Frictional Force: Reaction Force & Turning Cars
  • Thread starter chocofingers
  • Tags
    Forces
In summary: For a brief moment, the object is moving at a much higher speed than the surface it is sliding on. That means the speed of the object is greater than the speed of the friction, and the object starts to slow down. At some point, the speed of the object will be equal to the speed of the friction, and the object will stop.So, in summary, friction is a force that opposes the motion of an object. It is caused by the contact of two surfaces and is quantified by the static friction coefficient. Static friction is important for preventing objects from moving, but it is not the only type of friction.
chocofingers
30
1.is frictional force a reaction force.?
e.g when we walk there is force of friction that allow us to walk.if there isn't any friction we can't walk.
my question is that if there is no friction there will be reaction from the ground when someone will walk,why doesn't he walk then.
if friction is a reaction force then why it is less than the driving force very often.
2.how frictional force provides a centripetal force when turning a car.
plx help me in this. thnxz in advance
It's the direction. If there is no friction, reaction force from ground is perpendicular to surface. On a flat surface, that's straight up. Useful for not falling towards the center of the planet, not so much when you try to move. If you ever lost footing on ice, you should have some idea of what it's like. Except, on ice you can get a grip if you are careful, because there is still some friction.
As far as friction itself, which one you call action and which you call reaction is matter of preference, really. But yes, the ground always pushes on you as much as you push on it. That's true for vertical and horizontal components. No getting around that.When you make a turn, the car would "like to" continue traveling in the straight line, but that would require tires to slip relative to ground. The force preventing the slipping is the static friction force. Since the wheel rolls along direction of motion, there is no static friction in that direction. You get a force that's perpendicular to direction of travel and points into the turn. That's your centripetal force which keeps the car following the curve.
How do I thankyou K^2 :P
Thankyou so much!
what is friction? i read article about friction in wikipedia but there is not explained what it is, is it something like fluid resistance?
yeah friction is an opposing force to every moving object plus an object that is at rest. A friction causes the book to stay on the table and yet on other occasions it is not necessary like when reducing friction b/w moving parts of machine
And fluid resistance has another term called drag force :)
aha:D of course i know this but i didnt associated this with "tarcie" in polish, thanks:)
aww welcome :P
ANything else? what don't U understand ? :)
aww welcome :P
There isn't a terribly good quantitative model that perfectly explains friction in all situations, but qualitative explanation for static friction force can be given.
An object supported by horizontal surface experiences some pressure distributed over the contact surface. If we look at it closer, we see that the surfaces are not perfectly smooth, and so instead, you have a whole bunch of contact points between object and support, and surface at points of support isn't always level. Since the normal force is perpendicular to the surface, you end up with support forces not all pointing straight up, but rather point at different angles. The net force is still pointing straight up.
Now, suppose you start pushing an object. You are now shifting the weight off the support points where support force points in the direction of your push and onto the support surfaces that point against it. You are effectively trying to push an object uphill. So in order to get the object to move you are going to apply a force that is some fraction of the object's weight. The fraction is the static friction coefficient, and will depend on smoothness and hardness of the two surfaces.
Once an object is in motion, however, this picture changes. Kinetic friction is much more difficult to explain on microscopic level, but it still has to do with object effectively always going "up-hill".
1. What is frictional force?
Frictional force is a type of force that resists the motion of two surfaces that are in contact with each other. It is caused by the microscopic irregularities on the surfaces that create resistance when they slide against each other.
2. What is the reaction force in relation to frictional force?
The reaction force is the force that is exerted by a surface in response to the force applied to it. In the case of frictional force, the reaction force is equal in magnitude and opposite in direction to the force applied by the object.
3. How does frictional force affect the movement of turning cars?
Frictional force plays a crucial role in the movement of turning cars. It provides the necessary grip between the tires and the road surface, allowing the car to turn without slipping. The direction of the frictional force is towards the center of the turn, which helps to keep the car on the desired path.
4. How can frictional force be reduced in turning cars?
Frictional force can be reduced in turning cars by using materials with a lower coefficient of friction for the tires, such as slick tires. Additionally, keeping the tires properly inflated and maintaining a smooth road surface can also help reduce frictional force.
5. How does the weight of a car affect the frictional force in turning?
The weight of a car has a direct impact on the frictional force in turning. A heavier car will have a greater normal force (the force perpendicular to the surface) on the tires, resulting in a larger frictional force. This can provide better traction and stability for turning, but it can also increase the wear and tear on the tires and other components of the car.
  • Mechanics
  • Mechanics
9K
  • Mechanics
  • Mechanics
  • Mechanics
