Register to reply
Force on electric diploe in non-uniform electric field
by rajeshmarndi
Tags: diploe, electric, field, force, nonuniform
Share this thread:
rajeshmarndi
#1
Jun27-14, 02:10 AM
P: 176
I couldn't understand why there is,
∂E[itex]_{y}[/itex] and ∂E[itex]_{z}[/itex] term in the equation,
for the x-component of the force on di-pole,
F[itex]_{x}[/itex] = q [ E[itex]_{x}[/itex] + ∂E[itex]_{x}[/itex]/∂x δx + ∂E[itex]_{y}[/itex]/∂y δy + ∂E[itex]_{z}[/itex]/∂z δz ] - qE[itex]_{x}[/itex]
Isn't both ∂E[itex]_{y}[/itex] and ∂E[itex]_{z}[/itex] term, should be zero along the x-component.
I understand, the net force on the di-pole, in an non-uniform electric field, should be,
F[itex]_{x}[/itex] = q [ E[itex]_{x}[/itex] + ∂E[itex]_{x}[/itex]/∂x δx] - qE[itex]_{x}[/itex]
Since the force on the ends of a di-pole are not the same in an non-uniform field. And therefore, there would be a net force on the di-pole.
Phys.Org News Partner Physics news on Phys.org
UCI team is first to capture motion of single molecule in real time
And so they beat on, flagella against the cantilever
Tandem microwave destroys hazmat, disinfects
Simon Bridge
#2
Jun27-14, 03:12 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,067
What are the delta terms in the equation for?
Micky raj
#3
Jun27-14, 03:35 AM
P: 4
can't get through what you have written. Bhai apka Post kia hua acha say nahe sam j
rajeshmarndi
#4
Jun27-14, 04:49 AM
P: 176
Its given E[itex]_{x}[/itex], E[itex]_{y}[/itex] and E[itex]_{z}[/itex] are three rectangular component of field strength E at the origin where the charge -q of the dipole is situated and the charge +q is situated at (δx, δy, δz).
Quote Quote by Simon Bridge View Post
The delta terms must be the rate of change of the field.
I understand, force experienced upon x-component of the +q charge
= q [ E[itex]_{x}[/itex] + ∂E[itex]_{x}[/itex]/∂x δx + ∂E[itex]_{y}[/itex]/∂y δy + ∂E[itex]_{z}[/itex]/∂z δz ] and,
force experienced upon x-component of the -q charge= qE[itex]_{x}[/itex]
and hence the net force on x-component of the di-pole =
Micky raj
#5
Jun27-14, 05:04 AM
P: 4
Hi you Indian ?
Simon Bridge
#6
Jun28-14, 12:00 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
NO - the delta terms are the position of one end of the dipole with respect to the other one.
The partials attached to the delta terms are the rate of change of E with the direction.
Since the dipole can be tilted in the y or z direction, the gradient of E in that direction must count.
rajeshmarndi
#7
Jun28-14, 12:08 AM
P: 176
Apologize, there is no ∂E[itex]_{y}[/itex] and ∂E[itex]_{z}[/itex] in the equation, so the equation is F[itex]_{x}[/itex] = q [ E[itex]_{x}[/itex] + ∂E[itex]_{x}[/itex]/∂x δx + ∂E[itex]_{x}[/itex]/∂y δy + ∂E[itex]_{x}[/itex]/∂z δz ] - qE[itex]_{x}[/itex].
Still, can there be term ∂E[itex]_{x}[/itex] wrt ∂y and ∂z. I understand it would be zero wrt ∂y and ∂z.
Simon Bridge
#8
Jun28-14, 12:59 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
Sure ... the x component of the electric field can depend on y and z
$$\vec E = E_x(x,y,z)\hat \imath + E_y(x,y,z)\hat \jmath +E_z(x,y,z) \hat k\\$$
rajeshmarndi
#9
Jun28-14, 02:30 AM
P: 176
We have only E[itex]_{x}[/itex] component along x-axis, similarly E[itex]_{y}[/itex] and E[itex]_{z}[/itex].
So, obviously ∂E[itex]_{x}[/itex]/∂y i.e rate of change of x-component on y-axis should be zero.
Where am I wrong.
Simon Bridge
#10
Jun28-14, 02:41 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
We have only Ex component along x-axis, similarly Ey and Ez.
... that's what I wrote - notice that each component of the electric field is a function of position?
If the x component electric field does not depend on z or y then the gradient in those directions will be zero.
The equation you wrote does not make that assumption.
The equation is explicitly for the situation that the electric field varies with position.
rajeshmarndi
#11
Jul11-14, 08:43 PM
P: 176
I still am missing something.
For e.g a particle accelerating in the x-y plane.
If I'm right, its instantaneous velocity along x-axis after an interval δx will be, ∂V[itex]_{x}[/itex]/∂x δx, and we wouldn't need ∂V[itex]_{x}[/itex]/∂y δy.
V[itex]_{x}[/itex] = instantaneous velocity on the x-axis
∂V[itex]_{x}[/itex]/∂x = acceleration on the x-axis
Simon Bridge
#12
Jul12-14, 01:58 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
Didn;t you say earlier that the delta-x delta-y etc were related to the separation of the charges in the dipole.
rajeshmarndi
#13
Jul12-14, 05:36 AM
P: 176
I think this is what I'm still not getting. Can you please make it simple.
Why the x-component depend on z or y axis? That is, once we know the rate of change along x-axis is ∂E[itex]_{x}[/itex]/∂x, we don't need z and y component.
Only ∂E[itex]_{x}[/itex]/∂x is required to know the value of E[itex]_{x}[/itex] at δx.
Yes, one end of the dipole is at origin and the other charge +q is situated at (δx, δy, δz).
Simon Bridge
#14
Jul12-14, 08:19 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 13,067
... that would happen if the field is not uniform.
i.e. For a point charge, the electric field is $$\vec E = \frac{kQ}{r^3}\vec r$$ ... find ##E_x##
Remember:
The electric and magnetic fields are vectors.
So ##\vec E = E_x(x,y,z)\hat\imath + E_y(x,y,z)\hat\jmath + E_z(x,y,z)\hat k##
##E_x## is not the value of ##\vec E## along the ##x## axis, it is the component of ##\vec E## at point ##\vec r = (x,y,z)## that points in the +x direction.
Register to reply
Related Discussions
Force acting on a dipole in non-uniform electric field. Advanced Physics Homework 1
Electrostatic force,electric field,electric potential,electric flux Introductory Physics Homework 2
Electric field, Electric Potencial, Electric Force, Potential Electric Energy Classical Physics 1
Uniform Electric Field Upward Electric Force Equals Weight. HELP Introductory Physics Homework 1
Electric charge and fields: uniform electric field Introductory Physics Homework 1
