Faster than the speed of light paradox
In summary, the conversation discusses the concept of a hypothetical stick that is 1 light-year long and how it could potentially be used for faster communication than the speed of light. However, the group comes to the conclusion that the stick would still have limitations due to the speed of sound and compression waves.
bystander1212
Ok, so I'm not a physicist by any means, and I don't actually understand the first thing about physics. So, I'm guessing that somebody's probably realized this before, and I just want to know the name of this "paradox" (i'm not even sure it's the right word) so I can read up on it.
Here's the thing: light would take 1 whole year to travel the distance of 1 light-year. So even if we had communication that could travel at the speed of light, it would take 1 year to cover that distance.
So we got this epiphany, where if you built a (hypothetical) stick that's 1 light-year long, and you tapped it on that planet that's a light year away, you could communicate much faster than the speed of light. Right? :confused:
So what's this called, and what other information can you give me about it? Thanks for the info guys!
Science news on Phys.org
Wrong. The tap would travel through the stick at the speed of sound for the material that the stick is made from, and the speed of sound through any material will always be less than the speed of light.
I think he is saying something more to the effect of having the end of the stick dipped in ink and put next to a piece of paper one light year away. Then when you push the stick it should also be pushed against the piece of paper, and you could write morse code or something else.
I think this is a quite good thought by the way. I have never thought of it. However you may think that the stick would instantaneously move as you push it, but I am thinking that your pushing will cause a compression of the stick which will travel at some speed... actually perhaps the speed of sound. For small sticks we of course would never notice such a thing, but I'm thinking that something along those lines would explain it. But perhaps i am wrong.
Alex, that's exactly what i meant. i mean physically pushing the stick, not tapping it so the vibration travels THROUGH the stick. jesus, I've always been bad at physics but not THAT bad.
so if you pushed the base of the stick (from earth), wouldn't the end of the stick (1 light-year away) move instantly? even if you, say, swung it, it would end up like the classic "2 points on an LP" thing. the end of the same object would still move as quickly as it was pushed on earth...i think.
Push it or 'tap it', it still takes time for the mechanical pulse to travel from one end of the stick to the other.
No.
No.
Well in our experience, when we push something, the object seems to move all at once. But on big scales, the fact that the object is made of atoms will come into play. When we push the stick, this compresses the atoms that are on the end of the stick that we pushed. I am thinking that explanation lies in the idea that the other end of the stick will not move until the compression wave that you have caused reaches the other end, and that the compression wave will travel at some velocity lower than light.
Exactly. Typically it will travel at the speed of sound in the material, much lower than the speed of light. (As Janus has stated.)
wow guys, that's fascinating. thanks for the replies, it was worth a shot huh?
also, if that last post came off as sarcastic for any reason, it wasn't. that really is fascinating.
Yep. In addition, a push should arrive much faster than a side to side motion, since the velocity of a compression wave will be substantially higher than a lateral wave. So, pushing the stick would result in a faster transmission than swinging the stick would, but both would be substantially slower than light.
sry for bumping an old thread but i have 2 questions that relate to the OPs original questions...
i understand perfectly why pushing a very long stick or rod extended across a large distance would not result in faster than light communication...but i was wondering what about rotating/spinning a rigid rod? would spinning a cylindric rod also rely on a compression wave? hope this isn't such a dumb question. thanks guys
It is a different type of wave, but it is transmitted in the same way, so it would have the same speed (speed of sound).
Why is it the speed of sound that it is transmitted at has anyone done an experiment to show that this is conclusuve. A stick is made of matter and gravity travels at the speed of light why the delay.
There is no such thing as a rigid body. Treating something as a rigid body is a simplifying assumption that makes the math much simpler.
In reality, the stresses that would build up inside the rod would cause the rod to tear itself into pieces long before any part of the rod was moving even close to the speed of light. So what if we make the rod out of unobtanium? First off, there is no such substance as unobtanium, so we're verging into the "what do the laws of physics say would happen if we violate the laws of physics" territory. That said, even unobtanium has it's limits. Read up on Born rigidity.
Sooooo...
What about a rod made of neutronium? :devil:
We have a FAQ specifically on this topic
https://www.physicsforums.com/showthread.php?t=536289
1. What is the "Faster than the speed of light paradox"?
The "Faster than the speed of light paradox" refers to the idea that nothing can travel faster than the speed of light, but there are certain phenomena and theories that suggest otherwise.
2. Can anything actually travel faster than the speed of light?
According to the currently accepted laws of physics, nothing with mass can travel faster than the speed of light. However, there are theories such as wormholes and cosmic inflation that suggest the possibility of faster-than-light travel.
3. How does the theory of relativity relate to the "Faster than the speed of light paradox"?
The theory of relativity, particularly the special theory of relativity, states that the speed of light is constant and the maximum achievable speed in the universe. This theory is what creates the paradox, as it suggests that nothing can exceed the speed of light.
4. Are there any observed instances of faster-than-light travel?
No, there are currently no observed instances of faster-than-light travel. However, there have been experiments conducted with particles such as neutrinos that appeared to travel faster than light, but these results were later found to be due to measurement errors.
5. What are some proposed solutions to the "Faster than the speed of light paradox"?
Some proposed solutions include the idea of spacetime warping, where an object can travel a shorter distance in a warped space and appear to have traveled faster than light. Another solution is the concept of multiple universes, where travel between parallel universes could potentially allow for faster-than-light travel.
  • Optics
12K
