Gravitons in Loop Quantum Gravity
In summary: Minkowski space. In summary, LQG is a canonical quantization approach that starts from a curved spacetime and does not use gravitons as building blocks. It does not assume a background and aims to get rid of the limitations of the usual quantization methods. On the other hand, string theory starts from a background and its excitations are the quanta of the associated fields, including gravitons. However, in some non-perturbative versions of string theory the background is not fixed and can fluctuate, making it more similar to LQG.
waterfall
381
How do you understand about Gravitons in Loop Quantum Gravity? All I know about it is from what I heard that "LQG hopes that its predictions for experiments occurring far below the Planck scale will be almost identical to that of gravitons on flat spacetime".
So do you consider it a pure graviton at all or some kind of pseudo-graviton (in LQG)?
I just found a paper about gravitons in LQG but may not understand it 100%
http://arxiv.org/pdf/gr-qc/0604044v2.pdf
Do you think it's correct? Please share other papers about gravitons in LQG if there is. Thanks.
For example someday the LHC were able to detect gravitons. Can we tell whether it is a String graviton or the pseudo-graviton of Loop Quantum Gravity? What are the differences? Maybe the latter involves some kind of geometric based graviton or something?
Here's a more recent paper that references the one in the OP.
http://arxiv.org/abs/1105.0566
Euclidean three-point function in loop and perturbative gravity
Carlo Rovelli, Mingyi Zhang
"In particular, the low-energy limit of the two-point function (the “graviton propagator”) obtained in this way from the improved-Barrett-Crane spin foam dynamics [7–12] (sometime denoted the EPRL/FK model) correctly matches the graviton propagator of pure gravity in a transverse radial gauge (harmonic gauge) [13, 14]. ... The obvious next step is to compute the three-point function. In this paper we begin the three-point function analysis. We compute the three-point function from the non-perturbative theory."
BTW, Rovelli and Zhang's calculations are based on a different spin foam proposal from that used in Bianchi et al's paper referenced in the OP. Bianchi et al base their calculations on the Barrett-Crane proposal, which is now thought to be wrong, because it did not match the graviton propagator. The Rovelli and Zhang paper is based on the EPRL/FK/KKL proposal which is reviewed in Rovelli's Zakopane lectures.
What's odd in the two papers above is they mentioned about "Graviton propagator" instead of just "Graviton". Why is that. In your own understanding, why do they call it "Graviton Propagator"? Why "Propagator"?
In quantum theory, a propagator contains information about the probability that a particle will take a certain path.
http://arxiv.org/abs/0905.4082
LQG propagator from the new spin foams
Eugenio Bianchi, Elena Magliaro, Claudio Perini
(Submitted on 25 May 2009)
We compute metric correlations in loop quantum gravity with the dynamics defined by the new spin foam models. The analysis is done at the lowest order in a vertex expansion and at the leading order in a large spin expansion. The result is compared to the graviton propagator of perturbative quantum gravity.
Comments: 28 pages
http://arxiv.org/abs/1109.6538
Lorentzian spinfoam propagator
Eugenio Bianchi, You Ding
(Submitted on 29 Sep 2011)
The two-point correlation function is calculated in the Lorentzian EPRL spinfoam model, and shown to match with the one in Regge calculus in a proper limit: large boundary spins, and small Barbero-Immirzi parameter, keeping the size of the quantum geometry finite and fixed. Compared to the Euclidean case, the definition of a Lorentzian boundary state involves a new feature: the notion of past- and future-pointing intertwiners. The semiclassical correlation function is obtained for a time-oriented semiclassical boundary state.
Comments: 13 pages
excerpt:
In this limit, the two-point function we obtain exactly matches the one obtained from Lorentzian Regge calculus [38]. We therefore extend to Lorentzian signature the results of [13].​
[13] E. Bianchi, E. Magliaro, and C. Perini, Nucl. Phys.
B822, 245 (2009), arXiv:0905.4082 [gr-qc].
