An object travels 14 cm in fourth second of motion
  • Thread starter 9giddjl
  • Tags
    Motion
In summary: So you are correct in your calculation, but the book has a typo.In summary, the object starts from rest and travels 14 cm in the fourth second of its motion. Using the equation s=ut+0.5at^2, we can find the positions at t=3 seconds and t=4 seconds, which are 4.5a and 8a respectively. By subtracting these two positions and setting it equal to 14 cm, we can find the acceleration to be 4 cm/s^2. This means that after 4 seconds, the object will have traveled a distance of 16 cm.
9giddjl
35
An object starts from rest and travels 14 cm in the fourth second of its motion. Calculate:
a) the acceleration of the object (assumed uniform)
b) the distance traveled by the object after 4.0 s.
c) the distance traveled in the tenth seconf of motion, if the acceleration is the same throughout its motion.
u=0 s=0.14 m t= 1 sec?
I really don't get these questions.. the ones that are 'it travels 2 metres in 5th second of motion:S however if it traveled 14 cm in fourth second of motion does that mean the time would just be one second? For question a) could i use s=ut +0.5at^2? Wait scratch that i just tried it and it didn't work.. umm pls help. These type of questions just confuse me altogether. Thankyou very much
Hi 9giddgl,
If it travels 14cm in the fourth second of motion, that means that it means it travels 14cm from t=3 seconds to t=4 seconds.
You do want to use the equation you mentioned ([itex]\Delta x = v_0 t + \frac{1}{2}at^2[/itex]). But you can use it twice, to find the position at 3 and 4 seconds (not as a number, but as an expression). What do you get for these two positions?
Once you have those, how can you use the 14cm talked about in the problem to find the acceleration?
So, for the two positions, is it s(3)=4.5a and s(4)=8a?
and then s(4)-s(3) = 14cm = 8a - 4.5a = 3.5a.
Therefore the answer is 4cm/s^2 or 0.04m/s^2?
Is this right, because the answer at the back of my question sheet said 4m/s^2?
Thanks
The book must have meant 4 cm/s^2.
If the acceleration had been 4 m/s^2, then after one second it would be moving 4 m/s; after two seconds 8 m/s; at three it would be going 12 m/s, which would mean at the start of the fourth second it would be going 1200 cm/s. Since it only does 14 cm in that second, those numbers just don't match.
1. What is the formula for calculating motion?
The formula for calculating motion is distance = velocity x time.
2. How do you determine the distance an object travels in a specific amount of time?
You can determine the distance an object travels by multiplying its velocity by the time it has traveled.
3. What is the significance of an object traveling 14 cm in the fourth second of motion?
This means that the object's distance has increased by 14 cm in the fourth second of its motion, indicating a constant or increasing velocity.
4. Is it possible for an object to travel a negative distance in a certain amount of time?
Yes, it is possible for an object to travel a negative distance if it is moving in the opposite direction of its initial position. This can be represented by a negative value in the distance formula.
5. How is velocity related to the distance an object travels?
Velocity is directly proportional to the distance an object travels. This means that as velocity increases, the distance traveled also increases, and vice versa.
