Induction, magnetism and conductivity‏
In summary, the induced electric current in a conductor wire due to relative motion with a permanent magnet is not affected by the type of conductor. However, the current that flows in the wire can be affected by the magnetic properties of the conductor. In order to maximize current flow, the magnetic field inside the conductor must be constant according to Faraday's law. The magnetic properties, such as paramagnetic index, can impact the amount of current produced. Whether two materials with different paramagnetic indices can have the same conductivity is unclear.
MarkoniF
56
Relative motion between a permanent magnet and a conductor wire produces electric current in the wire. Would induced electric current be greater in a wire made of "magnetic" material like iron, "non-magnetic" material like copper, or it doesn't matter? In other words, is there relation between material magnetic properties and its inductivity? And similar but I think different question, is there relation between material magnetic properties and its conductivity?
How come magnetic field of a permanent magnet can interact with magnetic fields inside a wire that is overall magnetically neutral? Does the same thing happen with electric fields, so if instead of permanent magnet we had some electrically charged object, could we also induce electric current in a conductor wire by their relative motion?
I am not sure what you mean by "inductivity".
The induced emf in a conducting loop depends on the time rate of change of the magnetic field through the area enclosed by the conducting loop (Faraday's law). So induced emf has nothing to do with the type of conductor. The current that flows in the conducting loop in response to that induce emf does depend on the type of conductor. In order to maximize the induced current you would want to minimize the factors that impede current flow in the conductor. How would you do that?
AM
I was referring to Faraday's law of induction. The question is whether the amount of induced current would be greater in a wire made of iron or copper, as measured in volts and amperes.
Does that mean induced EMF would be the same for copper and plastic wire? Electromotive force doesn't seem to be what I'm asking about. I'd like to know the difference we would measure in different types of conductors in units of volts and amperes.
That's the question I'm asking, but it doesn't seem to be simply proportional to material conductivity or resistance. Both conductivity and magnetic properties, such as diamagnetic or paramagnetic index, are related to unpaired electrons or "free electrons". So to rephrase the question, having two wires made of a material with the same conductivity would amount of induced voltage and/or current (volts/amperes) be greater in the material with greater paramagnetic index? The other, perhaps the same question, is whether two materials with different paramagnetic index can have the same conductivity?
Welcome to PF by the way!
Yes. That means the induced emf around the wire loop is determined not by the type of wire but by the rate of change of the magnetic field and the area enclosed by the wire.
The emf does not depend on the type of wire. The current produced by the wire does. If the wire is plastic, the conductivity is 0 so the induced emf produces no current.
I am not sure what you mean by diamagnetic or paramagnetic index.
If you are asking if the induced emf depends on the wire, the answer, as I have said, is no. The current that flows in the wire due to that emf does. The current can be affected by the magnetic properties of the conductor. In order to maximize current flow, the magnetic field inside the conductor must be constant (that is just from Farraday's law). There are quantum effects that actually eliminate the magnetic field inside the conductor in order to achieve superconductivity.
AM
It's susceptibility of a material to respond to external magnetic field, or more precisely said I think what I'm talking about is called "permeability". For example, copper has lower paramagnetic index than iron, which means iron would be more attracted to external magnetic field than copper.
Let me put it this way. We have two equally long wires, one made of copper and the other made of iron, but the iron wire is thicker so that both of them have the same conductivity. We attach voltmeter and ammeter to each wire and then we move permanent magnet next to one and then next the other in exactly the same way. You say the reading of volts and amperes would be the same for both wires?
It seems to me there are more factors that would come into play than just conductivity, like the number and strength of magnetic fields per volume of substance that would be available (unpaired) to interact with this external magnetic field. But also not all of those magnetic fields would interact in the same way. Some would be due to electron spin and some would be due to electron orbits, some would repel while others would attract, so depending on how many of them there are, how "free" they are to move, and depending in what direction they prefer to move, on average and relative to that external magnetic field, it seems it would result in greater or less induced electric current. But then what I just described could be the same thing what defines conductivity as well, and if so it would all boil down to be the same after all. In any case the situation is very complex, especially considering the temperature and heating of the substance would be a factor too, so I'm afraid the answer I'm looking for is specific and experimental rather than general and theoretical.
In your example there would appear to be no current because there is no circuit. Let's use two same sized loops of each kind of wire. A magnet passes through the loops.
Are you suggesting that since the iron wire has a higher permeability, the magnitude of the magnetic field changes inside the iron wire will be somewhat greater than in the copper wire?
