Finding x-value for vector in a plane defined by two non-parallel vectors
In summary, any two vectors that are not parallel define a plane and if r is coplanar to q*, then r* is a scalar multiple of p* and q*.
teejmd
Any two vectors that are not parallel define a plane. So p = i + j -k and q = 2i +j define a plane. For what values of x is the vector r = xi + j + k in this plane?
If r* was in the plane formed by p* and q*, would r* be a scalar multiple of p* and q* to be certain it was in the plane? Solving that I get the only x value being 2. I'm not sure if this was the right approach and would appreciate some help! thanks
Two vectors don't determine a plane, they just determine the orientation of a plane. Any plane parallel to that plane would also be parallel to the same vectors. So what you are really asking is for what x is r = xi + j + k parallel to the plane.
Hint: Any vector perpendicular to the normal vector for the plane is parallel to the plane.
Alternate hint: The parallelepiped formed by p,q, and r would have volume 0.
Two vectors form a plane in between them...question is asking for when r is coplanar to q * p.
Correct me if I'm wrong. Can be solved by using 0 = r*(q*p)
LCKurtz said:
Two vectors don't determine a plane, they just determine the orientation of a plane. .
Eh? That's what the actual question says and that's what I've been taught, anyone able to clarify?
Anyway what I've ended up doing is saying if r* was in the plane, it's cross product with either p* or q* (p* x r* etc) would be parallel to p* x q* (p* q* cross product). i.e. they are both normal to the plane formed by p* and q*, making them parallel => making them scalar multiples of each other. Vector parallel still confuse me.
I set [(p* x q*) x (p* x r*)] = 0 vector so that they are parallel and solved for x, getting x=3.
If you have been taught that all vectors have their "tails" at the origin, you have been taught wrong. If the problem really says "Any two vectors that are not parallel define a plane", it is wrong. (If it said "position vectors", that would be a different matter- although I dislike that phrase.)
The two vectors p = i + j -k and q = 2i +j define the planes x+ 2y- k= C for any C. If C= 0, then that plane includes the origin and so would include the "position vectors". One can determine if three vectors, u, v, and w, lie in the same plane by looking at their "triple product", [itex]u\cdot(v\times w)[/itex]. They will be in the same plane if and only if that is 0.
(I just realized this is a physics problem, not a math problem. Ah, well, physicists tend to be unfortunately loose with mathematics terminology.)
1. What is a simple vector plane problem?
A simple vector plane problem is a mathematical problem that involves using vector operations to solve for unknown quantities on a two-dimensional plane. This type of problem is commonly found in physics and engineering.
2. How do you represent vectors in a simple vector plane problem?
Vectors are typically represented using arrows on a coordinate plane, where the length of the arrow represents the magnitude of the vector and the direction of the arrow represents the direction of the vector.
3. What are some common vector operations used in simple vector plane problems?
The most common vector operations used in simple vector plane problems are addition, subtraction, scalar multiplication, and dot product. These operations allow you to manipulate vectors to solve for unknown quantities.
4. Can you explain the concept of vector components in a simple vector plane problem?
Vector components refer to the individual parts of a vector in the x and y directions. They can be found by breaking down a vector into its horizontal and vertical components using trigonometric functions.
5. How can I apply simple vector plane problems in real-life situations?
Simple vector plane problems can be applied in various real-life situations, such as calculating the displacement of an object, determining the force required to move an object in a certain direction, or finding the resultant force of multiple forces acting on an object. They are also useful in navigation and mapping, as well as in designing structures and machines.
  • Precalculus Mathematics Homework Help
