Did I do this angular acceleration problem right?
In summary, the blades in a blender rotate at a rate of 7000 rpm, or 2638937.829 rad/s. When turned off during operation, the blades slow to rest in 3.4 seconds with an angular acceleration of -776158.185 rad/s^2. It is important to convert units correctly in order to calculate accurately.
zeromodz
246
The blades in a blender rotate at a rate of 7000 rpm. When the motor is turned off during operation, the blades slow to rest in 3.4 s.
What is the angular acceleration as the blades slow down?
Lets first convert rpm to rps and then multiply by 2π to get its angular velocity.
7000rpm * 60 = 420000 rps * 2π = 2638937.829 rad/s
Now just simply use.
Wf = Wi + AT
A = Wf - Wi / T
A = (0) - (2638937.829) / (3.4)
A = -776158.185 rad/s^2 <-----Answer
The answer is negative because its decelerating.
Are you sure about that?
Yes you have to convert it into rps to get seconds and then multiply times 2 pie to get radians per second.
1min= 60s not the other way around
Calculate again. Your answer is wrong. rev convert to radian, minute convert to second.
Unit conversion is very important. Becareful / * sign .
1. What is angular acceleration?
Angular acceleration is the rate of change of angular velocity. It is a measure of how quickly an object's rotational speed is changing.
2. How is angular acceleration calculated?
Angular acceleration is calculated by dividing the change in angular velocity by the change in time. It is typically measured in radians per second squared (rad/s²).
3. What is the formula for calculating angular acceleration?
The formula for angular acceleration is α = (ω2 - ω1) / (t2 - t1), where α is the angular acceleration, ω is the angular velocity, and t is the time.
4. Can angular acceleration be negative?
Yes, angular acceleration can be negative. A negative angular acceleration indicates that the object is slowing down its rotation, while a positive angular acceleration means it is speeding up.
5. How do I know if I did an angular acceleration problem correctly?
If you followed the correct formula and used the correct units, your answer should be in units of radians per second squared (rad/s²). You can also check your answer by plugging it back into the formula and making sure it satisfies the given values for angular velocity and time.
