Register to reply
Conservation of angular momentum
by MechatronO
Tags: angular, conservation, momentum
Share this thread:
MechatronO
#1
May7-13, 11:41 AM
P: 25
Imagine a body that is attached to a massless string and then rotated in such a manner that no external forces like gravity acts on the body in tangential direction.
The body now has the angular momentum with respect to the axis of rotation
Lo = Ro * Vo * m
Where
Ro = constant initial radius of rotation
Vo = constant initial tangential velocity
m= mass of the body
If the string is pulled in with respect to time, and no torque is applied with respect to the axis of rotation would the velocity be this, according to the law about conservation of angular momentum?
V(t)=[itex]\frac{Vo*Ro}{r(t)}[/itex] ?
And would the tangential acceleration then be
a(t)=[itex]\frac{-Vo*Ro}{(r(t)^2)}[/itex]*r(t)' ?
Where
r(t) = the derivate of the radius of rotation with respect to time
If so, could this acceleration be added directly to external forces that is causing tangential acceleration?
The purpose is forwarding a regulator that will control the acceleration of a robot.
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
mfb
#2
May7-13, 01:45 PM
Mentor
P: 11,589
Looks right.
External forces could change r'(t), but if they do not, I would expect that you can add them.
Register to reply
Related Discussions
Angular momentum and conservation of angular momentum problem Introductory Physics Homework 0
Linear momentum conservation vs angular momentum conservation Classical Physics 2
Conservation of Angular Momentum: angular speed Introductory Physics Homework 3
Finding angular velocity using conservation of angular momentum Introductory Physics Homework 2
Law of the Conservation of Angular Momentum > Principle of Conservation of Momentum General Engineering 0
