Atomic spectra and atomic structure by Gerhard Herzberg
In summary: This goes to the foundation of QM and why the Schrodinger Cat thought experiment came into being!It does NOT have a definite position till it is measured. The s-orbital is a spherical distribution of ONE electron. You get this by solving the orbital part of the Schrodinger equation. The electron IS distributed all over the place simultaneously. This is what makes QM highly non-intuitive for anyone who skip the mathematical formalism.How do you know such a distribution exists?
Galaxy33
Hi! to everyone on the forum. I am new and did not really know where i should of posted this thread its not homework its just a question i have.
A friend of mine asked me a question about a book he read about (atomic spectra and atomic structure by Gerhard Herzberg). Gerhard Herzberg said that, in reality the electron revolves, not about the nucleus itself, but about a commen center of gravity; also the nucleus revolves about that center.
The question is, in 2005 is this view by Gerhard Herzberg still true? I did not know the answer so i posted it here...
Galaxy...
Galaxy...
Great question. Some physicists, during the advent of quantum mechanics, spent some time double checking but Herzberg is still correct.
Though the atomic nucleus greatly outweighs the electrons, the electrons still do some pulling--enough anyway to yank the whole atom (electrons and all) out of whack, even if just the smallest bit.
If you view the system classically, then yes the electron does revolve around the CM.
If you take the Qunatum view, the correct representation, then the question is ill-formed and can not be answered.
And in what kind of observation/experiment/phenomenon does this "smallest bit" effect manifests itself?
Zz.
I'm assuming you're talking about HUP. Fine, this is a theoretical question and I'm going to keep assuming (unless asked otherwise) that Galaxy doesn't require proof of speed and position of the particle at the same time.
And, I might add, just because we can't nail down a mathematical snapshot of said particle doesn't mean that we don't know what it's doing. Feynman spends some time on this topic.
It has nothing to do with the Uncertainty principle. The electron, described by it's wavefunction, has a probability distribution that doesn't "revolve" around anything.
What "mathematical snapshot" did you have in mind? The mathematical description of an atom has no such trajectory. One only needs to look at the solution fo the hydrogen atom to know this. And these were not derived out of the HUP either.
Zz.
Where is the electron distributed? Does it not have a position?
Based on the responses I'm way off on this, somehow. If that's the case give the proper answer. I'd hate argue bad info any longer than I have to.
How do you know such a description is valid? Besides the fact that QM gave unbelievably accurate energy spectrum of many atoms and molecules (something classical mechanics could not), we also have evidence from how bonding forms, especially in the formation of bonding and antibonding states. Such phenomenon has no intuitive counterpart in classical mechanics.
Zz.
So, I'm assuming that a thrown photon's trajectory is also a matter of probability?
To say something about the OP's question : Yes, you can decompose the Schrodinger Equation for the H-atom into two parts - one dealing with the center of mass motion and the other dealing with the relative motion - using the standard change of variables :
[tex]\mu = \frac {m_1m_2} {m_1+m_2}~;~~M = m_1 + m_2~;~~r = |r_1 - r_2|~;~~R = \frac{m_1 r_1 + m_2 r_2}{m_1+m_2} [/tex]
This makes - in the case of the H-atom - a very tiny change to the Hamiltonia.
I wouldn't know, since I have no idea what a "thrown photon" is.
Zz.
Zz.
When an electron drops to a lower energy level it releases a photon
Did I do something to irritate you?
No. I'm responding to what you have said. Is it wrong for me to get clarification of what you are saying or claiming? I have never seen the phrase "thrown photon" in all my years in this field. I have also haven't seen any experimental evidence to back your claim earlier of "... electrons still do some pulling--enough anyway to yank the whole atom (electrons and all) out of whack, even if just the smallest bit.. "
So a photon emitted by an atomic transition is what you called "thrown photon"? I'm not sure why this would be relevant for this thread. Once photons are emitted one can very much invoke classical optics.
Zz.
Don't take thing's personally.
Life is in the details. When you ask a vague question you're going to get a vague answer. When you ask a general, non-specific, or ill-worded question, you'll find the answer you get isn't going to be helpful.
Photons are very different from electrons.
Oh, I wasn't taking anything personally. Just making sure someone else wasn't. I have very colloquial conversations with working physicists everyday with far better results than just now. But I have a way of not making sense sometimes.
Thanks for the information. Ciao.
Thanks to everyone who answered my question, but can i assume that the answer was yes, as Conehead stated (some physicists during the advent of quantum mecanics, spent some time double checking but Herzberg is still correct) ?
Titana....
1. What is atomic spectra?
Atomic spectra refers to the unique pattern of wavelengths of light emitted or absorbed by an atom. These wavelengths correspond to specific energy levels or electron transitions within the atom.
2. Who is Gerhard Herzberg?
Gerhard Herzberg was a German-Canadian physicist who won the Nobel Prize in Chemistry in 1971 for his work on the electronic structure and geometry of molecules, including the study of atomic spectra and atomic structure.
3. How is atomic structure related to atomic spectra?
The energy levels and electron transitions that make up atomic spectra are determined by the arrangement and number of electrons in an atom's orbitals, which is known as its atomic structure. Therefore, understanding atomic structure is crucial in studying atomic spectra.
4. What are the different types of atomic spectra?
There are three main types of atomic spectra: continuous, emission, and absorption. Continuous spectra are produced by hot, dense objects and contain all wavelengths of light. Emission spectra are produced when electrons in an atom jump from higher to lower energy levels, emitting specific wavelengths of light. Absorption spectra are produced when atoms absorb specific wavelengths of light, indicating the presence of certain elements.
5. Why is the study of atomic spectra important?
The study of atomic spectra allows scientists to identify and understand the properties of different elements. It also provides valuable information about the energy levels and electronic structure of atoms, which is crucial in fields such as chemistry, physics, and astronomy.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Other Physics Topics
