What is the magnetic field strength on Earth's surface at either pole?
In summary, the magnetic field strength on Earth's surface at either pole is approximately 0.00006 tesla, based on the Earth's magnetic dipole moment of D_0 and the equation _u = NIA. For more information, the dipole field can be used to find the exact pole strength.
tnutty
326
Earth's magnetic dipole moment is D_0
B = ____ G
_u = NIA ; N is the number of turns I is current, A is the corss sectional area
I am not sure, they give _u = D_0, but U am not sure what to equate this to.
Perhaps use the dipole field?
http://en.wikipedia.org/wiki/Orders_of_magnitude_(magnetic_field )
about .00006 tesla
Doesn't give the pole strength, but probably has the data you want.
1. What is a magnetic field?
A magnetic field is an invisible force that surrounds a magnet or electric current and exerts a force on other magnets or moving charges. It is represented by lines of force that extend from the north pole of a magnet to the south pole.
2. How is Earth able to have a magnetic field?
Earth's magnetic field is generated by the movement of molten iron in its outer core. The rotation of the Earth and convection currents in the liquid iron create an electric current, which in turn creates a magnetic field.
3. What is the strength of Earth's magnetic field?
The strength of Earth's magnetic field varies depending on location, but on average, it is around 25-65 microteslas (µT) at the surface. At the poles, it can be as high as 60-70 µT.
4. How is the strength of Earth's magnetic field measured?
The strength of Earth's magnetic field is measured using a device called a magnetometer. This instrument detects the direction and strength of the magnetic field and can be used to create maps of the field over different areas.
5. Does the strength of Earth's magnetic field change over time?
Yes, the strength of Earth's magnetic field is not constant and has been fluctuating over time. In fact, it has been weakening over the past few centuries and could potentially reverse in the future, where the north and south poles switch places.
