Maximum current from a battery
by abdo799
Tags: battery, current, maximum
abdo799
abdo799 is offline
#1
Dec21-13, 05:14 AM
P: 90
If we had a battery with internal resistance 1 ohm and 9 V.
If we connected to just wires ( resistance 0) i will produce a 9 amps current. Is this the maximum current? If we connect to this battery a 0.5 ohm resistor (in parallel ) the total resistance will be lower than one, will the current produced be greater than 9 amps?
Phys.Org News Partner Physics news on Phys.org
Sensitive detection method may help impede illicit nuclear trafficking
CERN: World-record current in a superconductor
Beam on target: CEBAF accelerator achieves 12 GeV commissioning milestone
K^2
K^2 is offline
#2
Dec21-13, 05:33 AM
Sci Advisor
P: 2,470
You can't connect a resistor so that it's in parallel with internal resistance of battery with respect to the voltage drop of the battery. So yeah, you get maximum current if you just short the battery out.
abdo799
abdo799 is offline
#3
Dec21-13, 05:43 AM
P: 90
So basically maximum current = voltage/internal resistance and i can never surpass it
mikeph
mikeph is offline
#4
Dec21-13, 06:57 AM
P: 1,197
Yep.
CWatters
CWatters is offline
#5
Dec21-13, 10:14 AM
P: 2,861
If we connected to just wires ( resistance 0) i will produce a 9 amps current. Is this the maximum current? If we connect to this battery a 0.5 ohm resistor (in parallel ) the total resistance will be lower than one...
The total resistance will be higher than one.
abdo799
abdo799 is offline
#6
Dec21-13, 11:47 AM
P: 90
Yup...i got it
sophiecentaur
sophiecentaur is offline
#7
Dec22-13, 10:03 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,341
Quote Quote by abdo799 View Post
The idea of 'internal resistance' is not that simple. What actually happens inside batteries cannot necessarily be reduced to a simple series ohmic resistance when the load gets higher and higher. Any power dissipated inside the case will raise its temperature and this can alter the emf produced by the chemical process. Batteries are sometimes rated by their short circuit current (for a brief, specified, time) but they are not designed with a short circuit in mind.
Otoh, interestingly, PV cells are usually characterised in terms of open circuit volts, short circuit current and maximum power output (at specified temperatures). Continuously taking near-short circuit current is not too harmful for PV cells I believe.
CWatters
CWatters is offline
#8
Dec22-13, 10:37 AM
P: 2,861
Very true. Model aircraft and car racing competitors carefully control the temperature of their battery packs to get the best out of them. It's possible to get very high currents out of some quite small cells if you know what you are doing.
Borek
Borek is offline
#9
Dec22-13, 02:12 PM
Admin
Borek's Avatar
P: 22,655
Quote Quote by sophiecentaur View Post
http://en.wikipedia.org/wiki/Nernst_equation
Basically voltage is directly proportional to the temperature.
Register to reply
Related Discussions
LC circuit: finding the time interval between maximum potential and maximum current Introductory Physics Homework 5
Battery to battery straight wire of current? Classical Physics 1
Maximum Battery Charging Amperage Electrical Engineering 1
Determine the maximum current discharged from a battery Introductory Physics Homework 6
Maximum power/current for a battery? Introductory Physics Homework 3