Just applying Faraday's law, one can see that this would tend to increase the induced emf in the iron wire, and, therefore the current. But the increase would be in proportion to the area of the wire loop itself (the diameter x length of the wire) compared to the area enclosed by the wire loop. If you are making the diameter of the loop much larger than the diameter of the wire, it should not be significant.
AM
AM
But if the loop resistance is very small its own magnetic field affects the loop emf. The flux in the loop is a combination of the external field plus the internal mag field inevitable when current exists. If the loop R value is small in comparison with the self inductance reactance of said loop, then the emf around the loop decreases. But if R >> XL, then R has negligible influence on the emf around the loop.
Claude
The circuit would be closed by connecting voltmeter at the ends, but loop is fine too.
I think yes, if by that you mean what I mean.
I'm not sure what you just said. Let's make it a bit more clear and take both iron and copper wires to have the same length and the same thickness, but if permeability plays any role, could that then compensate for the lesser conductivity of the iron wire so that we get about the same amount of induced current in both wires?
You cannot measure induced emf in a conductor with a voltmeter. You would be measuring the emf generated around the entire loop made by the conductor and the leads of the voltmeter, not the voltage across the ends of the conductor.
Faraday's law has some very subtle aspects that cause all sorts of confusion. Professor Lewin at M.I.T. has a very[/PLAIN] good lecture on this that can be found here.
. It can be found on Youtube here (it is easier to navigate in the Youtube version).
The magnetic fields inside the iron wire will have greater variation than in the copper. This will affect the emf in the wire and, hence, current. If the wire diameter/thickness is much smaller than the diameter of the loop, the effect will be rather small. To quantify the effect you would have to give all the dimensions and conductivities etc. and painstakingly apply Faraday's law.
AM
It wouldn't matter to measure the difference, but if you don't want leads of the voltmeter to play any part then you simply extend the ends of the wire further away from the loop(s), or make the leads parallel to the direction of magnet motion.
What equation are you talking about?
So having two equally thick wires with the same conductivity, would greater permeability of one of the wires lead to greater induced current in that wire?
Where do you see connection between Faraday's law and permeability?
It does matter! That point was very well demonstrated by Prof. Lewin. The voltage measured by the voltmeter depends very much on how the leads are configured. The measured voltage depends on how much flux the circuit - which includes the voltmeter leads - encloses! If you extend the leads farther away from the loops the induced voltage will actually increase because the flux enclosed by the circuit increases. If you make the leads parallel to the direction of magnetic motion so that the circuit encloses no flux, the measured voltage will be 0! No one said Faraday's law was simple or intuitive. It is very counter-intuitive.
I wasn't talking about an equation. I was talking about the way iron responds to an applied magnetic field. Since the iron atoms are strong magnetic dipoles, they will align with the applied field so that the magnetic field inside the iron conductor will be greater than the applied magnetic field. Consequently, any changes in the applied magnetic field will result in greater changes of the magnetic field inside the iron conductor.
I seems to me that it would result in a slightly greater magnetic flux enclosed by the iron wire. This in itself would result in a greater induced voltage (slightly) but there are other effects of a magnetic field inside a conductor that tends to decrease conductivity, so I think you will have to do some experiments to determine whether the induced current is greater.
Faraday's law says that the induced voltage around a closed path is equal to the time rate of change of the flux enclosed by the path. The strength of the magnetic field depends on the permeability of the space. That is why you have an iron core in a solenoid or transformer - to create a strong magnetic field.
AM
It does not matter for the difference of induced current between copper and iron wire. If anything about leads changed the measurement, then that impact would be the same for both wires and so it would not matter.
Whether we measure voltage or amperes we would take the same measurement with both iron and copper wire, and the point in that lecture is about two DIFFERENT measurements. It's about two different measurements of the potential difference related to the direction of the current and two different resistors, which is indeed peculiar, so perhaps it's best to just measure amperes instead of voltage, although since we have no uneven distribution of resistance, like they did, we would not need to worry about anything like that.
No, voltmeter leads are not part of the loop, so at best they could contribute a little bit to the induced current, and if they are parallel to the direction of magnet motion they would be completely irrelevant. Also, nothing about voltmeter leads could ever make the voltage be zero if there is some induced current present in the loop, unless you disconnect them. Nothing like that was even addressed in that lecture.
Perhaps, however we are not interested in the changes of the magnetic fields in the conductor, we are interested only in the amount of induced current, and those two could be related, that's what I think too, but assumptions, either yours or mine, are not the answer I'm happy with.
