there a formula for a(t)? (and/or v(t))
I guess the formula would need to exist of at least G, the initial distance between the particles and their mass, but I really don't know how it would look like.
I know that a(t) is not linear, and neither is v(t).
Also, I know that acceleration is the integral of velocity with respect to time, but since I have no t in the formula for acceleration, I have no idea how to do this integral.
(The motion of the particles is one-dimensional; they don't rotate around each other, they just move towards each other due to the gravitational forces they apply on each other.)
I hope someone can help me out :biggrin:
Hey Acronim,
Yup you're quite right. You can get a(t) by a little calculus trick.Here:
In order to avoid confusion let us say the distance between the bodies is "x" at a particular time.
put a=vdv/dx = Gm2/x2......(i)
Integrate and find v(x). Now put v=dx/dt to get x(t).....(ii)
Once you have x(t) you can differentiate to find v(t) or a(t)
Hope this solves your doubt.
Aniketp:
Thanks for the fast (and rather useful) response!
I'm not quite sure if I understand it completely, but I'll try to work it out. I'm no professor, you know (didn't even start at university yet):tongue2:... But I'll try to get as far as I can.
What I don't quite understand is what exactly to integrate...
You wrote:
[tex]a= v \frac{dv}{dx}=\frac{Gm_2}{x^2}[/tex]
Should I integrate only [tex]\frac{Gm_2}{x^2}[/tex]
[tex]\int \frac{Gm_2}{x^2} dx=-\frac{Gm_2}{x}+c[/tex]
Or should I integrate something else?
Defennder:
I have quickly looked through that page, and also tried to find some more info about the two-body problem, but for as far as I could see, the two-body problem is about two body circulating around each other in some way. I don't know how I could possibly apply that if the bodies are not circulating around each other, but simply approaching each other like an apple approaches the Earth in a straight line due to gravity.
Acronim said:
Defennder:
Considering that the bodies have no velocity at t=0. ok, That is a nice question
basically by the simetry of the problem, you can consider a single axe, say x.
Considering that 1 particle is still(to simplify), you have [tex]a_x=\frac{K}{x^2}[/tex] K is a constant. And the problem is there. That is called a differential equation. You have that the second derivative of x(acceleration) is equal to a constant times 1/x^2.
That differential equation has no analytical solution. Basically that means that you can't derivate/integrate/math-tricks to solve it in order to x(t). So, no, you can't just get the equation of movement of that particle. A computer can, however, make a computational solution(an numerical approximation: with the two bodies it can too). If you want to know more about it, ask here, and i post you a python code with an how to, or just pm me to talk msn.
It looks like I didn't read the original pos properly. The OP only wants to decribe the equations of motions of two masses originally at rest with each other, which effectively reduced the problem to 1 dimension. I think aniketp answered it pretty well. Here's what she/he meant. You have by the law of gravitation:
[tex]a_1(x) = \frac{Gm_2}{x^2}[/tex]
By the chain rule, [tex]a_1 = \frac{dv}{dt} = \frac{dv}{dx} \frac{dx}{dt} = v\frac{dv}{dx}[/tex]
This is separable and solvable:
[tex]\int a_1 dx = \int v dx[/tex]
[tex]Gm_2 \int \frac{1}{x^2} dx = \int v dv[/tex]
Once you get the expression for v in terms of x, note that v=dx/dt, which effectively allows you to solve by separation of variables to get x(t). The constants of integration can be obtained by substituting the initial conditions as you have given.
You are forgetting that the two particles are accelerating toward each other.
Which two other particles? There's only m1 and m2 here.
Yes, there are two particles, that was a typo. Fixed.
Both accelerating toward each other. Post #4 and #6 deal with the acceleration of m1 with respect to inertial, not m1 with respect to m2.
I'm afraid I'm not following you here. What do you mean by respect to "inertial"? You have v1, v2 and these can be expressed as functions of x.
You said
[tex]
\begin{aligned}
a_1 &= \frac {Gm2}{x^2} \\
a_1 &= \frac {dv}{dt} = \frac {dv}{dx}\, \frac{dx}{dt}
\end{aligned}
[/tex]
which is incorrect. One problem is the sign on the acceleration (first equation). The second equation is a bigger problem because it ignores the motion of mass 2 toward mass 1.
