Can someone please explain this statement regarding Newton's 3rd law?
In summary, when an object falls towards the Earth, it is pulled by the Earth's gravity towards the center of mass. This follows Newton's 3rd law, where the falling object also exerts an equal and opposite force on the Earth, causing it to accelerate towards the object. This can be seen in the example of a satellite falling towards Earth with a force of 9.8N, causing both the object and the Earth to accelerate in opposite directions. This is due to the fact that the force of gravity depends on the masses of both objects. The equal and opposite forces are due to the fact that each object pulls on the other with the same force. However, the accelerations are not equal unless the masses are also equal
ASidd
73
This is a statement from my textbook
"When an object falls down, it falls inwards towards the centre of mass of the Earth pulled by it's gravity. As said in Newton's 3rd law of motion the falling object will also exert an equal and opposite force on Earth; which then accelerates upwards towards the object."
What the heck does that mean?
If a satellite falls down on Earth and the gravity on it is 9.8 then is it also exerting a force of 9.8 on earth? How is that possible?
Can somebody please please clear this up for me?
You are mixing up force and acceleration; otherwise you are doing fine.
The Earth exerts a force of 9.8N on a 1kg mass, causing it to accelerate towards the Earth at 9.8ms-2. The mass exerts a force of 9.8N on the Earth, causing it to accelerate towards the mass at 9.8/6x1024=1.6x10-24ms-2. The forces are the same, but the visible results are very different.
If you're still boggling at that, ask yourself a question: what's the other option? That the Earth doesn't move? If so, why does it move under the gravity of the Sun? You could also look up the word barycentre.
Another way to look at it is that it's all just atoms pulling on each other. Some of the atoms happen to be bound together in large balls, and some in small balls, but it's all just atoms.
So F=ma and the force exerted depends on mass since the Earth has a much larger mass we barely feel it but the force exerted on the object by it is felt because that object has a much smaller mass?
But then what is with equal and opposite forces?
Exactly what it says- the force of gravity between to masses is [itex]-GMm/r^2[/itex]. Each object pulls on the other with exacty the same force. If the Earth pulls on an object with mass m, then, because "F= ma" so a= F/m, its acceleration is [itex]-GM/r^2[/tex]. The mass "m" has canceled. And the object pulls on the Earth with exactly the same force. The difference is that now, to find the Earth's acceleration we divide by earth's mass which is much much larger- the Earth's acceleration toward the object is [itex]-Gm/r^2[/itex] which is too small to be measured.
The forces are equal and opposite. The accelerations are not, unless the masses are equal. The difference is enormous in this case, as HallsOfIvy points out.
1. What is Newton's 3rd law?
Newton's 3rd law states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object exerts an equal but opposite force on the first object.
2. Can you give an example of Newton's 3rd law in action?
A classic example is a person pushing a wall. The person exerts a force on the wall, but the wall also exerts an equal and opposite force back on the person. This is why the person does not move or fall through the wall.
3. How is Newton's 3rd law related to the concept of momentum?
Newton's 3rd law is closely related to the concept of momentum. According to Newton's 2nd law, force is equal to mass multiplied by acceleration (F=ma). Momentum is also equal to mass multiplied by velocity (p=mv). Since the force exerted on an object is equal to the change in momentum over time, the equal and opposite forces in Newton's 3rd law are essentially the cause and effect of changes in momentum.
4. Is Newton's 3rd law applicable to all types of forces?
Yes, Newton's 3rd law applies to all types of forces, including gravitational, electromagnetic, and contact forces. This law is a fundamental principle in physics and is used to explain the interactions between objects in the universe.
5. What are the implications of Newton's 3rd law in everyday life?
Newton's 3rd law has many implications in everyday life. For example, it explains why we feel a pushback when we jump off a diving board or why we feel a recoil when we shoot a gun. It also plays a role in the design of structures, vehicles, and other objects that need to withstand forces and maintain balance.