That's what I think, and I could do experiment myself if I only had iron wire and more sensitive instruments.
That's not really what we are talking about, but I do agree it could be related. After all I have quite similar opinion, if not the same, which is why I ask the question in the first place.
But the point is that you are not measuring the voltage between the two points that the voltmeter leads are connected to - ie across the ends of your two wires. You are measuring the integral of [itex]E \cdot dl[/itex] around the loop that the voltmeter and leads form with the conductor.
This is a side issue to the issue you raise about the effect of the permeability of the conductor on the induced current, but it is important to appreciate it. Measuring voltages where there is a time dependent magnetic field present is very different than measuring voltages in a circuit containing a battery and resistance.
If the material did not have any effect on the magnetic field inside the wire then there would be no difference in the voltage that is induced in any same sized loop, whether it is made of copper, iron, aluminum or plastic. The currents will differ depending on the resistance/conductivity of the material, but that is all. As you study Faraday's law it will be easier to see why this is.
But iron does have an effect on the magnetic field, which is the basis of your original question. To determine how it would affect current is very complicated and involves quantum effects as well as Faraday's law.
Physics is not intended to make you happy.
?? It is exactly what we are talking about! The magnitude of changes in a magnetic field, as well as the rate of change, determines the magnitude of the induced voltage in a closed path in that changing magnetic field. Anything that affects the magnitude of the magnetic field (such as the permeability of the region of space enclosed by and included in that path) will affect the induced voltage. That is just a natural consequence of Faraday's law.
AM
Leads don't form anything and have nothing to do with induction loop(s) where induction takes place.
You are reading too much into that lecture making general conclusions from specific examples, thus applying them where they are not relevant at all. The difference pointed in that lecture is only due to having two different resistors and because voltage was measured at two points between them. We don't have any resistors and we do not measure anything directly on the loop. Our setup is like on that picture above, so given the same change in magnetic field we would measure the same amount of voltage regardless of how we connect the leads, only sign could be different.
You are mixing inductor coil with induction loop. First one is to be substitute for moving magnet, you don't induce electric current in inductor coil but supply it and induce magnetic field. We are talking about the second one, induction loop, where the current is not supplied but induced with moving permanent magnet or inductor coil, and the fact that it then creates magnetic field as well is irrelevant for the question which is only about electric current induced as compared between induction loop made of copper and iron. This is not addressed by Faraday's law, and if it is addressed anywhere at all it would be classical electrodynamics, not quantum mechanics.
Answers, not physics. Physics always makes me happy, but answers can make me sad.
You are talking about inductor coil while the question is about induction loop. Faraday's law has nothing to do with magnetic permeability of induction loop, but only with external magnetic field or inductor coil which then induces current in induction loop. Forget inductor coil and iron cores, we don't need any of that as we have moving permanent magnet.
My comments about a voltmeter were with respect to your original suggestion that you measure the induced voltage in a section of a conductor. You had posted:
"The circuit would be closed by connecting voltmeter at the ends, but loop is fine too."
I simply observed that measuring the induced voltage in a section of conductor like that will not give you induced voltage between the two ends of the conductor. It measures the emf around the whole loop comprised of the conductor and the voltmeter leads. That is why I suggested you use loops.
In the above example, the magnetic field enclosed by the voltmeter leads is not significant so a voltmeter will measure the induced emf across the ends of the coil, which is a function of the rate of change of the flux through the coil loops.
If you were replace the coil with a single straight conducting wire and pass a magnet in a direction perpendicular to the direction of the wire (replace the coil with a straight wire and have the magnet moving perpendicular to the page) as you were suggesting, a galvanometer connected as shown in your diagram would not measure the induced voltage in the conductor. That was my point.
Faraday's law is a fundamental part of classical electromagnetic theory. To progress any further you will have to study Faraday's law and induction. Your comments show that you are not inclined to do that. You seem to want answers that fit with how you already view things, so I am afraid I cannot help you.
AM
I does not matter, just the same. Take that same image, it could be no loops up there, just a wire bent in 'U' shape, and leads of the whatever meter could be little horizontal wires at the bottom, far away from the magnet.
I didn't say wire is straight, or that it has to be. But even if it was straight, there would again be induced current and galvanometer would measure. Try it.
As I said, you were mixing two different types of induction loops. I's exactly how I told you, check it out.
There would be no induced current in a straight wire. You need a circuit. That is why I suggested a loop.
If you think it does not matter then apply Faraday's law and tell us what the induced voltage is in a straight conductor of length L as a function of dB/dt.
