New Reply
Autocad center of gravity
Share Thread Thread Tools
Dec22-12, 09:31 AM   #1
HELLO
Can someone help me locate the center of gravity for my vehicle design? all the parts, dimensions and mass of the parts of the design are known. Is it possible to locate for the COG of it? Thanks!
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Dec22-12, 01:30 PM   #2
Quote by RJ2012 View Post
HELLO
The way I always did it in 2D was draw it, REGION it and MASSPROP it. From the massprop, you can drag the figure by the centroid to (0,0).
Dec22-12, 01:37 PM   #3
Hello! Is your method accurate? :) Does the result agree with the calculate/ theoretical ( if theres any) center of gravity? thanks buddy!
Dec22-12, 01:51 PM   #4
Math 2012
Recognitions:
It will be as accurate as your CAD model. Most CAD models give a significant underestimate of the total mass of the object, because they don't contain all the "little" components like nuts and bolts that hold the real structure together, the mass of surface finishes like paint, manufacturing tolerances that produce oversized parts, etc.
That type of thing can easily contribute a few percent to the total mass of the real object, and obviously it can change the CG position as well.
Dec22-12, 02:59 PM   #5
Hello AlephZero! thanks for the reply! Do you know a firm (online ) who do modelling and do stuff in AutoCAD, or can you suggest me some readings/ related lit about center of gravity. I keep on looking and looking for different materials for this topic, thank you!
Dec23-12, 09:31 AM   #6
In 2D, it's more accurate than you'll ever need. Try it out with an oddly shaped piece of cardboard or thin plywood (something with constant thickness). You should be able to balance the cardboard or plywood on a nail at the centroid AutoCAD gives you.
New Reply
Thread Tools
Similar Threads for: Autocad center of gravity
Thread Forum Replies
Force to hold a cylinder about its axis with Center of Gravity offset from the center General Physics 2
Center of Gravity questions - Center of Area Introductory Physics Homework 3
Moon Center of Mass/ Center of Gravity Classical Physics 6
3d design autocad tips : How to Change Dimension Text in AutoCAD Engineering Systems & Design 0
center of mass and center of gravity different in non uniform gravitation field?expl General Physics 4
