What affects the swing of a pendulum w/ and w/o air resistance
In summary, the conversation discusses hypotheses about what factors affect the swing of a pendulum, including the amplitude, mass of the bob, air resistance and friction, and the length of the thread. The conversation also mentions the equation for simple harmonic motion and how it relates to the questions posed. The main struggle is with hypothesis 2, which asks whether the period is affected by the mass or density of the bob and what conclusions can be drawn from different scenarios. Help is requested in understanding this hypothesis.
The_Lobster
30
I'm having troubles figuring out what affects the swing of a pendulum.
Hypotheses:
1) The period is dependent on the amplitude
2) The period is dependent on the mass of the bob
3) Air resistance and friction will affect the period
4) The period is dependent on the length of the thread
None...
Well, as I've understood so far, hypothesis 1 is wrong, as a higher amplitude will give the bob greater kinetic energy, but the distance it has to travel is longer; hence they will cancel each other out and the period is the same?
Hypothesis 2: This one I'm having most trouble with. Without air resistance, any bob with any mass and density will travel with the same velocity. But with air resistance, is the period affected by the mass or by the density of the bob? Say the mass is constant but the density varies (big wood-bob 0.2 kg, small iron-bob 0.2 kg); will they both travel with the same velocity (w/ air resistance)? What about if the density is the same, but the mass varies (small iron bob 0.2 kg, large iron bob 1 kg)? What conclusions can be raised here? (some explanations as well would be great!)
Hypothesis 3: Well of course I guess? No need for further explanation?
Hypothesis 4: True. If we use the same amplitude on two bobs, one with a long thread the other with a short thread, the bob on the short thread will be in a higher position than the one with the long thread at the same amplitude, and therefore it will gain a higher kinetic energy than the other, though travel the same distance; hence quicker...
I guess it's hypothesis 2 I'm having most troubles with... It's probably very simple :blushing:
Help please with confirming and correcting (especially hypothesis 2)? :)
Cheers,
Joachim
It appears that you have some good hypotheses and are on the right track in understanding the factors that affect the swing of a pendulum. Here are some points to consider:
1. The period of a pendulum is indeed dependent on the amplitude. As you mentioned, a higher amplitude will result in a longer distance for the bob to travel, but it will also result in a larger angle of displacement, which affects the restoring force and therefore the period.
2. The mass of the bob does not affect the period of a pendulum in the absence of air resistance. This is because, as you correctly stated, all objects will fall with the same acceleration due to gravity regardless of their mass. However, when air resistance is present, the mass and density of the bob can affect the period. This is because the air resistance will create a drag force that is proportional to the surface area and velocity of the bob. A denser bob with a larger surface area will experience more drag and therefore have a longer period compared to a less dense bob with a smaller surface area.
3. As you mentioned, air resistance and friction will definitely affect the period of a pendulum. In the presence of air resistance, the amplitude will gradually decrease due to the loss of energy to air resistance and friction, resulting in a shorter period.
4. The length of the thread or string does affect the period of a pendulum. A longer thread will result in a longer period, as the bob has to travel a greater distance to complete a swing.
Overall, it is important to consider all the factors that can affect the period of a pendulum, including air resistance, friction, amplitude, mass, and length of the string. It is also important to note that these factors can interact with each other and may not always have a straightforward relationship. Keep exploring and experimenting to deepen your understanding of pendulum motion.
1. How does air resistance affect the swing of a pendulum?
Air resistance can significantly impact the swing of a pendulum by slowing it down and reducing its amplitude. This is because air molecules create friction against the pendulum's movement, which causes it to lose energy over time.
2. Does the length of the pendulum affect its swing with and without air resistance?
Yes, the length of the pendulum does affect its swing. A longer pendulum will have a longer period, meaning it will take longer to complete one full swing. With air resistance, a longer pendulum will also experience more drag, slowing down its swing even further.
3. Which factors have a greater impact on the swing of a pendulum: mass or air resistance?
Air resistance has a greater impact on the swing of a pendulum. While mass does influence the period of a pendulum, air resistance can significantly reduce its amplitude and slow down its swing over time.
4. How does the shape of the pendulum affect its swing with and without air resistance?
The shape of the pendulum does not have a significant impact on its swing. As long as all other factors, such as length and mass, remain constant, the shape of the pendulum will not affect its swing with or without air resistance.
5. Can the swing of a pendulum be affected by the location and altitude of its suspension point?
Yes, the location and altitude of the suspension point can have a minor impact on the swing of a pendulum. Higher altitudes have less air resistance, so the pendulum may swing slightly longer before slowing down. Additionally, a perfectly horizontal suspension point will result in a more accurate and consistent swing compared to an angled or uneven one.
  • Mechanics
  • New Member Introductions
