Register to reply
Magnetic coupling - Halbach Array
by Mo
Tags: array, coupling, halbach, magnetic
Share this thread:
Mo
#1
Nov12-13, 07:11 PM
P: 82
Hi I would like to incorporate a Halbach Array as a means of magnetic coupling.
From the wikipedia entry I understand that I can accomplish this if I nest 1 array within another, with opposite magnetization.
The lowest energy state would be where the magnetic flux matches and thus if I were to rotate one array relative to the other, there would be a restoring torque produced. So if i continually rotate that array, then the 'other' array should rotate to maintain that lowest energy state.
Assuming my understanding up until now is correct, the question(s) now are..
- how can I ensure that there will be enough force or torque in order for the 'other' array to keep following the rotating array (which will be connected to a motor shaft), how can I ensure that at high speeds the coupling will work and the coupled array will 'keep up'?
-how can I even put some numbers onto this? eg: calculating the right magnetic field strength to produce a certain torque between the arrays?
Thanks
Phys.Org News Partner Engineering news on Phys.org
Researchers use 3D printers to create custom medical implants
For secure software: X-rays instead of passport control
Razor-sharp TV pictures
Register to reply
Related Discussions
What is the difference between inductive coupling and magnetic coupling? General Physics 3
Magnetic resonance coupling Vs. Induction resonance coupling General Physics 0
Spatial Wavelength of a Halbach array (Magnetism) General Physics 1
Coupling AC and DC magnetic fields Electrical Engineering 1
Changing kinetic E of charged particle in magnetic field - Halbach array Advanced Physics Homework 6