So Bianchi Ding is a sequel to Bianchi Magilaro Perini. It completes that initiative by doing the earlier analysis in the Lorentzian setting
About LQG vs String Theory. Let me share an answer to a question I asked 2 weeks ago. I was asking if loop quantum gravity was also about spin-2 on flat spacetime. The answer is no, because LQG starts from curved spacetime and is simply a canonical quantization thing and the curvature is primary. While String Theory is actually spin-2 on flat spacetime with the spacetime curvature as secondary effect. Although one can say LQG can be modeled as spin-2 on flat spacetime by taking the GR part in LQG and doing it. But for full fledged LQG. It has spacetime curvature a priori and there is no flat spacetime underneath it. I think everybody agrees now and I assume there are no objections from anyone.
Likes David Horgan
Although perturbative string theory has flat spacetime (or some other vacuum solution of the Einstein equation) as background, in some versions of non-perturbative string theory such as AdS/CFT the bulk space has no background and is completely free to fluctuate, so it is similar to LQG in this respect. In fact it is more radical, since LQG assumes space as a fundamental entity that fluctuates, whereas the bulk space is not a fundamental entity in AdS/CFT.
Likes ComplexVar89
In string theory and in most treatments of QFTs one starts with quantized excitations on top of a classically fixed background. The excitations are the quanta of the associated fields (photons, gravitons, ...). This approach has some limitations and LQG tries to get rid of them.
LQG never introduces a background and excitations living on this background, so LQG does not use gravitons as building blocks. Instead one expects that one may recover a kind of semiclassical limit or weak field limit where something like "gravitons" will show up again.
So in contrast to any other QFT where the "...ons" are the fundamental (mathematical and physical) entities in LQG the gravitons are not fundamental but only to be considered in a certain limited approximation.
Likes ComplexVar89 and John M. Carr
tom.stoer said:
In string theory and in most treatments of QFTs one starts with quantized excitations on top of a classically fixed background. The excitations are the quanta of the associated fields (photons, gravitons, ...). This approach has some limitations and LQG tries to get of them.
This is an excellent concise statement! Offhand I can't think of any place where these basic facts have been expressed more clearly.
Just to amplify, unnecessarily I think, any approach which starts with a classical fixed geometry and lays quantized excitations on top of it is called "perturbative". The primary aim of LQG, and so to speak its "claim to fame", is to strive for a "non-perturbative" quantum geometry.
In the loop approach there is no mathematical "thing" representing space or space time. There are only relationships among measurements. These are the quantum states of geometry (a state is a web of interrelated geometric measurements). It's a minimalist approach, in a sense, and makes for challenging mathematical problems.
thanks!
Well I believe the story is roughly like follows. Strings, in the usual worldsheet formulation, assume some fixed background. Eg for the flat empty space, take this to be the Minkowski space described by a metric eta_mn, plus small fluctuations delta around it:
g_mn = eta_mn+ delta_mn
Essentially these delta describe gravitational waves whose quanta are gravitons. Other, curved backgrounds g_mn are equally possible, like eg. black holes, and one can expand around them analogously.
In LQG the “expansion point” is more like g_mn=0, so no spacetime is there. In order to recover GR as we know it, one needs to specify a backgound around which one wants to expand, essentially by putting some non-zero g_mn in by hand. Only then one can try to see what a graviton propagator etc looks like, namely by expanding around this ad-hoc background.
It is (for me) an open question what the admissible choices are, certainly flat space should be an allowed possibility. AFAIK is has not yet been proven that flat space is a solution to LQG at all. As often said, showing that that graviton propagator comes out right it is a necessary, but by no means a sufficient condition, as the 2-point function just captures the free theory.
Some ppl seem to claim the LQG ought to be background independent and thus be able to “dynamically decide itself” what the backgound is supposed to be; but how can this ever be possible without additional input. Namely in particular our whole universe should be an allowed solution, including the gravitational fields of us sitting in front of our computers, residing on Earth orbiting the sun; etc. Roughly the whole solution space of GR (plus whatever is necessary to make the theory quantum mechanically consistent) must be allowed vacua of any theory of gravity incl LQG.
The theory can’t know by itself what solution to choose, so it must be told by specifying boundary conditions or a boundary state in LQG. So roughly the necessary, fixed choice of g_mn in string theory is replaced in LQG by a choice of boundary conditions that induce the desired background g_mn in the low-energy limit. But what are then the rules that determine or constrain the admissible boundary conditions?
