Inflation as a solution to the Early Universe Enrtopy problem
In summary, the conversation discusses a paper mentioned by Chronos that proposes a solution to the issue of inflation not being able to explain the arrow of time. The paper argues that taking into account quantum effects, specifically quantum entanglement entropy, can explain how inflation can start. Some people have raised concerns about the validity of this argument and its implications for other models such as CCC and the Carroll/Chen model. The conversation also briefly discusses the possibility of LQC providing a solution to the inflation problem.
skydivephil
474
I really think this paper
http://arxiv.org/abs/1212.1087
which Chronos mentioned in another thread deserves its own thread. Has anyone had a chance to look at it? what do you think? This has been a lot of noise about this issue raised by people like Roger Penrose and Sean Caroll . They have come up with the some pretty , shall we say, creative ideas such as CCC and the Caroll/Chen model to deal with this issue. But if this paper is right they are not required.
Space news on Phys.org
It certainly is an interesting idea, i.e. to appropriately take account into quantum [entanglement] entropy. But personally I don't believe the problem is quite solved. Recall that the problem we had was how to get inflation started in the first place. It may be true that indeed the probability of inflation does somewhat increases if we were to take into account various quantum effect. However part of the argument in the paper relies on the fact that inflation is always accompanied by particle horizon [and so there is entanglement entropy of stuffs beyond and in the horizon]. However, that means inflation has already started! One can of course think of some other way out of this and show that inflation can indeed happen once all quantum effects are properly taken into account; so I do feel that it is a fresh idea in the field.
At first glance, it sounds a bit unlikely. The claim is that inflation itself lowers entropy over time, which is another way of stating that they're using an invalid measure of entropy.
That said, I don't think you should lump in CCC with the Caroll/Chen model. The Caroll/Chen model is fairly reasonable. The CCC model is way, way, way out there.
They are using von Neumann entropy as a measure of entropy, which is the quantum version of entropy. This appears entirely reasonable to me. The Carroll/Chen model, http://arxiv.org/abs/hep-th/0410270, invokes eternal inflation, which has its own issues.
There have been a number of papers which suggest the probability of inflation is 1 in LQC, see here:
http://arxiv.org/abs/0912.4093
http://arxiv.org/abs/1011.4249
So it seems to be possible both of these results are valid, if so might a solution then have been found? BTw on the CCC model and Caroll/Chen models, I was simply trying to ascertain if this paper (perhaps combined with the results in the 2 paper I mention above) removes the need for such models. How reasonable or unreasonable they was not my issue here.
Yes, I am aware that LQC does that, but what I don't understand is: if we accept LQC explanation, then isn't that all there is to it? As long as we can get inflation to start, then what is the problem? [Since the original problem is that inflation itself does not explain the arrow of time because inflation needs even lower entropy to get started, i.e. we need to either explain how the inflation starts despite generic initial condition (which LQC probably does), or explain why the initial state is so different (such as http://arxiv.org/abs/0711.1656v2)] .
The whole point of the paper, as I understand it, is that they are trying to explain how inflation can get started entirely within the quantum entanglement framework.
...of a generalized Chaplygin gas, which is a highly hypothetical material. And stating that they're using von Neumann entropy is a relatively meaningless statement. Von Neumann entropy is merely a counting of the microstates: what matters is what microstates they are counting. An invalid measure of entropy is one in which they count the microstates in an invalid way.
What is your criteria of validness for measure?
Entropy tends to increase over time, following the second law of thermodynamics in the statistical sense as derived from statistical mechanics.
I do agree with you. However in the paper the authors mentioned "We notice that in the literature there are examples of decreasing entanglement entropy [15][16] due to the situation where the system is out of equilibrium or simply from long-range quantum correlation". So I am somewhat confused.
I now understand the paper better after I discussed with the authors [well, actually... one of them is my supervisor and I also know the other two] The point of the paper is to point out that if we take into account entanglement entropy, then according to their way to counting, there is a larger probability for inflation to happen [but if you believe the LQC people, then the problem is already solved]. That is, they don't really aim to explain *how* inflation gets started, merely that there is a larger probability that it *can* happen than traditionally believed by, e.g. Penrose.
As I understand there are two issues that we would like answers to (well obviously more than 2 but 2 related to this thread):
1 how did inflation get started and how likely was that state?
2 why was the entropy of the early universe so low?
From my reading the paper attempts to address question 2 and a paper like Ashtekar/Sloan addresses question 1. So assuming 1 is solved I don't think that means that 2 is solved or am I wrong?
To be frank, I am not sure if explaining inflation is sufficient, but one way to think about the issue is as what McInnes mentioned in http://arxiv.org/abs/0711.1656v2.
Inflation gives us an enormous simplification of the problem of explaining the Arrow. As Huw Price has emphasised [11], we are by no means entitled a priori to assume that the low initial entropy of our Universe was “stored” in a simple way or confined to a single form of matter. Inflation performs precisely this service: it implies that the entire, potentially vastly complicated problem of accounting for the entropy of the early Universe reduces to the single problem of accounting for the initial state of the inflaton. In the words of Lisa Dyson, Matthew Kleban, and Leonard Susskind [12]: "Some unknown agent initially started the inflaton high up on its potential, and the rest is history." In fact, at stake here is the reason why there was any history: if we can understand the "unknown agent", then, thanks to Inflation, we will have a theory of the "passing" of time.
1. What is "Inflation" in the context of the Early Universe Entropy problem?
Inflation is a theoretical concept in cosmology that proposes that during the first fractions of a second after the Big Bang, the universe underwent a rapid expansion, causing it to increase in size by an unfathomable amount. This period of rapid expansion is thought to have resolved several issues in the early universe, including the problem of low entropy.
2. How does Inflation solve the Early Universe Entropy problem?
Inflation proposes that during the rapid expansion of the universe, the energy density of the universe remained constant while the volume increased. This led to a decrease in the entropy of the universe, effectively solving the Early Universe Entropy problem.
3. What evidence supports the concept of Inflation?
Several lines of evidence support the concept of Inflation, including the observed smoothness and homogeneity of the universe on a large scale, the flatness of the universe, and the uniform temperature of the cosmic microwave background radiation. Additionally, observations of the polarization of the cosmic microwave background provide further evidence for the existence of Inflation.
4. Are there any challenges to the Inflation theory?
While Inflation offers a potential solution to the Early Universe Entropy problem, there are still some challenges and unanswered questions surrounding the theory. For example, the exact mechanism that caused the rapid expansion is still not fully understood, and some observations have raised questions about the homogeneity of the universe on a smaller scale.
5. How does Inflation impact our understanding of the early universe?
Inflation has significantly impacted our understanding of the early universe by providing a potential solution to several long-standing problems, including the horizon problem and flatness problem. Additionally, the concept of Inflation has led to further research and hypotheses about the origin and evolution of the universe, helping us gain a deeper understanding of our cosmic origins.
  • Cosmology
  • Beyond the Standard Models
