Prove Power Rule by Math Induction and Product Rule
You just need to clean it up a bit and then add a conclusion. If you want to post it here in the thread, I'll take a look at it for you.
5hassay
82
Use the Principle of Mathematical Induction and the Product Rule to prove the Power Rule when n is a positive integer.
Dxxn = nxn-1
Dx(fg) = fDxg + Dxfg
In summary,
Dxxn = nxn-1
Dxxk = kxk-1
Dxxk+1 = (k+1)x(k+1)-1
Dx(xkx) = (k+1)xk
xkDxx + Dxxkx = (k+1)xk
xk + kxk-1x = (k+1)xk
xk + kxk = (k+1)xk
(k+1)xk = (k+1)xk
Therefore, Dxxn = nxn-1 is valid for all positive integers n.
EDIT: Oh, and much appreciation for any help!
Looks like you have pretty much proved it. You just need to show it's true for n=1.
If you really want to have a hoot, try proving the power rule from the definition of the derivative.
I pretty much did that in my lecture notes that I uploaded here.
It looks like the instructions are pretty clearly saying to use induction and the product rule:
Did anyone read the proof yet? If I was the professor, I might give the proof half credit. I'm not intending in any way shape or form to criticize, 5hassay. That's why students come here: to learn and improve.
On the third line of the summary, where k+1 is introduced, the proof appears to assume the result of the induction. Although for many proof methods, one can simply substitute what we need, this substitution is not allowed, because we are only allowed to assume it, the induction hypothesis, is true for k<=n.
What about arranging the proof around
xk+1= xk*x and then applying product rule to the right hand side?Also, clarify how you're going about this. Specifically, when doing induction stating the induction hypothesis, improves clarity.
For example,
Basis step: prove the statement for n=1.
... (easily forgotten/skipped, but essential)
Inductive step:
Assume for induction
Dxxk= k*xk-1
xk+1= xk*x
Dxxk+1= Dx(xk*x) Take deriv. both sides
Then apply product rule to right hand side and see what happens.
5hassay said:
In summary,
Dxxn = nxn-1
This is what you assume is true. → Dxxk = kxk-1
With the above assumption, PROVE that this is true. (Don't assume it's true.) →Dxxk+1 = (k+1)x(k+1)-1
Dx(xkx) = [STRIKE](k+1)xk[/STRIKE]
xkDxx + Dxxkx = [STRIKE](k+1)xk[/STRIKE]
xk + kxk-1x = [STRIKE](k+1)xk[/STRIKE]
xk + kxk = [STRIKE](k+1)xk[/STRIKE]
(k+1)xk = [STRIKE](k+1)xk[/STRIKE]
Write xk as x(k+1)-1
Pretty much what nickalh said.
Ahhhh, thanks Sammy, I just realized OP actually worked it out acceptably on the left hand side. You're right, ironically, deleting the right hand side and cleaning up a bit does the proof. Possibly add a concluding line, I prefer actual English instead of just notation.
Ya'll have an excellent day/afternoon/night.
Haha, I do imagine that would be a good amount of fun and a good looking product afterward!
For example,
Inductive step:
Dxxk= k*xk-1
xk+1= xk*x
Ah, okay. Yes, I am very new to Mathematical Induction (by definition), so I thought I would just skip the various statements. I now know that their importance is not less so as to not be involved in a summary! Also, I now understand about the n=1 step. I did indeed not think about it at all! Thanks for your help!
Okay, thanks!
nickalh, I agree. I prefer English, rather than only notation, too.
5hassay said:
Okay, thanks!
You're welcome. Though what SammyS wrote in Post #7 is really correct. What you did was fine in terms of figuring things out, but a formally correct proof should follow along the lines of Post #7. Like I said, you pretty much have it.
1. What is the power rule in mathematics?
The power rule states that when differentiating a function that is raised to a power, the power can be brought down in front and the exponent can be reduced by one. For example, the derivative of x^3 is 3x^2.
2. How do you prove the power rule using mathematical induction?
To prove the power rule using mathematical induction, we start by showing that the rule holds for the base case, where n = 1. Then, we assume that the rule holds for n = k and use this assumption to prove that it also holds for n = k + 1. This completes the proof by mathematical induction.
3. What is the product rule in mathematics?
The product rule states that when differentiating a product of two functions, the derivative is equal to the first function multiplied by the derivative of the second function, plus the second function multiplied by the derivative of the first function. In other words, (f(x)g(x))' = f'(x)g(x) + f(x)g'(x).
4. How do you prove the product rule using mathematical induction?
To prove the product rule using mathematical induction, we start by showing that the rule holds for the base case, where n = 1. Then, we assume that the rule holds for n = k and use this assumption to prove that it also holds for n = k + 1. This completes the proof by mathematical induction.
5. Why is it important to prove the power rule and product rule using mathematical induction?
Proving mathematical rules using induction is important because it provides a rigorous and logical way to show that a rule is true for all cases, not just a few examples. This is especially important in mathematics, where we want to be certain that our rules and equations are always accurate and applicable.