You appear to be looking for someone to confirm your understanding of induction. In such circumstances, the only help anyone can give you is to suggest that you thoroughly study Faraday's law and then see if you still have the same questions.
AM
You have no idea and yet you make statements as if you are certain about it, that's strange. There would be induced current in a straight wire. Try it out.
http://www.ndt-ed.org/EducationResources/CommunityCollege/EddyCurrents/Physics/inductance.htm
- Faraday's Law for an uncoiled conductor states that the amount of induced voltage is proportional to the rate of change of flux lines cutting the conductor. Faraday's Law for a straight wire is shown below.
http://www.sweethaven.com/sweethaven/ModElec/acee/lessonMain.asp?iNum=0201
- Faraday's Law for a Straight Wire: The amount of induced voltage is proportional to the rate of change of flux lines cutting the conductor.
Help yourself and learn some basics. My question stands, and as I explained it's not addressed by Faraday's law.
http://www.ndt-ed.org/EducationResources/CommunityCollege/EddyCurrents/Graphics/faradays%20law1.jpg
Ok. I can see where the problem arises. There is a lot of misinformation and large misunderstandings out there about Faraday's law, as Prof. Lewin mentions. It is not your fault. Your attitude, however, could use a improvement if you are serious about learning physics. I don't mind, but others on PF will take you to task for it!
A lot of 'theory' written for high school students and engineers is wrong or at best confusing or misleading and it is difficult to sort out what is right and what is wrong.
I am not sure where this idea originates that the voltage induced in a wire is determined by the number of lines of flux per second 'cut' by the wire. Faraday's law states that the voltage induced around a closed path is equal to the time rate of change of the magnetic flux through a surface enclosed by the path:
[tex]\oint \vec{E}\cdot \vec{dl} = \frac{d}{dt}\int \vec{B}\cdot d\vec{A}[/tex]
Engineers may have developed a short-hand conceptual way of thinking about this using flux 'cutting' a conductor but you should stick to Maxwell's version because it is always correct and clear. The engineering approach appears to have made its way into high school and engineering texts but, in my view, it is confusing if not wrong.
For starters, it suggests that a current can be induced in a conductor that does not form part of a circuit. The authors certainly know that cannot happen but that is a conclusion that might be drawn from what they have written.
But here is the real problem with that explanation. Flux is magnetic field x area. So the rate at which flux 'cuts' a conductor involves some concept of a magnetic field and area. It is not clear what the area part is.
If you take a square loop of conductor wire and accelerate it through a uniform magnetic field each side of the loop will 'cut' lines of flux at an increasing rate. But the voltage induced in the wire is always 0 according to Faraday's law because the rate of change of [itex]\vec{B}\cdot \vec{A}[/itex] through the area enclosed by the loop is necessarily 0. Now, of course, using the "rate at which the conductor cuts lines of flux" approach you would say that is because the directions of the voltage in each of the opposite sides is the same so they cancel each other out. That works. But I am not sure that it is correct.
I will start a thread and get some discussions going on this point, which is an interesting one.
AM
AM
Actually, a straight wire such as a dipole antenna when subjected to a time-varying magnetic field of high enough frequency will have induced current. A closed path or loop is not needed for current to exist. I'm old enough to remember 1970's cars equipped with windshield antennae. They were 2 L shaped wires not touching, neither wire forming a closed loop. Current was induced into the wires. Look it up, current does not need a closed path in the ac domain. It's called displacement current.
Claude
It's not just a theory, it's reality. You can induce electric current in a straight wire by moving permanent magnet around it. Try it out.
What are you talking about? You seem to have problem visualizing how a straight wire can be a part of a circuit.
No, that's not correct. Direction of the current would not be opposite at opposite sides, it would be either clockwise or anticlockwise along the whole loop.
You are quite correct that a current does not need a closed path in the ac domain - but an induced current does. An electric dipole antenna is a good example.
My understanding is that the electric dipole antenna responds to the electric vector in the electromagnetic wave. In other words, the current flows in response to the time-dependent electric field of the electromagnetic wave, and is not induced by the time-dependent magnetic field. The antenna must also be coupled to a capacitor, otherwise there would be no flow at all.
My understanding is that the same applies to the displacement current. The displacement current derives from Ampere's law not Faraday.
AM
You can certainly induce a current in a straight wire by moving a magnet around it, provided the straight wire is connected to a circuit that encloses the magnetic flux of the magnet (ie. encloses an area through which there is some component of the magnetic field at right angles to the area). I think I have made that part clear.
