Register to reply
Need help understanding the signal wire.
by MinnesotaState
Tags: signal, wire
Share this thread:
MinnesotaState
#1
Aug24-13, 08:45 PM
P: 31
My servo,
http://www.allelectronics.com/make-a...G-SERVO/1.html
Not sure if this servo requires AC or DC power. What I really want to understand is the signal wire; specifically how changing the input value either increases or decreases the speed of the servo. I speak of input value because I do not know if the EMF or the I is changing. I'd assume that the EMF would remain constant & the change I would be responsible for change in speed of the servo.
Perhaps it's best that I understand how a varistor works? With a varistor, the + & - leads have completed the circuit. You change the flow via screwdriver or such. You can think of turning the screwdriver as your signal, correct? How does this work? To me, it's either you complete the circuit or you don't.
Btw, I believe the servo requires AC. I standard 9Vdc didn't work. I ran the signal to positive...
Phys.Org News Partner Engineering news on Phys.org
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
Compact vibration harvester power supply with highest efficiency opens door to "fix-and-forget" sensor nodes
davenn
#2
Aug24-13, 11:19 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,464
it requires 6V DC did you not read what it said on the page ?
the signal wire usually is an output from the motor ... the few servo motors I have worked with produce a pulsing signal on this line that is sent back to the motor drive circuit.
If you connected it to power you may have damaged it ??
the 9VDC may have also damaged it ?
Dave
rbelli1
#3
Aug25-13, 01:30 PM
P: 14
That is a standard hobby server. The control signal is a PWM input that sets the position of the arm.
How RC Servos Works
BoB
Register to reply
Related Discussions
Reconstructing a signal using an equilizer filter function Engineering, Comp Sci, & Technology Homework 12
In binary can we have a value with deci centi mili or more lower valued prefix? Computers 14
Turning FETs off in presence of AC signal at Drain or Source Electrical Engineering 7
Physics of creating a deliver-to-Earth-in-future signal Astronomy & Astrophysics 36
What is meant by signal-to-noise ratio? General Engineering 15
