Magnetic force on a moving charge particle with friction force acting on it
In summary, the problem involves a "q" charge particle moving along the +y axis with velocity V0 starting from the origin, while a friction force and a constant magnetic field act on it. The goal is to find the x-coordinate of the particle when it stops. The solution involves using Newton's 2nd law in vector form and integrating it to obtain the general velocity along the x and y axes as functions of time. This leads to a differential equation that can be solved using complex numbers. The final velocities are of the form v0*[e(^(-constant))]*cos(wt), where w is the angular frequency.
siddscool19
A "q" charge particle is moving along +y axis with velocity V0 starting from Origin. A friction force is acting on the charge particle " f= -(alpha)V(Vector) ".A constant magnetic field of magnitude B0 acting along +Z axis. The mass of the particle is m. Find the x co-ordinate of the particle when it stops.
I Have found that the total path moved by the particle is mV0/(alpha)
But I don't know how to find x coordinate with it.
There is a quick way to solve this problem: write down the Newton 2nd law equation in vector form and integrate it :wink:
I have solved the problem. I am just too lazy to type the WHOLE thing out here. The solution is kind of long. Basically, get the general velocity along X axis and Y axis as a function of time.
To obtain this, in the penultimate step, you will get a differential equation that you will have to solve using Complex numbers.
In the end, the velocities will be something of the type v0*[e(^(-constant))]*cos(wt), where w is the angular frequency.
You are not even allowed to write whole solution. you can just give hints.
I would approach this problem by first considering the forces acting on the charge particle. The magnetic force, given by F = qV x B, will cause the particle to move in a circular path in the xy-plane. However, the friction force, given by f = -(alpha)V, will act in the opposite direction and slow down the particle's motion.
To find the x-coordinate when the particle stops, we need to find the point at which the forces balance each other out and the particle comes to a rest. This can be done by setting the net force equal to zero and solving for the velocity at that point.
F_net = F_magnetic + F_friction = 0
qV x B + (-alpha)V = 0
Solving for V, we get V = (alpha/qB).
Now, we can use the equation for velocity, V = dx/dt, to find the x-coordinate when the particle stops.
dx/dt = (alpha/qB)
Integrating both sides, we get x = (alpha/qB)t + C
To determine the constant C, we can use the initial conditions given in the problem. Since the particle starts at the origin, we know that x = 0 when t = 0. Therefore, C = 0.
Thus, the final equation for the x-coordinate when the particle stops is x = (alpha/qB)t.
We can now substitute in the given values to find the specific x-coordinate.
x = (alpha/qB)(mV0/alpha) = mV0/qB
Therefore, the x-coordinate of the particle when it stops is mV0/qB.
In conclusion, by considering the forces acting on the charge particle and using the equation for velocity, we were able to determine the x-coordinate when the particle comes to a rest. This solution can be verified by plugging in the values and checking that the net force is indeed equal to zero.
What is magnetic force?
Magnetic force is the force exerted on a moving charged particle by a magnetic field. It is a vector quantity and is always perpendicular to the direction of motion of the particle.
How does magnetic force affect a moving charge particle?
The magnetic force will cause the charged particle to change direction, but not speed. This is because the force is always perpendicular to the velocity of the particle, so it does not do any work on the particle.
What is friction force and how does it affect a charged particle?
Friction force is the force that opposes the motion of an object. In the case of a charged particle, friction force can arise due to interactions with the medium through which it is moving. This force will cause the particle to slow down, as it acts in the opposite direction of the particle's motion.
How do magnetic force and friction force interact with each other?
When a charged particle is moving through a medium, both magnetic force and friction force will act on it simultaneously. The resulting motion of the particle will be a combination of these two forces, and the final path of the particle will depend on the relative strengths and directions of the forces.
How can the magnetic force and friction force on a charged particle be calculated?
The magnetic force on a moving charged particle can be calculated using the equation F = qvBsinθ, where q is the charge of the particle, v is its velocity, B is the strength of the magnetic field, and θ is the angle between the velocity and the magnetic field. The friction force can be calculated using the equation F = μN, where μ is the coefficient of friction and N is the normal force acting on the particle.