The physical direction would be the same (eg. left to right) but since they form part of a circuit this would be in opposite directions around the circuit. In the example I gave, there is no current because there is no change in the magnetic flux enclosed by the loop.
AM
No. Try it, learn it.
No. That's terribly wrong. There is no any left and right or up and down, only clockwise and anticlockwise.
Here's an example of a current being induced in a straight wire in an experiment by Faraday. The straight wire is part of a circuit but the only effectively moving part is the straight wire. The sides and bottom don't "cut" the field lines as the wire is flipped over. The magnetic field is, in this case, supplied by the earth:
Michael Faraday said:
171. A piece of common copper wire, about eight feet long and one twentieth of an inch in thickness, had one of its ends fastened to one of the terminations of the galvanometer wire, and the other end to the other termination; thus it formed an endless continuation of the galvanometer wire: it was then roughly adjusted into the shape of a rectangle, or rather of a loop, the upper part of which could be carried to and fro over the galvanometer, whilst the lower part, and the galvanometer attached to it, remained steady (Plate II. fig. 30.). Upon moving this loop over the galvanometer from right to left, the magnetic needle was immediately deflected; upon passing the loop back again, the needle passed in the contrary direction to what it did before; upon repeating these motions of the loop in accordance with the vibrations of the needle (39.), the latter soon swung through 90° or more.
http://www.gutenberg.org/files/14986/14986-h/14986-h.htm#toc_8
So you are telling us that Faraday's law is wrong?
There is no current. You have to read carefully what I wrote. I gave the example of a rectangle of wire sitting in a uniform magnetic field with the plane of the wire is perpendicular to the direction of the magnetic field. The rectangle is accelerated in a direction parallel to the plane of the wire. There is no induced current because d∅/dt is 0 ie. BA = constant. So Faraday's law says that there is 0 induced emf around the circuit and no current.
Now the "rate at which the conductor cuts flux" explanation would say that the leading edge has an induced voltage (eg. say clockwise - it depends on the direction of B and the acceleration) and an equal induced voltage in the trailing edge (which is necessarily counter-clockwise) in order to achieve that 0 current. Same result but a bit different explanation. The question is whether this is a correct model of the physics.
AM
AM
I can't believe what you're saying. Have you had formal e/m field theory classes? Induced current needs no closed path at all. An antenna current is induced. As far as electric & magnetic fields go, they are inseparable, as under ac conditions, neither one can exist w/o the other. The E & B fields both exert a force on the charges in the antenna loop. B exerts normal force, E exerts tangent force.
It is indeed induced. Is it induced by E or B is a moot question as they cannot exist alone. A good example is a static example where a pair of plates is charged forming a capacitor. A wire loop is inserted in between the plates. There is an E field between the plates due to charge polarization on the 2 plates. Said E field moves charges in wires so as to create polarization. The electrons move towards the positive plate & vice-versa. But current does not circulate in the loop.
Here we have charges moving under E w/o a B force, but continuous current is zero. The E field has no curl because no varying B is present. If the same loop is immersed in a time-varying B field (magnetic), the associated E field has curl, aka "rotation". Here charges circulate in the loop due to this type of E field. But a rotational E field does not exist w/o a time-changing B field. The charges flow in the loop due to both fields, E & B. E moves an electron tangentially, but in the case of the loop in between cap plates, E alone will not produce circulation. The B force is normal to charge particle velocity keeping it in a circulating motion.
To say that induction is due solely to E or to B is incorrect because you need them both. When we say that induction happens when the magnetic field is time varying, it is implicit & understood that there is an accompanying E field which exerts the tangential force needed for charge circulation. "Induction" does not imply that E is irrelevant.
As far as antennae needing to connect to a capacitor, that is incorrect as well. Any wire has capacitance between itself & the reference node, i.e. ground. Also, a dipole antenna in space has finite area in the ends of the wires, forming a capacitance.
A time varying B field is always accompanied by a non-zero rotational E field. Each field exerts a force on free charges in the loop moving them around the loop. They both are involved, E & B, neither being more or less important. The loop need not be closed, as some capacitance is always present. Induced current exists in an open or a closed path.
Claude
It is indeed induced. s it induced by E r B is a moot question as they cannot exist alone.
We were talking not about an antenna loop but a straight antenna wire. Perhaps you could explain how a stationary charge responds to anything but an electric field? Once a current starts flowing the charges will interact with the magnetic field through the Lorentz force. Is that what you are referring to?
