Intersection Equation of two Trigonometric Graphs
In summary, the graphs of f( ) = 2sin() - 1 (blue) and g() = 3cos() + 2 (red) have the intersection points (112.62, 0.8461) and (180, -1), respectively. To find an equation that will have these two points in its graph, the student used the Pythagorean theorem to solve for cosx. However, because the cosx term is negative, the equation was incorrect and the student was unable to find a solution.
Sabellic
68
The graphs of f( ) = 2sin() - 1 (blue) , and g() = 3cos() + 2 (red)
are shown below:
http://img403.imageshack.us/img403/6991/38ah7.jpg
http://g.imageshack.us/g.php?h=403&i=38ah7.jpg
What equation would have the intersection points of the graph its solutions?
http://www.eformulae.com/images/trigonometry_001.gif
From using a calculator (set to degrees) I discovered the intersection points of the two graphs. They are:
1: (112.61986, 0.84615385)
and
2: (180, -1)
Therefore, to find an equation that will have these two points in its graph I did the following:
2sin(x) - 1 = 3cos(x) + 2
which eventually came to:
2sin(x) - 3cos(x) = 3
which brought me to:
2sinxcosx - 3cosx=3
cosx (2sins - 3) = 3
so cosx = 3
or sinx=3
Needless to say, it is wrong.
Can somebody tell me a strategy?
Thanks in advance.
"What equation would have the intersection points of the graph its solutions?"
Couldn't you just find the equation for a line through the two points? Also, shouldn't you be finding the two points without a calculator?
2sin(x) =/= 2sin(x)cos(x) = sin(2x). You confused 2sin(x) with sin(2x).
Try writing everything in terms of sin(x). Setting the equation to 0, factoring, and checking for extraneous roots should solve the problem.
If I wanted to find the points algebraically without a calculator, would I do what I thought was the original answer?
That is solve for:
2 sinx - 1 = 3cosx + 2
Thanks
That is solve for:
Thanks
Yes. This will give you the x value of the points. Now substitute these into one of the equations to find the y value.
Thanks a lot.
But I can't get past:
2sin(x) - 3cos(x)=3
How do I solve for x? Am I supposed to multiply them by some number so they all become sin?
Do you know of any relations between the sin and cos functions so you would be able to eliminate one of them in your equation?
is sin^2x=1-cos^2x?
Oh, no. I multiply both sides by cosx.
No. 2sin^2(x)=1-cos(2x)
oh sorry
So what do you get when doing this?
Sabellic said:
is sin^2x=1-cos^2x?
I think you mean sin2x = 1 - cos2x. And yes that is the (fundamental) relation that would solve this problem. You might want to isolate the cos(x) term in the equation before applying that though.
sin2x - 3cos^2x = 3cos x
In other words, multiplying by cos (x) doesn't seem to get the answer.If i multiply by cos(x) I will never get rid of the cos(x) and won't be able to solve using one trig ratio.
I'm stuck too. My brain isn't thinking.
Are you sure the original equations are written correct?
Dang, you kind of isolated the cos(x) term. Why not keep it simple and manipulate it so that you have positive terms?
2sin(x)-3 = 3cos(x).
By the fundamental pythagorean identity, cos(x) = [tex]\sqrt{1-sin^2x}[/tex]. Do you see how this substitution will make everything in terms of sin(x)?
y= 2sinx - 1
and
y= 3cosx + 2
therefore
2 sinx - 3 cosx = 2 + 1
2sinx - 3cosx = 3
BTW, I thank you very much for trying.
Yep. That should do it. Thanks snipez90
let's see:
(2sinx - 3) (2sinx -3) = 9 (1-sin^2x)
4sin^2 - 6sinx - 6sinx + 9 = 9 - 9sin^2x
4 sin^2x - 12sinx + 9 = 9 - 9 sin^2x
13sin^2x - 12sinx = 0
sinx (13sinx - 12) = 0
Like that?
Yes, and that means sin(x) = 0 or 13sin(x) - 12 = 0. Now check both of those equations. Remember there is probably a loss of information from squaring both sides, so make sure you only find the solutions that work. For instance, the graphs obviously don't intersect for x = 0 (which is an extraneous solution, sin(0) = 0 but 0 - 3 =/= 3).
but, if I use:
13sinx - 12=0
13sinx = 12
sinx = 12/13
This equals 67 degrees.
