How to determine the direction of propgation of a plane wave?
In summary, the experts discussed the determination of the moving direction of a plane wave with the use of the Poynting vector. They also talked about the calculation of the electric and magnetic fields for a TEM plane wave and the direction of power flow for a linearly polarized wave. They also mentioned the importance of specifying both the spatial and temporal dependence of the wave to accurately determine its direction.
Rex_chaos
hi all,
Suppose there is a plane wave u=exp(-i k x), where k is a wavenumber. How to determine it's moving direction?
In general, you can find the direction of the power flow of an EM wave by calculating the Poynting vector:
P = E x H.
Anyway, for this case (the case of a TEM plane wave), the electric field may be expressed as:
E(R) = E0 exp(-ik dot R).
The corresponding magnetic field may be expressed as:
H(R) = (1/eta) an x E(R).
Here, eta is the intrinsic impedance of the medium.
I will assume that your wave is linearly polarized which makes
E0= ay E0 cos(2[pi]f t)
and
H0 = az (E0 / eta) cos(2[pi]f t).
You should be able to prove to yourself that the power flow is in the +x direction.
eNtRopY
Perhaps i missed something during my physics classes but the k in this equation is the wavevector which gives you the direction. In general the solution to a 1D wave equation will be of the form:
Aexp(ikx)+Bexp(-ikx)
Where the plus is for moving to the right en the minus for moving to the left. In higher dimensions the k is a vector pointing in the direction of travel...
Where the plus is for moving to the right en the minus for moving to the left...
Yes, I know the result. However, how to prove that +k corresponding to a wave moving to the right?
This wave does not move...
It has a definite value at each point in space which is fixed in time.
Only if you have :
Aexp(i(kx-wt)) + Bexp(-i(kx+wt))
you can have a moving wave. Note the difference of the sign in front of w.
To show in which direction it moves it suffices to study the argument being zero:
kx-wt=0 --> x=ct moving to +x
kx+wt=0--> x=-ct moving to -x
where c=w/k the velocity of the wave.
To determine in which direction the wave propagates you need to specity the time dependence as well as the space dependance. You've only given the spatial dependence of the phasor. There are two choices of a time dependence corresponding to two choices of the sign of "wt".
Pete
If you're talking QM in the time-independent case, then it's just convention that the + waves goes right and the - goes left. It's actually erroneous to say they're going anywhere; "time-independent" scattering is a sort of vague approximation they teach you in beginning classes -- but of course they never explain why it works. :)
Originally posted by heumpje
Perhaps i missed something during my physics classes but the k...
It is true that in the trivial case which has the form E ~ exp(-kx) the wavevector gives the direction of the traveling wave. However, examine a case with superpositioned wave patterns having unequal direction, orientation and magnitude. You will see that calculating the Poynting vector gives the most straight-forward method for determining the direction of an EM wave.
eNtRopY
Pete
It is common practice to absorb the time dependence in the magnitude coefficient as I shown above. I assume Rex_chaos meant:
u [pro] exp(-i k x)
rather than
u = exp(-i k x).
Otherwise, his problem is too trivial.
eNtRopY
re - "It is common practice to absorb the time dependence in the magnitude coefficient as I shown above. I assume Rex_chaos meant:"
Sometimes that's true. But to determine the direction you have to know what it was that was absorbed.
Pete
1. How do you determine the direction of propagation of a plane wave?
The direction of propagation of a plane wave can be determined by looking at the direction of the wave's oscillations. In a transverse wave, the oscillations are perpendicular to the direction of propagation, while in a longitudinal wave, the oscillations are parallel to the direction of propagation.
2. What is the difference between transverse and longitudinal waves?
Transverse waves are a type of wave where the oscillations are perpendicular to the direction of propagation, while longitudinal waves are a type of wave where the oscillations are parallel to the direction of propagation.
3. How does the wavelength of a plane wave affect its direction of propagation?
The wavelength of a plane wave does not affect its direction of propagation. The direction of propagation is determined by the direction of the wave's oscillations, which is independent of the wavelength.
4. Can the direction of propagation of a plane wave change?
Yes, the direction of propagation of a plane wave can change if the medium through which the wave is traveling changes. For example, if a wave enters a denser medium, it will change direction due to refraction.
5. How can you measure the direction of propagation of a plane wave?
The direction of propagation of a plane wave can be measured using a variety of instruments such as a laser pointer or a compass. These instruments can detect the direction of the wave's oscillations and therefore determine the direction of propagation.
  • Other Physics Topics
  • Classical Physics