But there is an electric force on the charges. Since the charges within the conductor distribute themselves to create equipotential surfaces in the wire and 0 field inside the conductor, I am not sure why anyone would expect a current. If the polarity of the plates kept changing (fast enough), would there not be tiny charge oscillations?
In fact the E field is related to the time dependent B field by Faraday's law:
[tex]\nabla \times \vec E =-\frac{\partial \vec B}{\partial t}[/tex]
I understand that. The antenna issue is a side issue to the point we were discussing and I will concede that I have not spent a lot of time studying antennas.
The point we have been discussing is whether one can measure the emf (or E field x length) induced in a straight conductor by passing a magnet near it by attaching a voltmeter of some kind (eg. galvanometer). My point was the induced voltage measured by a voltmeter depends on how you configure the leads and, in particular, an area enclosed by the leads and the conductor and the orientation of that area to the direction of the magnetic field. The voltage reading that you get depends on the way you connect the voltmeter. That was the point that seems to make MarkoniF apoplectic but it is just an obvious consequence of Faraday's law. If I am wrong on that, perhaps you could enlighten me.
Quite correct. I was trying to point out that the current flow requires capacitance which, in my understanding, is why capacitors are coupled to an antenna - to get a detectable current (other capacitors are needed to create a resonant circuit for tuning frequencies but that is a different function).
AM
This is an illustration of Faraday's law but it is also easily explained by the Lorentz force or Lorentz field (v x B) because you are moving the free charges in the top wire in a direction that is not parallel to the direction of B so v x B is non-zero. Since the charges are free to move around the circuit, the v x B E-field produces current in the wire which is detected by the galvanometer.
In the situation proposed by MarkoniF the wire is stationary and you draw a magnet past the wire. So there is no v x B electric field. Explanation requires Faraday's law. When applying Faraday's law, it becomes apparent that the length and orientation of the other wires will affect the reading on the galvanometer. So the galvanometer or voltmeter cannot be used to determine emf induced in the straight section of wire. The galvanometer reading reflects the induced emf in the entire loop.
AM
Don't you have a voltmeter, piece of wire and a magnet? Try it out and you will see. How else do you expect anyone shall convince you? I already gave you two links that confirm current can indeed be induced in a straight wire. You think people around the world just hallucinated that and came up with the same equation? Here is some more:
http://www.patana.ac.th/secondary/science/anrophysics/ntopic12/commentary.htm#inducedemf
- "The induced electromotive force across a conductor is equal to the rate at which magnetic flux is cut by the conductor."
- "Faraday's Law for an uncoiled conductor states that the amount of induced voltage is proportional to the rate of change of flux lines cutting the conductor. Faraday's Law for a straight wire is shown below."
http://www.kean.edu/~asetoode/home/tech1504/acdc/ii.htm
- "The amount of induced voltage is proportional to the rate of change of flux lines cutting the conductor."
http://www.schoolphysics.co.uk/age1...nduced_emf_in_a_straight_conductor/index.html
- "When a straight conductor is moved through a magnetic field an e.m.f. is induced between its ends."
http://www.saburchill.com/physics/chapters/0059.html
http://www.xtremepapers.com/revision/a-level/physics/electromagnetic_induction.php
http://ebookbrowse.com/induced-emf-in-a-straight-conductor-doc-d258502729
You just need to "cut through flux lines". So if you move that wire up-down there will be induced current, but not if you move it left-right.
  • #31
Faraday's law is a fundamental part of electromagnetic theory. If you think I am failing to appreciate that, you are mistaken. You do not seem to be able to read or to understand what I have written.
AM
1. What is induction?
Induction is the process by which a changing magnetic field induces an electric current in a conductor.
2. How does magnetism work?
Magnetism is a force that is created by the movement of electrons. When electrons move in the same direction, they create a magnetic field.
3. What is conductivity?
Conductivity is the ability of a material to allow the flow of electric current. Materials with high conductivity, such as metals, allow electric current to easily pass through them.
4. How are induction and magnetism related?
Induction and magnetism are closely related because a changing magnetic field can induce an electric current in a conductor, and an electric current can create a magnetic field.
5. What are some real-life applications of induction, magnetism, and conductivity?
Some real-life applications of these concepts include generators and motors, which use induction to convert mechanical energy into electrical energy, and vice versa. Conductivity is also important in the functioning of electronic devices, as it allows for the flow of electricity through circuits. Magnetism is used in many everyday items, such as speakers and hard drives, which use the magnetic properties of materials to function.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