Newton's law of gravitation applies to inertial frames. Your a1 is the magnitude of the acceleration of mass 1 with respect to some inertial frame. This is a mouthful, so many say "with respect to inertial" for short. The problem is that this is not the second time derivative of the distance between the two objects, which is what your second equation says.
One way to reach the correct solution is to define x as the distance between the two masses, v as the time derivative of x, and a as the time derivative of v. From Newton's law of gravitation,
[tex]a = -\,\frac {G(m_1+m_2)}{x^2}[/tex]
Using the chain rule and separating as you did leads to the correct solution.
I think there is some confusion here. Apparently x is defined here as the separation distance between m1 and m2 at anyone time, so v=dx/dt can't be correct. I was misled by the way in which x is used more commonly in other contexts. But if that is the problem then how can the chain rule and separation of variables work here be correct?
Acronim said:
Aniketp:
Yeah that's the one you have to integrate. It's actually quite simple. You know that
a=dv/dt .Using chain rule, a=dv/dx*dx/dt = vdv/dx . You may also try definite integration to get rid of the constant.
Defennder said:
IApparently x is defined here as the separation distance between m1 and m2 at anyone time, so v=dx/dt can't be correct.
v=dx/dt is correct for the simple reason that this is the definition of v.
aniketp said:
Yeah that's the one you have to integrate. It's actually quite simple. ...
Except you are ignoring the motion of the other mass, and in doing so you get the wrong answer.
The answer we will get is the relative velocity as a function of time, won't it?
Here are two ways to arrive at a description of the time evolution of the separation distance.
Non-inertial frame
Choose one of the masses -- say m1 -- as the origin of a reference frame. The goal is to describe the location of the other mass (m2) as a function of time. Denote the x-hat axis of our frame as pointing toward mass m2 and denote x as the distance between the two masses. The equation of motion in this accelerating frame is
[tex]a \equiv \frac {d^2 x \hat x}{dt^2}
= \frac {F_{\text{net}}}{m_2} - \ddot R[/tex]
where F_net is the net force acting on mass m2 and R-double-dot is the frame acceleration. By Newton's law of gravitation and Newton's third law,
[tex]
\begin{aligned}
F_{\text{net}} &= -\,\frac{Gm_1m_2}{x^2} \hat x \\
\ddot R &= - \, \frac {F_{\text{net}}}{m_1} = \frac{Gm_2}{x^2} \hat x
\end{aligned}
[/tex]
While the reference frame is accelerating, it is not rotating. The unit vector x-hat thusly is constant. Combining the above results,
[tex]a =
-\,\frac{Gm_1}{x^2} - \frac{Gm_2}{x^2} = -\,\frac{G(m_1+m_2)}{x^2}[/tex]
Define [itex]v[/itex] as the first time derivative of [itex]x[/itex]. Then
[tex]a = \frac {dv}{dt} = \frac{dv}{dx}\,\frac {dx}{dt} = v\frac{dv}{dx}[/tex]
Combining with the previous result,
[tex] v\frac{dv}{dx} = -\,\frac{G(m_1+m_2)}{x^2}[/tex]
This is a separable and easily differential equation, giving v as a function of x. Integrating velocity with respect to time will yield the desired time desciption of the displacement vector.
inertial frame
Let [itex]\mathbf x_1(t)[/itex] and [itex]\mathbf x_2(t)[/tex] be the positions of masses m1 and m2 as functions of time from the perspective of some inertial frame. The goal is to describe the distance between the two masses as a function of time. By Newton's law of gravitation and Newton's second law,
[tex]
\begin{aligned}
\frac{d^2\mathbf x_1}{dt} =
\frac {G m_2}{||\mathbf x_2 - \mathbf x_1||^3} (\mathbf x_2 - \mathbf x_1) \\
\frac{d^2\mathbf x_2}{dt} =
\frac {G m_1}{||\mathbf x_1 - \mathbf x_2||^3} (\mathbf x_1 - \mathbf x_2)
\end{aligned}
[/tex]
Taking the difference between these two acceleration vectors yields the second time derivative of the displacement vector from mass m1 to mass m2:
[tex]\frac{d^2}{dt}(\mathbf x_2 - \mathbf x_1) =
- \frac {G m_2}{||\mathbf x_2 - \mathbf x_1||^3} (\mathbf x_2 - \mathbf x_1)
= -\, \frac {G (m_1+m_2)}{||\mathbf x_1 - \mathbf x_2||^3}(\mathbf x_2 - \mathbf x_1)
[/tex]
The desired goal is a description of the magnitude of the relative displacement vector. Define x as this magnitude and x-hat as the unit vector along the vector from mass m1 to mass m2. As the force will always be directed along this line, the unit vector x-hat is a constant unit vector. Thus
[tex]\frac{d^2x}{dt}\hat x =
-\, \frac {G (m_1+m_2)}{x^3}x \hat x
[/tex]
Eliminating the unit vector x-hat and simplifying,
[tex]a \equiv \frac{d^2x}{dt} =
-\, \frac {G (m_1+m_2)}{x^2}
[/tex]
The rest of the solution follows that of the non-inertial frame.
