Concept of Distance and time. (basic question but no answer)
In summary, we have two cars, P and Y, with different distances from the finish line and uniform accelerations. We can use the equations v^2=u^2+2as and s=vt-1/2at^2 to calculate the distance traveled by each car, but when they are both in the same position, the acceleration is 0. By setting the distances traveled by each car equal to 220 m, we can solve for the time it takes for each car to reach that point. This leads to a quadratic equation, which can be solved to find the time it takes for car Y to reach the 220 m mark before the finish line. Therefore, car Y does indeed pass car P 220 m before
nabet94
Car P is 1km from finish line with a speed of 35ms-1 and a uniform acceleration of 2/5ms-2
Car Y is 1.2km from finish line going at 44ms-1 and a uniform accelr of 1/2ms-1
show that Y passes p 220m before the finish line.
v2=u2+2as
s=vt-1/2at^2
so the acceleration when they are both in the same position is 0. thus i can use s=vt-1/2at^2 for both and cancel them out. so it would be 220=(44)t-(1/2)(1/2)t^2 for Y and for P it would be 220=(35)t-1/2(2/5)t^2. but then i end up with 0=9t-(1/20)t^2. then what? after that I'm lost.
How did you come up with this?
nabet94 said:
thus i can use s=vt-1/2at^2 for both and cancel them out. so it would be...
Why minus?
The problem states that you have to prove that car Y passes the car P 220 m before the finish line. What is the distance that each car has to pass in order to get to that position, i.e. 220 m before finish line?
1. What is the concept of distance and time?
The concept of distance and time refers to the measurement of how far an object has traveled in a certain amount of time. It is a fundamental concept in physics that helps us understand the relationship between the two variables and how they affect the motion of objects.
2. How do we measure distance and time?
Distance is typically measured in units such as meters or kilometers, while time is measured in units such as seconds, minutes, or hours. We can use various tools such as rulers, tape measures, and stopwatches to measure these quantities accurately.
3. What is the relationship between distance and time?
The relationship between distance and time can be described by the formula: speed = distance/time. This means that the greater the distance traveled in a given amount of time, the faster the object is moving. Similarly, the shorter the distance traveled in a given amount of time, the slower the object is moving.
4. How does the concept of distance and time apply to real-life situations?
The concept of distance and time is applicable to many real-life situations, such as calculating the speed of a car on a highway, determining the distance traveled by a runner during a race, or estimating the time it takes for a plane to travel from one city to another. It is also used in scientific research to understand the motion of celestial bodies in space.
5. Why is the concept of distance and time important in science?
The concept of distance and time is crucial in science as it helps us understand and analyze the motion of objects. It allows us to make predictions about the future position of an object based on its current speed and direction. It also helps us accurately measure and compare the speed of different objects, which is essential in fields such as engineering, astronomy, and transportation.
21K
15K