This is the landscape “problem” in disguise, since one has to specfify as extra data what semiclassical long distance limit g_mn one wants to talk about. This landscape “problem” is actually not a problem and never was. The multitude of possible solutions must be a property of any theory of gravity. So the question is what LQG can possibly add here. One thing LQG might be able to do in principle at some point (and which is not possible in the standard world-sheet formulation of string theory), is to compute transition amplitudes between certain such boundary conditions. However, not all boundary conditions, or space-times g_mn seem to be allowed, which restricts the usefulness of this kind of ideas. See the review by Rozali on background independence for further details.
Are you saying the AdS/CFT is an alternative formulation of quantum gravity other than string theory and LQG, but AdS/CFT has anti-desitter spacetime with negative curvature which doesn't describe our universe at all. Unless you are saying that perhaps a future version of Ads/CFT with the right positive curvature can describe our universe?
AdS/CFT is non-perturbative string theory. I don't know if a future version of something like AdS/CFT can describe our universe, but I hope there will be.
I know AsD/CFT is non-perturbative string theory. But it describes negative curvature which doesn't describe our universe at all. So you are saying that if in the future we can't find any AsD/CFT that doesn't describe our universe, then the dual idea is refuted. Also an actual AsD/CFT would be sD/CFT but then the analogy or duality no longer holds because the antidesitter thing is done. So why is there high hopes reserved for the AsD/CFT programme?
Well, you study what you have, and learn from it. The first relativistic theory of gravity was Nordstrom's. Einstein studied Nordstrom's scalar gravity on flat spacetime, reformulated it as a curved spacetime equation, and formulated the correct tensor theory. Similarly, AdS/CFT is the first complete theory of quantum gravity, so maybe by studying it, we can learn what the correct theory is.
You are kinda saying that in the end, our universe may be described by something like "Michael Talbot's The Holographic Universe?
https://www.amazon.com/dp/0062014102/?tag=pfamazon01-20
It's bizarre but this seems to be what our quantum gravity programme is pointing to... because if we can find the right version of AsD/CFT, it would be "The Holographic Universe" as described Talbot.
suprised said:
Well I believe the story is roughly like follows ... .
I think you are right to approx. 99%, so it's unnecessary to comment on these 99%, and it's better to avoid any comments on the 1% in order not to confuse the reader with minor details.
We have been focusing on the idea of spin-2 fields plus flat spacetime = curved spacetime and applying this even to String theory. But have we forgotten that the compactified dimensions in String Theory are really 6 dimensions? Unless you are saying the 6 dimensions are flat? How does one resolve this?
In the standard formulation in ST one introduces a spacetime metric. Some decades ago this was typically "4-dim. Minkowski spacetime" * "6-dim. compactified Calabi-Yau space"; in the meantime other geometries have been discovered and are studied extensively.
From ST one can derive a consistency condition for the spacetime on which strings are propagating. This consistency conditions requires Ricci-flatness and forbids arbitrary spacetimes and arbitrary compactified dimensions; Minkowski spacetime * Calabi-Yau is a typical solution, but as I said, others are possible, and in the meantime string theorists were able to relax these conditions.
The problem I see with string theory is that "spin-2 fields plus flat spacetime = curved spacetime" does not really work; you have to chose are curved spacetime in the very beginning and study propagation of strings as "weak distortions" on top of it". But these strings do never change the whole spacetime dynamically, it always stays in some fixed subsector which does not change dynamically. This holds afaik for other approaches (e.g. branes, fluxes, ...) as well.
This is what is called background dependence and is basically due to the approach "fix a background and then quantize small distortions". LQG tries to get rid of this problem and avoids to fix a classical background. But as suprised explained, one still has to introduce some kind of boundary condition or background when doing physics; it's not required for the definition of the theory (and that's a major step forward), but it's required for detailed calculations (e.g. when studying black holes in LQG one has to define an isolated horizon classically; a full dynamical setup w/o any input like boundary conditions or background is not possible).
Well. So String Theory is about Spin-2 fields on curved spacetime? Isn't it redundant? Why produce GR from string modes in background that is already curved. Perhaps the original curved spacetime is not GR and strings are looking for modes to produce GR? Isn't this kinda contrived and redundant?
