Calculating Heat Capacity & Water Flow to Melt Honey Barrels
In summary, a technician provided a rough guide on how much energy is needed to melt 300kg of honey from 10°C to 50°C. It would take 300 x 10^3 x (50-10) x 0.73 = 8.76 million calories, or 36.8 Mjoules. To get this amount of energy from water cooling from 60°C to 50°C would need 876kg of water.
lukeluke
Hi there,
I am not an engineer but i do have scientific background. It is just a long time since i did any calculations!
I am trying to design myself a new way of melting barrels of honey. I have 200L, 300kg barrels of crystalized honey that I need to melt. One method I envisage is to make an 'element' type coil of pipe with hot water flowing though it that would melt the honey in the barrel from the inside out.
How would I calculate the surface area that the element would need to be to melt a barrel of honey in say 24 hours?
That is from 10C to 50C. with say the water at 60C.
Ah yes the specific heat capacity of honey is 0.73cal/g/C.
Could i also work out how much hot water i needed? and how fast i would need to pump it around the coil?
How do you think this would compare to just sitting the barrels in a big vat of hot water?
Thanks for your help. It is much appreciated.
As a very rough guide to get you started I would say that the energy required to warm 300kg of honey from 10C to 50C would be 300 x 10^3 x (50-10) x 0.73 = 8.76 million calories
or 36.8 Mjoules. (I am used to using Joules !)(1cal = 4.2J)
To get this amount of energy from water cooling from 60C to 50C would need
36.8x10^6/(10C x 4200) = 876kg
So if you had a flow rate of water of 10kg/min it would take 87.6minutes
These are very rough and ready figures which I hope make sense.
I do not know whether honey has a LATENT HEAT (needed to convert solid to liquid)...
I suspect it does not but... I don't know
good luck
Thanks for that technician. My calculations were only out by 2 decimal places!
I have another question now... I have an idea for setting up a flow inside the drum. If the solid honey was melted from the outside and the bottom simultaneously would the warm honey flow to the top and push the solid core down to the bottom where it would be melted faster?
Ta
This is just my opinion, Lukeluke, but your drum idea seems upside-down to me. I think that it would make more sense to heat it from all directions, or even just the bottom and sides that you suggest, and drain it straight out from the bottom. The cooler stuff will then naturally drop and be liquified in turn. I don't know the chemical properties of honey (unless "tastes great" counts), but I assume that you chose 60° because it will eliminate crystalization without adversely altering any other aspects.
What you need is an industrial kettle, these are double skinned with water flowing between the skins, the water is heated by elements in the bottom.
They can be picked cheaply secondhand.
http://www.specialprojects.com/search/kettle/
They come in all sizes and shapes, some have stirrers.
1. What is heat capacity?
Heat capacity is the amount of heat energy required to raise the temperature of a substance by one degree Celsius. It is a measure of a material's ability to store thermal energy.
2. How is heat capacity calculated?
Heat capacity is calculated by dividing the amount of heat energy absorbed by a substance by the change in temperature. This is typically measured in joules per degree Celsius (J/°C) or calories per degree Celsius (cal/°C).
3. How does water flow affect the melting of honey barrels?
The flow of water can greatly affect the melting of honey barrels. Higher water flow rates can increase the rate of heat transfer, resulting in faster melting of the honey. It can also prevent the formation of a stagnant layer of cooler water around the barrels, promoting more efficient heat transfer.
4. Can heat capacity be affected by other factors?
Yes, heat capacity can be affected by other factors such as the material's composition, temperature, and pressure. For example, materials with a higher specific heat capacity will require more heat energy to raise their temperature compared to materials with a lower specific heat capacity.
5. What is the best method for calculating heat capacity and water flow for melting honey barrels?
The most accurate method for calculating heat capacity and water flow for melting honey barrels is to conduct experiments in a controlled environment. This will allow for real-time data collection and adjustments to be made to optimize the process. Alternatively, mathematical models and simulations can also be used to estimate heat capacity and water flow rates.
  • General Engineering
  • DIY Projects
  • Mechanical Engineering
