New Reply
Calculating temperature increase in a building as a result of solar radiation
Share Thread Thread Tools
Dec18-12, 11:53 AM   #1
I'm working on a thermal balance of a building. In particular, I'm trying to calculate the effect energy gains (mostly due to solar radiation) have on the inside temperature of the building. So I calculated the energy gains per month, for instance, 20 kW for the month of February (it's an extremely poorly insulated building). The only way I know of relating heat, temperature, and mass, is through the equation:
Q=m.cp.dT
where:
- Q is the heat in kJ
- m is the mass of air in kg
- cp is the specific heat of air in kJ/kg.K
- dT is the temperature difference in K
(Note: I'm using the dot to represent thousands and the comma to represent decimals)
So, in one hour, we have 20 kWh, which is 72.000 kJ. For a volume of 637 m3 (the volume of the building) and a density of air of 1,2 kg/m3, we end up having 764 kg of air. If we consider the specific heat of air to be 1,0 kJ/kg.K, then dT is 94 K.
I must admit the number shocked me, so much so that I think I'm doing something wrong. Is there something I'm missing here? Theoretically, if I had a perfectly insulated volume of 637 m3 of air, and I heated it during 1 hour with 20 kW, then it's correct that said volume would experiment a temperature increase of 94°C?
Finally, in the case of a poorly insulated building (it has three sliding-glass walls and a corrugated steel pitched roof), how much could I expect the inside temperature to rise in summer? In other words, how can I accurately calculate temperature increase in a building as a result of solar radiation gains?
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec18-12, 04:59 PM   #2
mfb
Newcomer 2012
Recognitions:
Homework Helper Homework Help
You can neglect the air, unless you care about short-term effects from ventilation. The heat capacity of solid materials will dominate the total heat capacity. There is an easy way to see this: The mass of the building itself is much more than 760kg.
Dec18-12, 05:24 PM   #3
Recognitions:
Gold Membership Gold Member
If you had 20kW worth of central heating and you ran it for an hour, an average house would be 'very cosy' and that would be a real building with many heat loss mechanisms (which are going to lose heat proportional to the temperature difference). After an hour the walls and contents would have started to warm up and the heat capacity of those and all the other contents.
Years ago, I decided to get central heating installed in my home and I estimated the size of radiators needed for each room for a given temperature rise etc, etc. The answer I got was laughably small - until I realised that you need to take air exchange into account. I then got some sensible answers. The guy who did the installation then went and ordered different ones and the house was always very comfortable!! So much for theory. (I think he bought the cheapest sizes so I'm not complaining.)
Dec19-12, 04:40 AM   #4
Quote by mfb View Post
What exactly do you mean by, "you can neglect the air"? Heat gains will invariably rise the temperature inside the building, won't they?
Dec19-12, 04:41 AM   #5
Quote by sophiecentaur View Post
Okay, so 20kW is not that random a number then. Thanks.
Dec19-12, 04:50 AM   #6
Recognitions:
Quote by OdanUrr View Post
Bearing in mind that rich, nerdy people actually do build themselves houses that need no extra heating, there must be enough solar energy available to your house to keep it warm. That 20kW is certainly in the right ball park.
Going to the situation of high summer in a hot climate, you can expect to have a similar amount of heat to get rid of in order to stay comfortable.
Dec19-12, 04:58 AM   #7
Yes, that's why I'm going to use insulation in the model, to try and see if I can get rid of solar heat gains. I'm trying to create an insulated environment for an indoor pool.
Dec19-12, 07:02 AM   #8
mfb
Newcomer 2012
Recognitions:
Of course. Where is the connection between both?
Heat capacity of buildings is dominated by the heat capacity of the building itself and not its air. The heat capacity of air can be relevant for heating/ventilation.
You can quickly cool (or heat) the air by several degrees if you open a window. But as soon as you close the window again, temperature will quickly return to its previous value (with some very small drop) as the walls heat the air again.
Dec19-12, 07:05 AM   #9
Recognitions:
This is true but only if all the windows are closed! If they are open, you need to consider all the air in the surrounding (and changing) atmosphere. In practical terms this has more effect on your heating bills than anything else.
Dec19-12, 02:03 PM   #10
Perhaps I'm being picky but..
An "energy gain" is measured in Joules or possibly kWH if you insist. It's not measured in kW, that would be a power gain.
I believe well insulated houses need to incorporate shading to avoid overheating from solar gain. I think there are computer programs available to simulate this but I've not investigated.
If you are getting into this for real I recommend joining The Green Building Forum and posting requests for info on passive houses over there. I think there might be a small one off joining fee but can't remember how much it is.
http://www.greenbuildingforum.co.uk
New Reply
Tags
building, solar radiation, temperature increase, thermal balance
Thread Tools
Similar Threads for: Calculating temperature increase in a building as a result of solar radiation
Thread Forum Replies
Use pressure to increase temperature of solar oven? General Physics 7
solar radiation - conversion to calculate radiation impacting vertical surface Earth 0
Conical Solar Tunnel to Redirect Solar Radiation Engineering Systems & Design 2
Force applied: calculating increase in temperature (work mostly done, need help!) Introductory Physics Homework 1
Can spin result in an increase of velocity? General Physics 4