I was reading the book "Philosophy Meets Physics at the Planck Scale" today and some stuff there opened my eyes. In the book. There are 3 main quantum gravity programmes.
1. Particle Physics approach
2. String Theory
3. Canonical Quantization or LQG
The Particle Physics approach is the one that treats spin-2 field in flat spacetime = curved spacetime. Not String Theory. For 5 years. I thought String Theory was about it. According to the above mentioned book:
"The perturbative superstrings programme involves quantizing a classical system; but the system concerned is not general relativity, but rather a system in which a one-dimensional closed string propagates in a spacetime M (whose dimension is in general not 4). More precisely, the propagation of the string is viewed as a map X : W → M from a two-dimensional ‘world-sheet’ W to spacetime M (the ‘target spacetime’). The quantization procedure quantizes X, but not the metric γ on M, which remains classical."
The above suggests string theory is not about spin-2 on flat spacetime. Can anyone confirm this (or is there any objections?). The above says string theory is about quantizing the map X : W → M. Does anyone have other ways of saying it that can make it clearer? Or website links that specifically details this particular aspect? How do you connect it to Spin-2? Could it be possible that this world-sheet and dimensions not 4 somehow produce the predictions of spin-2 over flat spacetime. Is that what the above is saying or suggesting?
Tom, you mentioned above about the consistency conditions forbidding arbitrary compactified dimensions. Why, isn't the Calabi-Yau an arbitrary one? What is your example of "arbitrary" compactified dimensions?
Thanks.
String theory is about quantization of strings; but one finds one oscillation of a closed string that corresponds to a massless spin-2 particle which is then identified with the graviton. There is a limit in which string theories reduce to quantum field theoirs of poiintlike particles; this limit is a supergravity theory containing gravitons, gravitinos (and a lot of other stuff). In that sense ST contains gravitons.
The consistency condition is Ricci-flatness. CY are Ricci-flat and are in that sense not arbitrary.
After hours of checking at the web sites and reading old achives. I found this great site that derives it:
http://motls.blogspot.com/2007/05/why-are-there-gravitons-in-string.html
"If the worldsheet theory is consistent as a string theory, it must be scale-invariant, and the spacetime geometry must thus be Ricci-flat! We have just derived Einstein's equations from scale invariance of a two-dimensional theory."
It didn't mention about Calabi-Yau. But these are supposed to be 6 dimensional. I wonder how they could be Ricci-flat. It's like one has spike balls, how can it be flat.. unless you are saying since they are so tiny, they look flat at larger scale even though they are like spike balls?
If someone can explain too. Please do so. Thanks.
look at a two-torus T²; the embedding in R³ doesn't seem to be flat, but mathematically it's possible (w/o considering an embedding) to a define an atlas consisting of flat metrics on T².
http://img715.imageshack.us/img715/963/doubletorusillustration.jpg
Is the above an example of a two-torus? How does "one define an atlas consisting of flat metrics on T²"? In Calabi-Yau, there are 6 dimensions with 6 different axis.. how do you make it flat, maybe from looking at a distance very far? Thanks.
I found the best explanation about it here.
http://universe-review.ca/R15-26-CalabiYau.htm
Thanks for pointing out that manifolds that is not flat can really be flat. It's counter-intuitive that was why I missed the concept in all the years I read Brian Greene books.
I guess the reason they make it ricci-flat is so that it can satisfy the condition "ricci-flat plus spin 2 graviton field = General Relativity. But then. Since it can't even describe the FRW Universe. What good is it I'm wondering??
unfortunately that's not a two-torus but a two-fold or double torus; in T² the "2" means two-dimensional ;-)
a two-torus T² can be defined as tupels (x,y) in an interval ]0,Lx[ * ]0,Ly[, i.e. R² with a grid where all points (x+mLx,y+nLy) etc. (with integers m, n) are identified; the flat metric is nothing else but the standard metric on R²
atyy said:
The curved spacetime of a Schwarzschild black hole is Ricci flat.
String cosmology doesn't seem that well developed, but here are some recent reviews.