But the points of intersection are: (112.62, 0.8461) and (180, -1)
I did warn you about extraneous solutions didn't I? :). Anyways your inverse sin on the calculator probably only calculates the least valued solution for which the equation is true. Remember sin(x) = sin(pi-x) pi is equivalent to 180 degrees by a conversion factor.
I don't follow the last part you are talking about though. Why did you had 0-3?
OK, I know I'm not supposed to give full solutions but you've pretty much solved the problem yourself (well hopefully you understood the motivation behind converting everything to sin(x) and well you did do the algebra yourself) so I'll try to explain the actual solutions/roots part.
Whatever our solutions are, they have to satisfy 2sin(x) -1 = 3cos(x) + 2. Everything we do has to go back to that. Now we have sin(x) = 0 and 13sin(x) -12 = 0. Examine the first case sin(x) = 0. Now if you're just starting out, you would examine just two cases, x = 0 degrees and x = 180 degrees. If x = 0 degrees, 2sin(0) - 1 = -1 and 3cos(0) + 2 = 5, so this does not satisfy the equation. If x = 180 degrees, 2sin(180) -1 = 0 -1 = -1 and 3cos(180) + 2 = -3 + 2 = -1. So the equation is satisfied.
Now generalize the result, from the unit circle, all multiples of pi, or 180 degrees, satisfy sin(x) = 0 (verify this). But we have shown that 0, an even multiple of pi does not satisfy the original equation. Thus all even multiples of pi are extraneous solutions (remember, adding 2pi or 360 degrees will give us the same angle essentially). Similarly, we have shown that pi satisfies the equation. So we claim that odd multiples of pi work. Thus we can write our solution set (from sin(x) = 0) as x = 180n degrees (or again, pi*x where n = 1, 3, 5 ...
Now try analyzing the second part (13sinx - 12) on your own.
Ok. I will check extraneous roots:
2sinx - 1 = 3 cosx + 2
2 sin (12/13) - 1 = 3 cos (12/13) + 2
-0.96777993 = 4.999610675
They don't equal.
EDIT: Oh, I understand what I did wrong. It is not 67 degrees. 67 degrees is like the reference angle.
Ok. Don't worry. I'll get the rest.
I really, really, really appreciate all your help. I couldn't have done it without you.
Thanks snipez.
Oh, yes. I see. It's about adding it to 180 degrees.
Dang that's sneaky. Thanks snipez. I understand what I did wrong.
Well not 100%, but almost.
1. What is the formula for finding the intersection points of two trigonometric graphs?
The formula for finding the intersection points of two trigonometric graphs is to set the two equations equal to each other and solve for the variables. This will give you the x-coordinate of the intersection point. To find the y-coordinate, plug the x-coordinate into either of the original equations and solve for y.
2. Can you explain how to graph the intersection equation of two trigonometric graphs?
To graph the intersection equation of two trigonometric graphs, start by graphing each individual graph on the same coordinate plane. Then, identify the intersection points by setting the two equations equal to each other and solving for the variables. Plot these points on the graph and draw a line connecting them. This line will represent the intersection equation of the two graphs.
3. What are the possible number of intersection points between two trigonometric graphs?
The number of intersection points between two trigonometric graphs can vary. In some cases, there may be no intersection points if the two graphs do not intersect. However, there can also be one, two, or multiple intersection points depending on the equations and their graphs.
4. Can the intersection equation of two trigonometric graphs have more than one solution?
Yes, the intersection equation of two trigonometric graphs can have more than one solution. This occurs when the two graphs intersect at multiple points. In this case, there will be multiple values for the x-coordinate and corresponding y-coordinates for each intersection point.
5. How can the intersection equation of two trigonometric graphs be used in real-life applications?
The intersection equation of two trigonometric graphs can be used in real-life applications such as engineering, physics, and astronomy. It can help determine the points of intersection between two objects or trajectories, which can be useful in predicting collisions or planning trajectories for objects in motion.
33K
