About how to prevent being struck by lightning
  • Thread starter kuengb
  • Tags
    Lightning
In summary: I've always wondered what would happen if you were to get in one of those "anti-static" bags like computer parts are shipped in. In summary, during a thunderstorm, it is important to find a safe place to take shelter. If you are caught in an open area, it is recommended to crouch in a hollow and keep your feet close together. This minimizes the voltage difference between your feet, reducing the risk of current flow through your legs. It is also advised to avoid tall objects and standing near other people. One of the safest places to be is inside a car, as long as you stay away from the sheet metal skin and avoid playing golf. Sitting on a backpack or in a shallow cave is not a good idea
  • #36
So if standing with feet together is safer, would it be safest to stand on the toes of one foot?
Science news on Phys.org
  • #37
Crouch and place your heels together..AND...block your ears with your hands. The sound of lightning that close can blow your eardrums out. BTW, if the rare event that an electrical power line ever fell on your car with you inside it, STAY IN THE CAR. Numerous deaths have resulted when the driver panics and exits the auto, making contact with the vehicle and ground, and its curtains. Inside, you're much more protected as in a Faraday cage. I wouldn't touch any metal though, hands off the keys. Wait for professional help to arrive.
  • #38
Hah, if you can crouch on one toe and block your ears, you're much more athletically inclined than I. The heel to heel approach may burn your feet, but it's better than taking 100,000 amps thru the heart for sure.
  • #39
Yeah, it's not really a perfect Faraday cage as some people imagine it to be.
  • #40
Two of us watched in horror as a friend standing on a train had 5,000 volts arc to the left side of his neck (and blow off the bottom of his left shoe). Had the electricity arced to the right side of his neck, we were told, his heart would have been fried. The spark also ignited the vapors of the tank car in which he had been peering, giving him 50% burns. One other strange thing: the potential in his body was great enough to blow his metal frame glasses off of his head. He recovered more or less fully.
  • #41
I saw criss angel get shot by lightening.
  • #42
:eek:
He tried to commit suicide,or he didn't know the train powerline was energized?He was lucky he didn't buy the farm ..
BTW,his glases were not blew off of his head due to potential ,but probably by a powerful electric arc action .
The arc phenomenon occurs in explosive fashion (the same reason why you can hear thunder caused by lightning) :beside expansion of air and almost "instantenous" melting of materials in contact zone of the arc currents can peak kiloampere range causing strong local magnetic forces of repulsion.
I think an electric chair in states used voltage of aproximately 5000 V for executions .Your friend was very lucky.
Speaking of lightning and that you are completely safe in car or hause you may want to read this report: http://www.news.com.au/story/0,23599,20548077-13762,00.html
(And please don't laugh at it)
  • #43
And people laugh at safe sex.
  • #44
Of course lightning has potential
It's actually easy to approximate the voltage of lightning -- What you really have is a capacitor with air as the dielectric. According to wikipedia, the dielectric strength of air is about 3 MV/m -- so using that knowledge and a few intro physics equations it is pretty easy to at least estimate the potential in lightning.
  • #45
Firstly,at 2500 m altitude ,the dielectric strenght of air is ~ 2 MV/m.
But I disagree with you on basis of another (measured )fact.
Just a second or so prior to the lightning,a typical measured field on terrestial level is typically 10 kV/m = [tex]0.01 MV/m[/tex].
With assumption of uniform field distribution, the voltage taken along path 2000-3000 m turns out to be :[tex]20 - 30 MV[/tex].
Taking your value of 3 MV/m in the account this voltage can be as high as:
[tex]9000 MV[/tex].
Man that's 9 Gigavolts !
Easy eastimate?I don't think so!
  • #46
potential difference during lightning strikes
Richard Feynman has a good discussion of thunderstorms in his three volume Lectures on Physics (see Volume 2, Chapter 9). He estimates that the charge on the bottom of a cloud during a thunderstorm is large enough to produce a potential difference of 20, 30 or even 100 million volts between the cloud and Earth. This results in an electric field strength on the order of 1E5 V/m, which is an order of magnitude lower than the dielectric breakdown of dry air at atmospheric pressure. The dielectric breakdown of air at the base of a thundercloud is much less than 3E6 V/m, however, due to reduced air pressure (Paschen effect) and the presence of water droplets (Macky effect).
  • Science Fiction and Fantasy Media