McAllister, Silverstein String Cosmology: A Review
Burgess, McAllister Challenges for String Cosmology
I've been trying to read the two papers for half hour already but I can't seem to get the essence. The reasons we created all those Calabi-Yau is to simulate the ricci-flatness so that the particle physics approximation of flat spacetime + spin-2 field = curved spacetime can work. But in cosmology like inflation and FRW model... it doesn't support those approximation at all. So how do strings deal with it? By doing away with Calabi-Yau and using branes? How? Maybe you or someone can just give an enlightening pointer of strings plan to resolve it. Like could strings be trying to explain them by not resorting to the ricci-flat path and directly from strings mode to cosmology spacetimes? Thanks.
  • #31
You have gotten it all mixed up (here and pretty much everywhere)! First of all, the reason none of this material makes any sense to you (when explained by multiple parties) is b/c you haven't heeded my advice to start from the beginning. For instance, chapter 1 of Misner, Thorne, Wheeler or some other undergraduate level book on general relativity.
What's happening is you are confusing several different english words, that are utilized in different physical and mathematical contexts. Unfortunately its often the case that these things have multiple meanings in quite different situations. Worse, you are doing this with posts on physicsforum and other places on the internet where the word choices/phrasing aren't necessarily as polished as a textbook.
When a physicist reads a paragraph written in english about some physics subject, what he has in mind is a sort of substition (this is referring to a calculation that is done on page xx of book/paper or blackboard yy). Even there it can be a little bit ambigous and another reader will ask for clarification in a very particular way where it is clear that both parties are on the same wavelength.
What you are doing is grouping together words and concepts and trying to develop an abstract intuition about the physics. Well, believe me, you can stop right there b/c it won't work. It has not worked for the greatest geniuses of our time. The only way to learn this material is the hard way. ok?
Now.. If you really, really want to talk about in what sense and how linearized gravity works, I will be happy to explain. But only if I know you have done some groundwork first (this means knowing what a metric is, what gravitational waves are, what initial value formulations of GR are, and so forth aka a mastery of the first 18 chapters of the aforementioned MTW)
  • #32
I agree with you of course. As the details are what can make me comprehend 100%. But laymen just want to get a general feel of it all. And thanks to an interesting old thread where you participated intimately. I got the superficial grasp. Above I was asking about how GR came from strings, not about linearized gravity. After 3 weeks of discussing linearized gravity that spans many threads and more than a dozen people. Of course I got the basic of it. Basically the idea is that the correspondence between GR's curved manifold and a model using a flat manifold plus a spin-2 interaction has only been shown for weak gravity in a region small enough that the two manifolds can be put into 1-to-1 correspondence. This doesn't work for FRW. And I've been wondering for two days how strings can handle FRW. I'm also reading Tong paper you shared in the classic old thread:
https://www.physicsforums.com/showthread.php?t=495351
"General Relativity from String Theory"
I have read the thread twice and will do it again and again for the next few days.
You mentioned in #7 there:
After compactification, and integrating out the matter modes and taking the hbar --> 0 limit, the result is 4 dimensional Einstein Hilbert lagrangian. Solving the Euler-Lagrange equations yields Einsteins field equations in vacuum exactly.
This is completely analogous to the derivation in MTW where a spin 2 field and a weak field expansion is shown to reproduce the EFE exactly. Here though, the consisteny criteria are already staring at you in the face on the worldsheet. There is nothing else that string theory can limit too, it always must have the EFE's in the IR exactly!
And you detailed it in #9:
Tong explains it perfectly. You start by fixing a background on the worldsheet, and demanding that the quantum theory be conformally invariant (eg that the beta functions vanish). After a calculation you find a set of equations or requirements that must vanish.
Up to this point, everything is perturbative to a given order and fixed.
Now you switch perspectives, and ask, what is the low energy effective lagrangian over spacetime (as opposed to the worldsheet) that gives those beta functions as equations of motion.
And you are led to the EH lagrangian. This last step is decidedly not perturbative, it is not fixed, it is simply a statement that in the hbar --> 0 limit (which takes care of all the 2+ loop corrections from the worldsheet), that the EFE's are the only possible equations of motion that reproduces that lagrangian classically. All you then need to do is show that it is unique. Which is a classical theorem by Hilbert, and you are done.
