- #1
Pythagorean
- 313
Standard double pendulum setup. A string with mass, connected to a string with a mass, mounted to the ceiling. Given is m1,m2,l1,l2
a) choose a suitable set of coordinates and write a lagrangian function, assuming it swings in a single vertical plane (I did this, using L = T - U)
b)write out lagrange's equations and show that they reduce to the equations for a pair of coupled harmonic oscillators. (here's where my problem arises)
The Lagrangian
d/dt[dL/(dq/dt)] - dL/dq = 0
[tex]\frac {d}{dt} \frac {\partial L}{\partial d \theta_k[/tex]
My issue is really a implicit/explicit differentiation problem.
I come up with a term under the d/dt (first term) of the lagrangian that involves three variables (all degrees) in this form:
(dx1/dt)*sin(x1 - x2)
when I take the time derivative of this, how do I handle the x1 and x2 (which are actually angles theta in my written notation)
I realize the first term (by the product rule) would be:
(d^2x1/dt^2)*sin(x1 - x2)
but how do I handle the two angles under the sin term that have no explicit time dependence?
Thank you for your help.
LATEX VERSION BELOW (probably being updated, I'm slow at it)
[tex] \frac {d}{dt} \left \dot{\theta_1}sin(\theta_1 - \theta_2) \right
= \ddot{\theta_1}sin(\theta_1 - \theta_2) + \dot{\theta_1} (?) + \dot{\theta_1} (?)[/tex]
the above equation is what I have, where I don't know what to do for the (?) that involves taking the time derivative of theta (which has no explicit time-dependence)
