Thermodynamics - evaporator condenser
by James MEng
Tags: condenser, evaporator, thermodynamics
James MEng
James MEng is offline
#1
Oct31-13, 04:05 PM
P: 6
Hello - fundamental thermo question which is puzzling me...
It concerns a multiple effect evaporator with condenser. Hot vapour is water, cooling medium is water.
My question stems from the following:
When the flow of cooling water to the condenser is increased, the pressure in the condenser (and thus the pressure profile of the entire evaporator) is reduced.
Here's how I understand it...
  • Heat transfer area of condenser remains constant
  • Overall heat transfer coefficient is increased slightly; given that the Reynolds number on cold side is increased
  • Cooling water temperature out is reduced (assuming heat load is constant and inlet temperature is the same)
How does this in turn lead to a reduction in evaporator pressure, please explain in basic terms (what's actually physically happening rather than just formulae! ).
Thanks in advance for any replies
Edit: Also the mass flow rate of condensate will be the same for a given flow "in" of water and steam. Some thermodynamic activity is occuring here I just cannot work out what!
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
Register to reply
Related Discussions
Refrigeration Heat Exchanger Design (Evaporator and Condenser) Engineering Systems & Design 1
Refrigeration - Work done by evaporator, condenser, expansion valve General Engineering 11
design for the condenser coil evaporator coils General Engineering 0
Refrigeration - Fouling in the sizing evaporator and condenser Mechanical Engineering 1
heat exchanger capacity (condenser and evaporator) Mechanical Engineering 4