The bottomline is that there is no controversy that string theory gives GR in the low energy limit. It is basic textbook material!
(edit: The action here is indeed 26 dimensional, and strictly speaking this is the Bosonic string. The real calculation would involve compactification on the Superstring (eg 10 dimensional), and obviously it is a little more subtle with a lot more notation. But the actual proof goes through in a completely analogous manner, except there you won't derive pure GR, but rather supergravity (and then you have to worry about how to break supersymmetry))
Brilliant! Later in the thread, in msg# 50. Finbar mentioned thus:
qsa makes a good point. If we go by Tong's calculation string theory is only consistent in strictly Ricci flat space-times. Since evidence(accelerated expansion) points to us living in de-sitter space we must need to find some degrees of freedom(modes of the string), other than gravitons, which form a coherent state corresponding to de-sitter space.
Anyone know if this has been achieved??
You didn't comment on it. So maybe you agreed on the statement that something besides the gravitons modes of the string can form a coherent state corresponding to de-sitter space? This is my only question to you for this year before I started MTW for the next 2 years.
tom.stoer replied to Finbar statements above:
I guess this is a fundamental problem, namely that in a certain sense background independenca means something different in string theory. One has to prove for a certain background that a consistent quantization can be achieved. And this has to be done for each background seperately. Therefore the background (or let's say the class of backgrounds) changes the d.o.f.
I mentioned this because I can't figure the acronym "d.o.f.", what is d.o.f.? Depth of Field? I really need to know this because that old thread is a classic and it would be on my mind a lot.
tom.stoer ended it thus:
The problem is that one should somehow categorize backgrounds in terms of something like "classes" or "superselection sectors". Different sectors may or may not be "connected" by dynamics. In string theory the specific background can affect the details of the degrees of freedom living on it.
I see the following problems:
- one has to identify the correct d.o.f. for each background (sector)
- there may be backgrounds (sectors) which cannot be equipped with a viable string theory
- dynamically connected backgrounds (sectors) cannot be studied coherently if they have different string d.o.f.
Now the question is how to construct viable string theories for certain classes of backgrounds relevant in GR, especially
- dynamical collaps, e.g. pre-Schwarzschild and pre-Kerr
- FRW, dS, ...
So the question in my message previous to this was answered by tom last year. That we may need to to "construct viable string theories for certain classes of backgrounds relevant in GR, especially
- FRW, dS"
Now. Haelfix. I don't disagree with you that I read MTW book for the next one year. And I'm not looking or asking for any more details now if you don't want to ask more. I just want to know if you agree with Finbar and Tom above because in that old classic thread. You didn't respond to them. So you agreed with them? This is all I need to know at this point in time and I know I won't ask more questions before I mastered MTW book.
And Tom or others. Don't forget to tell me what is d.o.f. Many Thanks to all.
  • #33
d.o.f. = degree of freedom ;-)
1. What are gravitons in loop quantum gravity?
Gravitons are hypothetical particles that are believed to be the carriers of the force of gravity in loop quantum gravity. They are thought to be the smallest units of gravity and are responsible for the interactions between particles in the theory.
2. How do gravitons fit into the loop quantum gravity theory?
In loop quantum gravity, spacetime is believed to be made up of tiny, discrete units called loops. Gravitons are thought to be the fundamental building blocks of these loops, and their interactions with matter and other particles create the fabric of spacetime.
3. Can gravitons be detected?
Currently, there is no experimental evidence for the existence of gravitons. However, some scientists believe that they may be able to indirectly detect them through their effects on the fabric of spacetime.
4. How do gravitons differ from other particles?
Gravitons are unique in that they have no mass or charge, and they only interact with other particles through the force of gravity. This makes them very different from other particles, such as photons, which have mass and can interact through the electromagnetic force.
5. What is the significance of gravitons in loop quantum gravity?
Gravitons play a crucial role in loop quantum gravity, as they are believed to be the key to understanding the nature of gravity at the quantum level. By studying their behavior and interactions, scientists hope to gain a deeper understanding of the fundamental workings of the universe.
  • Beyond the Standard Models
