Is 1/R^3 descriptive of magnetic force drop off?
In summary, the magnetic field of a dipole drops off as 1/r^3 as you move away from both poles. This is likely not accurate if the dipole is near a magnet, as the far field may be much weaker than the near field.
rockyshephear
232
Someone on YoutTube stated...
Each magnetic pole drops off by 1/R^2. Once you get away from both poles (Cavendish setup) they they start canceling each other out and it ends up as 1/R^3.
Comments?
Here's the link if you need backup info
http://www.youtube.com/comment_servlet?all_comments&v=euvWU-4_B5Y
Yes, that's correct. Far field magnetic strength decreases as the cube of the radius.
What do you mean by far field magnetic strength? And can the setup on the youtube page work like it depticts?
I've never seen this equation ever!
The field strength of a magnetic dipole drops off as 1/r^3 when you're relatively far away from both poles.
A magnetic monopole's field strength would drop off as 1/r^2, but there are no true magnetic monopoles (as far as anyone knows), so the leading-order contribution is the 1/r^3 term.
So, I guess I have to forget what I've read that magnetism of a metal object near a magnet (always a dipole) fades off with the square of the distance. Have they started changing the textbooks yet? lol
Relatively far away from both poles. Like a million miles? How do I know the tranistion point? So the force varies like this?
R being 1 inch = 1 N, 2 inch =1/4 N, 3 inch = 1/9 N...(somewhere it changes)...1 mile = 1/R^3
Can someone look at the YouTube video and indicate whether this is a faked setup or not?
http://www.youtube.com/comment_servl...&v=euvWU-4_B5Y
Ah, but you're talking about near a magnet. When you're much closer to one pole of a magnet than the other pole, then it is a 1/r^2 force (or, well, very nearly so) because the effect of the one pole you're close to is so much larger than the effect of the other pole. The 1/r^3 behavior is only far away from the dipole.
If you were to start next to one pole of a bar magnet and move away in any direction, measuring the magnetic force as you go, you'd find that it starts out looking like 1/r^2 and then gradually transitions to 1/r^3.
Wow, I have never ever read this anywhere and even in the MIT Walter Lewin lectures either. I'm amazed. Please check out the YouTube video and comment. Thanks. I was wrong.
I made a little graph to show the magnetic force dropoff from a dipole, as you start from one pole and move off to the side. The red line is the actual dipole force, the green line is 1/r^2, and the blue one is 1/r^3, and you can see that the red line starts out following the green line then "moves over" to the blue line. As I said, it's a gradual transition, but the center of sorts is at r=1 on the graph, which represents the length of the dipole. So if the two poles are a distance d apart, roughly speaking, the force is like 1/r^2 if you're closer than d, and like 1/r^3 if you're further away than d.
Technical details: I actually used the formula for an electric dipole,
[tex]\vec{E} = \frac{q}{4\pi\epsilon_0}\left[\left(\frac{1}{x^2}-\frac{x}{(x^2+d^2)^{3/2}}\right)\hat{x} - \frac{d}{(x^2+d^2)^{3/2}}\hat{y}\right][/tex]
but a magnetic dipole behaves the same way with respect to r.
Haha that youtube video is definitely faked somehow. The gravitational constant is far far far too weak to have such an effect.
So why does not gravity do the same thing??
Because gravity is universally attractive. There are no gravitational poles. However, note that tides, which are ultimately caused by gravity, do also decrease with the radius cubed because tides are a differential force.
Thanks!
Which textbooks say this? Last semester I taught intermediate level E&M from https://www.amazon.com/dp/013805326X/?tag=pfamazon01-20 which derives the far field from both electric and magnetic dipoles as [itex]1/r^3[/itex].
See also for example Wikipedia's article on dipoles.
What's the equation to determine how far away the far field is?
See Diazona's answer in post #11. There's no sharp "boundary" between the near field and the far field. The far-field formula is always an approximation to the true field, which gets better and better as you get further and further away from the dipole.
How far away you have to get before the far-field formula is "good enough," depends on your definition of "good enough."
Is it like this? Since gravity is totally attractive and magnetism has attractive and repulsive attributes, the attractive and repulsive tend to cancel each other?
Also can you check the link to YouTube and tell me if this setup if faked?
1. How is the 1/R^3 term descriptive of magnetic force drop off?
The 1/R^3 term is derived from the inverse square law, which states that the intensity of a force decreases in proportion to the square of the distance. By applying this law to the magnetic force between two objects, we can see that the force decreases even more rapidly, resulting in the 1/R^3 term.
2. Why is the 1/R^3 term specifically used for describing magnetic force drop off?
The 1/R^3 term is specific to magnetic force because it takes into account the fact that magnetic fields have both a magnitude and a direction, unlike other forces like gravity which only have magnitude. This means that the force decreases more rapidly as the distance increases, resulting in the 1/R^3 term.
3. How does the 1/R^3 term affect the strength of the magnetic force?
The 1/R^3 term means that as the distance between two objects increases, the strength of the magnetic force decreases much more rapidly compared to other forces. This is due to the fact that magnetic fields have both a magnitude and a direction, resulting in a more rapid decrease in force with distance.
4. Is there any other factor that affects the 1/R^3 term in describing magnetic force drop off?
Other factors that can affect the 1/R^3 term include the strength of the magnetic fields, the orientation of the magnets, and the presence of any other magnetic or non-magnetic materials between the two objects. These factors can alter the strength and direction of the magnetic force, and therefore affect the 1/R^3 term.
5. Can the 1/R^3 term be used to accurately predict magnetic force at any distance?
No, the 1/R^3 term is only descriptive of the magnetic force drop off between two objects at a certain distance. It cannot be used to accurately predict the exact strength of the magnetic force at any distance, as other factors such as the orientation of the magnets and the presence of other materials can also affect the force.
  • Electrical Engineering
  • Other Physics Topics
  • General Engineering
