- #36
- 8,938
- 2,945
nanosiborg said:So, what can be inferred from the predictability of distant correlations? Can it be said, for example, that there has been an invariant relationship between entangled particles created through the entangling process, ie., through common source, interaction, common motion imparted to particles that don't have a common source and have never interacted, etc.? If so, does this seem weird?
Yes.
It doesn't to me, and the fact that the totality of results of optical Bell tests are in line with the conservation laws and optics principles further supports that view.
My general feeling is that if you don't find quantum mechanics weird, you haven't thought about it enough. Conservation laws don't by themselves explain the correlations.
Think about the following situation: You prepare an electron with spin-up along some axis [itex]\vec{S}[/itex]. Then later you measure its spin along a different axis [itex]\vec{A}[/itex]. Then the result will be non-deterministic: with a certain probability, the electron will be found afterwards to have spin-up in the [itex]\vec{A}[/itex] direction, and with a certain probability, it will be spin-down. In either case, the angular momentum of the electron was changed by the measurement: its final angular momentum is not the same as its initial angular momentum. That isn't a violation of conservation of angular momentum, because you can attribute the change to the interaction between the detector and particle. The angular momentum of the particle changes, and the angular momentum of the detector changes in a complementary way, so that the total angular momentum is unchanged by the detection process. But note that there is a small amount of angular momentum, [itex]\delta \vec{L}[/itex] transferred from the electron to the detector.
Now, if that electron happened to have come from an EPR twin-pair experiment, then each of the two detectors can be expected to receive a tiny amount of angular momentum from whichever particle is detected. But in the case of perfectly aligned detectors, we know that the [itex]\delta \vec{L_1}[/itex] received by one detector must exactly correlate with the [itex]\delta \vec{L_2}[/itex] received by the other detector, so that the resulting spins of the twin particles are perfectly anti-correlated.
So the perfect anti-correlation is not simply a matter of conservation of angular momentum. Angular momentum would be conserved whether or not the twin particles are found to be anti-correlated--it's just that different amounts of angular momentum would be transferred to the detectors. The perfect anti-correlation of twin pairs is a matter of cooperation between nondeterministic processes involving distant macroscopic objects (the detectors).