Unfortunately not...a~1/(d^2) and d is not the same x as v = dx/dt is referring to. Therefore, the procedure used previously does not work.
I know that my notation may be bad, since I leave out vector-notation and perhaps some other stuff I don't know about, but I thought it wasn't too important.
I'll try to make a graphic representation ( = picture :tongue2:) of the situation.
D H,
I just don't really know why we should work with [tex]a=-\frac{G(m_1+m_2)}{x^2}[/tex]
For as far as I understand, this is the difference between the acceleration of m1 and m2, so a2-a1, where a2 is "negative" and a1 is "positive". I know it works just as well as working with two accelerations seperately (It's easy to get a1 and a2 from a; same for v and x), or perhaps even easier.
If it's easier to work with displacement x1 and x2, thus (x2-x1) instead of d or x as a distance between the particles, it's no problem of course.
But if you've got a function for v as a function of x, how is it possible to integrate it with repect to time?
The distance between the two particles is x2-x1.
Another way to look at it: Suppose the masses are not equal. Only using what you are calling a1 to describe the motion will lead to two different answers if you simply switch which particle you are calling m1 and which you are calling m2. The real behavior doesn't depend on the labels we apply to things.
You should end up with a relationship [itex]v=f(x)[/tex]. In other words, [itex]dx/dt = f(x)[/itex]. You can solve for t as a function of x by integrating:
[tex]t=\int \frac 1 {f(x)}\,dx = F(x)[/tex]
If you want x as a function of t, you will have to find the inverse of this [itex]F(x)[/itex].
Actually...I might have to correct my previous statement and you might be right. If particle 1 was at x1 = 0 and particle 2 at x2 = x...if we let particle 1 stay at 0 relative to x2, then I'm thinking you are correct...heh, my apologies.
In fact, if we stick to considering the motion of particle 2 (or 1) relative to the other, then we could more easily get an equation of x(t), in which x is the distance between the particles. However, this would represent the change in the distance between the particles and not the independent motion of the particles; I'm still unsure of how to derive equations for such.
The motion of the individual particles is an unnecessary distraction and begs the question: In which reference frame? The frame typically used to solve such problems is the center of mass frame. To solve for the motion of each particle in some inertial frame you will have to solve for the relative displacement first. Why bother? The relative displacement is the quantity to be solved for.
I think I see your point. If we did have the relative displacement as a function of time, then we could substitute it into the equation of a = Gm/(x^2), in which x is the relative displacement.
1. What is the difference between constant and non-constant acceleration?
Constant acceleration refers to a situation where the velocity of a moving object changes by the same amount in each unit of time. Non-constant acceleration, on the other hand, refers to a situation where the velocity changes by different amounts in each unit of time.
2. How does gravity affect the motion of two particles?
Gravity is a force that attracts objects with mass towards each other. In the case of two particles, gravity will cause them to accelerate towards each other. The magnitude of this acceleration depends on the masses of the particles and the distance between them.
3. Can two particles have non-constant acceleration without gravity?
Yes, two particles can have non-constant acceleration without gravity. This can occur if there are other forces acting on the particles, such as friction or air resistance. These forces can cause the particles to accelerate at different rates, resulting in non-constant acceleration.
4. How does the distance between two particles affect their acceleration due to gravity?
The distance between two particles affects the magnitude of their acceleration due to gravity. As the distance between the particles decreases, the force of gravity between them increases, resulting in a higher acceleration. As the distance increases, the force of gravity and acceleration decrease.
5. Can the acceleration of two particles with gravity ever be constant?
No, the acceleration of two particles with gravity will never be constant. This is because the force of gravity is proportional to the distance between the particles, which means that as the particles get closer together, the force and acceleration will increase. Therefore, the acceleration will always be changing and cannot be constant.
  • Mechanics
  • Mechanics
