Register to reply
What are the fundamental methods of generating motion?
by Ngineer
Tags: fundamental, generating, methods, motion
Share this thread:
Ngineer
#1
Nov18-13, 12:55 AM
P: 19
I know that motion today is usually generated by
- generating a varying magnetic field and varying it in relation to a fixed one
- ccombusion engines
Are there other "fundamental" approaches to generate motion, or is that pretty much it?
Your input is appreciated, thanks!
Phys.Org News Partner Engineering news on Phys.org
UConn makes 3-D copies of antique instrument parts
Amazon worker piloted drone around Space Needle
Five next-generation technologies for positioning, navigation and timing
NascentOxygen
#2
Nov18-13, 07:22 AM
HW Helper
Thanks
P: 5,146
hydraulics are behind the movement of many mechanical arms and levers, e.g., ditch diggers, elevators, car brakes, jacks
pneumatics is good for lower-powered but faster acting arms and levers, e.g., air brakes, industrial robots
springs power the movement in older clocks and watches and parking meters
(wind moves sailing vessels and turns windmills)
Bandit127
#3
Nov18-13, 11:50 AM
P: 185
Steam (unless you include that in combustion engines).
Gravity.
Muscle power.
Hologram0110
#4
Nov18-13, 02:51 PM
P: 163
Ejecting mass to create a reaction force (think rockets or ablation) is another one.
Ngineer
#5
Nov18-13, 06:07 PM
P: 19
Very exciting contributions!
Don't Hydraulics merely transfer motion? (as opposed to generate it)
Also, imho, I.C., steam and rocket engines are fundamentally related.
I would then categorize the main methods of generating (continuous) motion as based on:
- Electromagnetism
- Combusion (Steam, jet, etc.)
- Potential (Gravity, springs, pneumatics)
- Other external flow (wind)
And maybe also
- Ionization (plasma)
- Organic (muscle)
Further contributions and corrections are welcome.
Baluncore
#6
Nov27-13, 06:37 PM
Sci Advisor
Thanks
P: 1,749
Expansion or contraction without phase change of a solid, liquid or gas.
Solid = Bi-metalic strip.
Liquid = Thermometer.
Gas = Stirling engine.
Piezoelectric transducer.
Magnetostriction.
Radiation pressure.
Gibsons77
#7
Dec1-13, 12:56 PM
P: 6
In the most general sense, I think when you say "motion" you probably mean work. In this case, work is defined as a force acting over a distance, W=F*d. The units for this are Joules, which is the fundamental unit of energy. According to several laws of thermo. energy cannot be created or destroyed, only exchanged. So by these definitions, all motion is transferred, and none of it is "generated".
Baluncore
#8
Dec1-13, 02:14 PM
Sci Advisor
Thanks
P: 1,749
Quote Quote by Gibsons77
IMO... “motion” means movement, not work.
So, are you are defining the question out of existence?
Or are you saying we live in a perpetual motion machine?
IMO.
An engine converts energy from one form to another.
A mechanism is a mechanical machine that converts one motion into another.
A motor is an engine or mechanism that produces motion.
So is a hydraulic motor a mechanism or an engine?? It converts pressure into motion but the working fluid moves. The pressure in the fluid was originally generated by a moving pump.
Likewise, an electric motor has a moving fluid. Power is also electron pressure times current flow.
Gibsons77
#9
Dec1-13, 09:42 PM
P: 6
Right, but all motion is is the change of position w.r.t. time. Since we're talking about methods of generating motion in the engineering forum, than we have to inherently talk about forces being applied over distances.
So if we're talking about work (or power) than we can break down the types of power sources. These power sources are the "fundamental methods of generating motion". As far as I can tell, we essentially know about every type of power source (I guess except for some futuristic quantum mechanical source).
These things you're talking about; engines, mechanisms, motors, and I can include machines, all have well defined definitions.
Hydraulic motors convert pressure into torque. That makes it to be defined as an actuator, and an actuator is a mechanism. A pump by this logic, is also a mechanism.
I guess to contribute to the thread, nuclear power I think is pretty fundamental. Geothermal sources, which is just simply fluid pressure from a temperature gradient from gravity.
Register to reply
Related Discussions
The future methods of generating electricity? Classical Physics 26
Proof that S is a generating set. Calculus & Beyond Homework 5
Generating Sets Calculus & Beyond Homework 1
Motion of pointed bodies - numerical methods Advanced Physics Homework 0
Numerical methods: Finite difference and spectral methods? Differential Equations 1
